Program, ki pove katero matično ploščo imam?
_Xavier_ ::
mam en problem s plato in ta je da nimam pojma kero plato sploh mam, zato me zanima če je kkšn programček k bi mi povedu saj kkšno uporabno
informacijo da bi lohk najdu kej na netu od plate.
ali3n ::
:D
- lahko pogledaš na plato (skoraj vedno piše)
pogledaš s programi:
- SiSoft Sandra
- mislim da je Aida
- "Rozi vidm." "S psom!"
_Xavier_ ::
na plati nč ne piše zato pa sprašujem sandra mi pa ne pove kej preveč.
ali3n ::
Meni Sandra "izpljune" tole (več kot dovolj) - na "motherboard information":
SiSoftware Sandra
System
Manufacturer : ECS
Model : P6S5AT
Version : 1.0
Serial Number : 00000000
System Chassis
Manufacturer : Uknown Chassis Manufacture
Type : Desktop
Can be locked : No
Version : Version 1.00
Serial Number : 123456890
Asset Tag : 0123ABC
Mainboard
Manufacturer : ECS
MP Support : No
Model : P6S5AT
Version : 1.0
Memory Controller
Error Detection Method : ECC
Error Correction Capability : 1-bit
Supported/Current Memory Interleave : 1-way / 1-way
Number of Memory Slots : 4
Maximum Installable Memory : 512MB
Maximum Module Size : 128MB
Supported STD/FPM/(B)EDO Speeds : 70ns, 60ns
Supported Memory Types : STD, FPM, EDO, Parity, ECC, SIMM
Supported Memory Voltages : +3.3V
Physical/BIOS Memory Banks
ROW-0 : Disabled
ROW-1 : Disabled
ROW-2 : Disabled
ROW-3 : Disabled
Chipset 1
Model : Silicon Integrated Systems (SiS) SiS635 CPU to PCI Bridge
Bus(es) : ISA AGP PCI USB i2c/SMBus
Front Side Bus Speed : 1x 133MHz (133MHz data rate)
Maximum FSB Speed / Max Memory Speed : 1x 133MHz / 2x 133MHz
Width : 64-bit
IO Queue Depth : 8 request(s)
Priority Master Queue Depth : 7 request(s)
Logical/Chipset 1 Memory Banks
Bank 0 : 512MB DDR-SDRAM 2.0-3-3-6CL
Speed : 2x 133MHz (266MHz data rate)
Multiplier : 1/1x
Width : 64-bit
Refresh Rate : 7.80µs
Power Save Mode : No
Fixed Hole Present : No
Memory Module(s)
Memory Module 1 : Nanya M2U51264DS8HB3G-6K 512MB 16x(32Mx8) DDR-SDRAM PC2700U-2533-700 (CL2.5 up to 167MHz) (CL2 up to 133MHz)
Environment Monitor 1
Model : ITE IT8705/12 ISA
Mainboard Specific Support : No
Temperature Sensor(s)
Board Temperature : 47.0°C / 116.6°F td
CPU Temperature : 73.0°C / 163.4°F
Power / Aux Temperature : 61.0°C / 141.8°F
Cooling Device(s)
Auto Fan Speed Control : No
Chassis Fan Speed : 2021rpm
CPU Fan Speed : 1592rpm
Voltage Sensor(s)
CPU Voltage : 1.47V
Aux Voltage : 2.48V
+3.3V Voltage : 3.34V
+5V Voltage : 5.00V
+12V Voltage : 12.04V
-12V Voltage : 1.05V
-5V Voltage : -5.41V
Standby Voltage : 5.16V
Battery Voltage : 3.50V
AGP Bus(es) on Hub 1
Version : 2.00
Speed : 4x
Fast-Writes Enabled : No
Side Band Enabled : Yes
Aperture Size : 64MB
PCI Bus(es) on Hub 1
Version : 2.10
Number of Bridges : 1
PCI Bus 0 : PCI (1x PCIClk)
LPC Hub Controller 1
Model : Silicon Integrated Systems (SiS) SiS PCI to ISA Bridge (LPC Bridge)
ACPI Power Management Enabled : Yes
Random Number Generator Enabled : No
Speed : 7MHz
USB Controller 1
Model : Silicon Integrated Systems (SiS) SiS5597/8 Universal Serial Bus Controller
Version : 1.00
Interface : OHCI
Channels : 3
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps)
Legacy Emulation Enabled : No
USB Controller 2
Version : 1.00
Interface : OHCI
Channels : 3
USB Controller 3
Model : OPTi Inc 82C861/2/3 FireLink USB Controller
Version : 1.00
Interface : OHCI
Channels : 2
System SMBus Controller 1
Model : SiS 961 Ext SMBus
Slave Device Enabled : No
Speed : 56kHz
Expansion Slot(s)
PCI1 (1h) : PCI 32-bit +3.3V Shared PME Full-Length Available (Silicon Integrated Systems (SiS) 5591/2 Virtual PCI to PCI Bridge)
PCI2 (2h) : PCI 32-bit +3.3V Shared PME Full-Length Used (Silicon Integrated Systems (SiS) SiS PCI to ISA Bridge (LPC Bridge))
Performance Tips
Notice 224 : SMBIOS/DMI information may be inaccurate.
Warning 2508 : All memory slots are full. Upgrading the memory may be difficult or expensive.
Tip 2546 : Large memory modules should be ECC/Parity.
Warning 2545 : Large memory modules should be Registered/Buffered.
Warning 2518 : Mainboard temperature is too high.
Warning 2519 : One of the system fans has failed or is spinning too slowly.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
_Xavier_ ::
kero sandro pa maš
ali3n ::
2004
_Xavier_ ::
jest tud pa mi nč kej tazga ne napiše. a to greš pod mainboard information
Lith ::
tudi tale ::: AIDA32 ::: je zelo spodoben program, pa še 3MB je vse skupaj za snet in tudi ::: na koncu piše FREEWARE :::
¤ black holes rule; I like the speed, speed kills ¤
_Xavier_ ::
jest mam tud to sam mi ne napiše nč tazga kokr teb. a to greš gledat pod mainboard information. pa kako si kopiru tist use k si napisu
_Xavier_ ::
tale aida je hud program sam je brezveze ker mi ne napiše ime plate tm use piše neznano.kr neki
chucki ::
ali3n teb se pa ceu comp. fulllll greje 8-O
ali3n ::
:D a ti verjameš vse kar prebereš?
sam eni se pa res obremenjujejo po nepotrebnem, z brezveznimi stvarmi :) :)
chucki ::
Js se ne sekiram zarad mene mejte 500C pa se ne sekiram,jst se vam lahko sm :D
Han ::
Poskusi srečo s CPU-Z.
Vprasanje....
81824 (1689) AnWar
Procesor AMD 2500+ Barton
142119 (1934) jest10
disk?
281625 (1373) maticm
BIOS upgrade
102058 (1888) Dead_Eye
Procesor ko žerjavica?
112080 (1846) T0RN4D0
