Forum » Loža » Revolut - trgovanje z delnicami in Brexit
forest_guy ::
Pozdravljeni,
pred kratkim sem začel trgovati z delnicami v aplikaciji Revolut, v mobilni aplikaciji sem sedaj prejel spodnje obvestilo:
"As a consequence of the UK leaving the EU, starting January 1st, 2021, Revolut Trading Ltd (RTL) is no longer able to passport its services across the EEA as an appointed representative of its UK principal firm. RTL is no longer authorised to advertise, promote or otherwise provede the trading service in your country under EU law.
By checking the circle below you confirm that you with to continue trading with RTL and that
- You are trading with RTL at your own initiative
- You are trading with RTL on the basis of an ongoing relationship
- You have been made aware that the trading service provided by RTL is not provided by an investment entity authorised in the EU
- You do not have the benefit of any EU regulatory protections or investor compensation schemes by trading with RTL
Please note, you may be required to enter into a new agreement with RTL in accordance with the application laws in your country. We will notify you in that event."
Kaj to torej pomeni za moj trgovalni račun po 1.1.2021? Bom še lahko trgoval ali je bolje sredstva iz trgovalenga računa prenesti na osnovni račun? Se bodo morda cene spremenile?
Hvala za odgovore :)
w0mbat ::
ja boš lahko , samo boš verjetno pod IRSKO.. recimo na payoneer so isto nakladali nič se mi ni spremenilo samo so šli na Ireland, vse poteka naprej normalno.
Spiky28 ::
Sej ti vse lepo piše, če ne razumeš potem bolje, da se ne ukvarjaš s takimi zadevami.
Torej: Če se strinjaš, boš še naprej lahko trejdal preko RTL, ampak se moraš zadevati, da RTL entity ni več pod EU zakonodajo in regulacijo, ki bi te ščitila kot uporabnika. Zadnja alineja je najbolj pomembna. Enostavno povedano, če Revolut propade (gre v stečaj, ali naredijo kakšno finančno prevaro), ti niso dolžni vrniti denarja oziroma equityja, ki ga imaš pri njih. (https://ec.europa.eu/info/business-econ.... Če se mene vpraša, bi šel stran, ampak vsak o svojem denarju odloča. p.s. Lahko da te potem vseeno ščiti kak zakon, ki je veljaven znotraj UK, ampak za to...do-your-own-research.
- spremenil: Spiky28 ()
janezvalva ::
jest poznam enga kekca, kateri trguje na RTL, pa sploh ni prijavil računa na FURS.
kakšne šanse so da ga dobijo?
grikos ::
Sredstva bodo varovana po UK zakonodaji, tako da brez skrbi:
Regulatory Protection: After Brexit, although your investments will no longer be protected under EU regulation they will be protected under UK regulation as RTL will continue to operate as an appointed representative of its UK principal firm which is authorised and regulated by the FCA. This level of protection will at least be equal to the strict requirements under EU regulation
Prijavi se na CAKE defi in zasluži 30 $ kriptovalute.
https://app.cakedefi.com/referral code: 772231
- spremenil: grikos ()
mr_chai ::
janezvalva je izjavil:
nične
RoccoC ::
nične
Hahaha...iz prve roke lahko povem da temu ni tako. Imajo izmenjave, iz Anglije še posebej. Po parih letih sigurno prideš na vrsto. Dvomim da bo po Brexitu kaj drugače.
svetidej ::
V prvi polovici 2021 gredo Revolutovi trgovalni računi iz Anglije na Irsko.
So pred tem, da dobijo licenco na Irskem.
https://denar.svetidej.com/
w0mbat ::
| » | Izbira on-line brokerja (strani: 1 2 3 4 … 14 15 16 17 )Oddelek: Loža | 280366 (10755) | Compare |
| » | Trading212 (strani: 1 2 3 4 5 6 )Oddelek: Loža | 87870 (7495) | 133780 |
| » | Degiro online broker (in alternative) - ima kdo izkušnje? (strani: 1 2 3 4 … 9 10 11 12 )Oddelek: Loža | 192314 (37564) | pirx |
