Impresivni mobilni procesor Apple A10
trnvpeti ::
A10 na nivoju desktop procesorja i3 6100 po gb3 single/multi
desktop i3 6100 skylake 2c/4 3.7Ghz 3700/8000
A10(iphone 7) , 2c, 2.37Ghz 3500/6500
iphone 6 A9 2500/4400
iphone 5s 1400/2500
Samsung note 7
exynos 8890(note 7) 2300/8100
S821/823 (note7) 2300/5400
Xiaomi
S625(redmi 4) 930/4700
S650(redminote3) 1500/3700
S616(redmi3 pro) 650/2900
buttplugs ::
To nikakakor ne drzi,, ampak OK, naj ti bo. Je pod mano razjasnjeno zakaj temu tako.
  • spremenilo: buttplugs ()
amacar ::
Malo visoki rezultati so pri note7 multi.
Torej je A10 v multi se vedno slabsi od exynos v s7.
trnvpeti ::
exynos 8 core(4core moongose + 4 a53)
a10 pa 2 core
mtk bo pa tudi kmalu imel varcne a35 + a73 na 2.8Ghz
amacar ::
Teh 8 corov ne more delati hkrati ne? Bo apple moral razmisliti tudi o vec corih, ampak potem bodo pojedli tekmece :)
buttplugs ::
Nope, delajo v clustrih. Tako kot recimo novi MTK Helio X20/25, kjer so trije clustri.
seveda je lahko zaposlenih vseh 8 corob hkrati ;)
technolog ::
Cak, en core 3500, 8 corov pa samo 6500? Moral bi bit cirka 8-kratnik, drugace nima smisla.
Drugic, kaj je to za en benchmark?
amacar ::
Geekbench3, pri a10 (ce bo tak, glede na to, da se ni uradno izdan) sta dva cora 6500.
buttplugs ::
iloveboobz je izjavil:
Pardon, sem pozabil, da ne furajo vsi little.BIG šita.
Qushaak ::
http://www.anandtech.com/show/9518/the-...
Še vedno precej aktualen test, ki precej razjasnuje to preblematiko v real-world aplikacijah.
trnvpeti ::
A10X (verjetno naslednji ipadi)
4236 v single in 6588 v multi
to je pa zlo sab scaling al pa geekbench mal zavaja ;)
OK, so you are still wrong on this point IPC != performance. Scaling up perf isn't free. It can be done, obviously (since Intel has done so, and they hardly have a monopoly on good design). But there's no guarantee that Apple can get to high frequencies without losing some IPC.
I know several CPU designers at Apple, and they will all tell you that they aren't targeting anything close to Intel performance. Their cores simply cannot scale to 4GHz. They also have no way to use 10A/core, which Intel certainly can. In fact, I bet Intel can probably draw around 15A/core for some workloads.
That is directly from the people who design the CPUs. If you think you know more than they do, let me know.
Samsung predstavil Galaxy S9 in S9+ (strani: 1 2 )
Oddelek: Novice / Android
5126808 (22169) xda develope
Intelovi procesorji Skylake (strani: 1 2 3 4 … 12 13 14 15 )
736140809 (71965) D3m
Samsung predstavil Galaxy Note8 (strani: 1 2 )
9836415 (32407) Ishmael
Intelova prva procesorja iz družine Skylake (strani: 1 2 3 )
Oddelek: Novice / Procesorji
14968143 (34443) GenZNPC
