Sandra MAX3
Sandra MAX3
kuglvinkl ::
download.
SiSoftware Sandra Standard Information
* 58 total Information, Benchmarking, Listing & Testing/Diagnostic Modules.
* Multi-threaded Wizards for all tasks (e.g. Create various reports).
* Multi-processor designed (multi-threaded) benchmarks - up to 64 CPUs.
* Full 32-bit code; uses Windows 2000/XP extensions (32-bit Sandra).
* Native Windows NT4/2000/XP format (UNICODE Sandra).
* Full 64-bit code; uses Windows .Net extensions (64-bit Sandra).
* Still get information on the 16-bit subsystem (ANSI Sandra).
* Plug-and-Play support.
* DMI/SMBIOS support.
* Supports AGP, PCI, PCI64/66, VESA (ANSI Sandra), EISA (ANSI Sandra), MCA (ANSI Sandra), PCMCIA, CardBus.
* DirectX (DirectDraw, Direct 3D, DSound, DMusic, DPlay, DInput), OpenGL support and information.
* Detects new CPUs including the Intel Pentium III/4, Celeron, Xeon III/4; VIA C3; AMD Athlon 4/XP/MP, Duron XP/MP (32-bit Sandra).
* Detects new CPUs including the Intel Itanium, McKinley (64-bit Sandra).
* Detects and uses MMX (Enhanced), 3DNow! (Enhanced/Professional), SSE/SSE2 instruction sets (32-bit Sandra).
* Advanced settings information on modern CPUs.
* Detects Intel, AMD, ALi, SiS, VIA and all other chipsets on the market.
* Network & Internet information.
* Can save, print, fax, e-mail, post and upload a report.
* Can export a SMS report for Microsoft SMS management system.
* Can export a RPT (hierarchical) report that can be imported into most programs.
* Can export a XML report for electronic data interchange.
* Can export a HTML report directly (with CSS support) or display one dynamically from the XML using XSL & CSS.
* Can upload a report to a FTP/HTTP server and account.
* Can insert a report into any ADO, OLEDB or ODBC supported database with the correct schema.
* Looks better in HiColour/TrueColour (16/24/32-bit) modes.
New Features:
* Multi-language combined installer (English, French, Nederland, Russian) with more languages to follow.
* Support for AMD Opteron multi-processor architecture (AMD Athlon 64/Opteron CPUs; AMD 8131, SiS 755/760, VIA K8T400/M chipsets; AMD 8111, SiS 963/S/L south bridges; NUMA up to 32/64 nodes; ACPI 2.0; SMBus 2.0)
* Support for Intel Pentium 4 400MHz architecture (Intel P4 2.4-3.2GHz CPUs;Intel 875P, 865P/PE/G chipsets; ICH5/5R south bridges)
* Support for Intel Pentium M mobile architecture (Intel PM 1.3-1.6GHz CPUs; Intel 855PM, 855GM chipsets)
* Support for SiS embedded architecture (SiS 55x SOC)
* Support for Intel Itanium 2 architecture (Intel E8870 chipset; NUMA up to 64 nodes; ACPI 2.0)
* Support for USB 2.0 HiSpeed USB controllers (enhanced EHCI; USB hubs)
* Support for Windows 64-bit XP/2003 IA64 and AMD64 in the 32-bit version through dedicated device drivers ensuring full functionality even under WOW64. The installer seamlessly sets up the correct device driver for the target OS.
* Support for WinSock ports (TCP & UDP) & process bound listing.
Ranljivost v Intel procesorjih (strani: 1 2 3 4 5 6 7 8 )
38373656 (21587) Horzen
K8: Athlon64, AthlonFX, Opteron (strani: 1 2 3 4 … 13 14 15 16 )
76752494 (30363) RC14
Procesor AMD 2500+ Barton
142102 (1917) jest10
Program, ki pove katero matično ploščo imam?
Oddelek: Programska oprema
144171 (4073) Han
Nujn rabim help ( BX & Tualtin)
242090 (1813) Dalmatinc
