Dishonored 2: Darkness of Tyvia
2 3
An anonymous tipster claims Dishonored 2: Darkness of Tyvia is coming to PC, PS4 and Xbox One, likely in November 2015
http://www.vg247.com/2014/07/15/dishono...
Upam, da je vse res, ker prvi del je bil odličen:)
  • spremenil: oo7 ()
medenko ::
njami.
Dishonored 2 Trailer
The trailer showcased a country in the midst of tyranny and revolution. Your character this time around is Emily Kaldwin, a character who was a child in the first game. She has a blue grappling hook that she can use to quickly scale buildings. Bethesda revealed that you can also play as Corvo, the hero from the first game.
Netrunner ::
Dishonored je ena boljših iger kar sem jih igral... da so končno naredili nekaj novega in zanimivega v FPS igrah.... tako da, komaj čakam nadaljevanje.
ahac ::
Zanimivo, če lahko igraš kot Emily ali Corvo... ni veliko single player iger, kjer bi lahko izbral characterja, sploh če je cel story vezan na njih. Ali mogoče narobe razumem in se menjata med igro (kot GTA5, Witcher 3, itd..)?
  • spremenil: ahac ()
Tr0n ::
M-Power je pa mel nocno. :)
plaz21 ::
Ahac med igro likov ne bo možno menjat. Tisto kar na začetku izbereš s tistim igraš do konca.
ahac ::
To sem videl zdaj, ja. Ampak to pomeni, da bo morala biti vsaj malo drugačna zgodba glede na to s katerim igraš...
Sploh glede na trailer, kjer Emily najde masko od Corvota... torej očitno ne delata (vseh) misij skupaj.
Here's the official story summary from Bethesda:
Dishonored 2 is set 15 years after the Lord Regent has been vanquished and the dreaded Rat Plague has passed into history. An otherworldly usurper has seized the throne from Empress Emily Kaldwin, leaving the fate of the Isles hanging in the balance. As either Emily Kaldwin or Corvo Attano, travel beyond the legendary streets of Dunwall to Karnaca - a once-dazzling coastal city that holds the key to restoring Emily to power. Armed with the mark of the Outsider and powerful new supernatural abilities, hunt down your enemies and forever alter the fate of the Empire.
Tr0n je izjavil:
Za Bethesdino konferenco se je splačalo ustati ob 4 zutraj =)
  • spremenil: oo7 ()
Mavrik ::
ahac je izjavil:
Glede na to da Corvo ni imel totalno nobene osebnosti in je bil samo lutka za izpolnjevanje ukazov... to pač ni nek problem. Mi je pa tečno da namesto da bi dejansko razdelali igralčev lik grejo na tako brezvezno foro.
yoco ::
Jz sem slišal, da lahko izbiraš med Corvom oz. Emily. Me pa mika, da bi zopet igral prvi del!
yoco je izjavil:
Jaz sem prvi del preigral dvakrat prvič stealth v drugo sem vse pobil =)
Zaphod_B75 ::
Netrunner je izjavil:
Yess, že ćez enko +DLC je sem šu pomoje ene 2x vsaj. Prvi stealth pol sm pač vsakič znova sem sprobaval nove načine kako čes prit in powerje possession, pa bend time. Vem da se je samo z blinkom dalo čez prit sam pol ni pol tok zabavno kot sicer... Vedno je blo več načinov blo kako neko stvar narest. Če bo tud dvojka nelinearna :-D.
Dishonored 2 izide 11 novembra 2016 8-)
Gameplay pa bodo pokazali naslednji mesec :)
Nekaj slik
Dishonored 2 - Official E3 Gameplay Trailer
Dishonored 2 will release on PlayStation 4, Xbox One and PC globally on November 11, 2016.
Dishonored 2 - Gamescom 2016 Gameplay Video
ahac ::
Dishonored 2 - Corvo Gameplay Trailer
Uf tole bo hudo sploh prvi del je bil fenomenalen :)
bambam20 ::
Prvi del še vedno občasno poženem in malce zaigram posamezne misije. Neverjetno , kako jim je uspelo zasnovati meni zelo privlačno okolje, precej karizmatične negativce in vsaj po moje precej zanimiv twist zgodbe na koncu.
Dishonored 2 - Creative Kills Gameplay Video
"Players won't understand Dishonored 2 till they play it twice" claims Harvey Smith
It's one of the biggest blockbusters of the year, and Dishonored 2's creator wants you to play it at least twice.
https://www.finder.com.au/players-wont-...
Tudi prvi del sem igral dvakrat tako, da ni nobenega problema :D
Dishonored 2 Clockwork Mansion Gameplay Trailer
Dishonored 2 | Gameplay Part 1 - Corvo & The Clockwork Mansion
scipascapa ::
še to
Dishonored 2 - Creating Karnaca
Dishonored 2 - Daring Escapes Trailer
Dishonored 2 Live Action Trailer - Take Back What's Yours
Zahteve za igro Dishonored 2
Minimum:
Windows 7/8/10 (64-bit versions)
Intel Core i5-2400/AMD FX-8320 or better
8 GB RAM
60 GB free HDD space
NVIDIA GTX 660 2GB/AMD Radeon HD 7970 3GB or better
Contains a single disc
Download of additional files from Steam is required to run the game
Requires Steam activation
Recommended:
Windows 10 (64-bit versions)
Intel Core i7-4770/AMD FX-8350 or better
16 GB RAM
NVIDIA GTX 1060 6GB/AMD Radeon RX 480 8GB or better
ahac ::
Launch trailer
Nekateri se pa pritožujejo nad težavami na PCju: http://www.neogaf.com/forum/showthread....
Early Dishonored 2 PC Impressions Report Troubling Performance for AMD
http://wccftech.com/early-dishonored-2-...
ahac ::
Sej to je isti vir kot sem ga jaz postal.:))
Zanimivo kako je en user napisal, da mi igra ne dela dobro... in zdaj se vsi sklicujejo na to. Prav je Bethesdi, kaj pa ni opisov... :P
ahac ::
Idiotech
Dishonored 2 - PC Performance Problems
Se pravi zaenkrat hude tehnične težave :(
Patch incoming.
ahac ::
Kakor sem bral na redditu, naj bi na Steamu bil tisti prvi patch že vključen v igro (ker so že patchal preden se je dal preloadat).
Pa menda imajo tudi na PS4 nekateri težave, drugim pa dela OK (na enaki konzoli). 8-O
Na enaki konzoli?
Kako je to mogoče?
A slučajno igra kaj preverja HW revision?
ahac ::
No idea. Jaz sem tudi mislil, da je prednost konzol to, da so vse enake... :P;)
Mogoče je fora v kakšnem PS4 software update?
V vsakem primeru sem vesel, da nisem preorderal. :P
Ja pred kratkim je prišla ven malo močnejša Ps4 konzola mogoče na teh dela dobro pa na starejših malo šteka?
On September 7, 2016, Sony unveiled two hardware revisions of PlayStation 4; a slim build of the console, and a "Pro" version with an upgraded GPU and higher CPU clock rate to support 4K gameplay on supported titles. All models, including the original sold in 2013, support HDR10 high-dynamic-range color.
Ampak, če igra slučajno preverja HW revision potlej se mora temu tudi SW prilagoditi?
  • spremenil: D3m ()
ahac ::
Tole sem gledal: https://www.reddit.com/r/dishonored/com...
¯\_(ツ)_/¯
Sicer, ja... igre, ki podpirajo Pro morajo podpirat tudi navadni PS4 in prilagodit grafične nastavitve glede na hardware. To, da bi na starejših opazno štekalo, se (v teoriji) ne bi smelo dogajat.
Potreben bo očitno še en patch :D
  • spremenil: D3m ()
RC14 ::
Mene samo zanima, kdaj bomo doživeli takšno grafiko v igrah, kot jo prikazujejo v raznih demotih, "new engine" next gen.....for games......
Po mojem še vsaj nekaj let ne.... Sploh , ko govorimo o izgledu obrazov ljudi-likov v igrah, razne mimike, naravni izgled las...... vse to v vseh igrah delujejo prav "plastični in umetni z premalo poudarka na realnem izgledu.
:4770K@4.5GHz @ BeQuiet!Dark Rock Pro2; MSI Z87 GD65 Gaming; 16GB RAM:
::GTX 1060 6GB; SSD Samsung 840 EVO 250GB; SEAGATE 3TB+3TB+1TB; LG 27"IPS::
:::: XFX 850W Black Edition; X-Fi Titanium; Fractal Design ARC R2 ::::
  • spremenil: RC14 ()
ahac ::
Dishonored 2 performance problems: Game sets CPU priority to low after every loading screen :))
http://www.neogaf.com/forum/showpost.ph...
To pa je šparancija. :))
bambam20 ::
RC14 je izjavil:
Men se zdi, da je v The Order 1886 grafično zelo na visokem nivoju, tudi mimika.
Jaz ne vem ali igre ne sprobajo predno jo dajo ven?
Arkane Studios has noted on the Bethesda website that it is working on all current issues. In the meantime, it has offered suggestions to help better the playing experience.
General recommendations
Avoid using Alt-Tab when playing. Relaunch the game if you see performance dropping after using Alt-tab.
Avoid having background applications running in addition to the game.
Video Settings
If you have performance issues, try lowering the resolution.
Use 1440p resolution only if you have a very high-end GPU ( GTX 1070/1080 or equivalent)
Keep the V-Sync activated, especially if you have large framerate fluctuations.
If you have framerate under 30 fps, adjust the "Adaptive Resolution" between minimum (50%) and default value (75%).
Advanced Settings
Use the "Auto" presets: this should adjust your visual settings without impacting your framerate.
If you still have performance issues with "Auto" presets:
Try deactivating the "TXAA Anti-Aliasing"
Try lowering the texture details
  • spremenil: oo7 ()
yoco ::
A je to console port, da je še ena igra ne preverjena za PC?
V obeh primerih šepa. Napaka je na strani Bethesda.
ahac ::
Menda ni port, ampak so razvijal istočasno s konzolami.
Mogoče težave izhajajo tudi iz tega, da so šli iz Unreal Engine (Dishonored 1) na Void Engine (na osnovi idTech + DX11).
Verjetno je bila to čisto poslovna odločitev šefov v ZeniMaxu (lastniki idja, Bethesde in Arkane)...;((
2 3
Dark Souls 3 (strani: 1 2 3 4 … 7 8 9 10 )
Oddelek: Igre
468121148 (3689) oo7
Project Cars (strani: 1 2 3 4 5 6 )
Oddelek: Igre
27153510 (15712) oo7
Age of empires 3 (strani: 1 2 )
Oddelek: Igre
679437 (3243) oo7
Igre 2009 (strani: 1 2 3 4 5 6 7 8 )
Oddelek: Igre
36233279 (23248) Berserker
Valve & STEAM & On-Line gaming (strani: 1 2 )
Oddelek: Igre
7110020 (8442) Tilen
