steam na linux
steam na linux
Zvezdica27 ::
lp,
torej, ena igra je,ki jo moram probat.
TOrej, imam linux.
Steam sem dal dol, je na sistemu, zdaj najbrž dam podatke o kreditni itd (nisem še). Kar me zanima je, ker je igra multiplatform, ali lahko to potem igram na večih kompih ali samona enem (se logiram in igram kjer čem). Ali potem dobim tudi igro na androidu, dugeih sistemih (recimo na win na drugem kompu pri frendu, mac pri bratu)?
Ali igro potegne dol lokalno, torej "old school install" ali je vse preko serverja preko neta.
Alhko igram če sem offline?
SAmo par pojasnil kako otčno to dela. Hvala.
zz
Steam račun je vedno vezan na eno osebo. Obstaja sicer tisti family sharing ali kaj je že, a vseeno ne more naenkrat eno igrat več kot ena oseba.
Drugo pa je, če je igra DRM Free* in načeloma je dovoljeno, da znotraj istega gospodinjstva poganjaš na več računalnikih.
* A to ne Steamu ne boš videl.
Recimo pravila na GOG.com:
GOG.com @ Wikipedia
http://www.gog.com/support/website_help...
9. Can I enjoy my purchases both on my laptop and desktop computer at home?
Yes. We do not limit the number of installations or reinstallations, as long as you install your purchased games on computers in your household. So yeah, if you've got a render-farm in the basement, you might actually break the world record for the number of legal Witcher installations in one household. However, if you think about installing your game on a friend's machine or sharing it with others then please don't do it, okay?
The same principle applies to movies - you're free to watch them anywhere you want, with anyone you want, as long as you don't share them with people who haven't purchased them.
  • spremenil: opeter ()
Highlag ::
Dela isto kot na windowsih. Le izbira aplikacij je precej oskubljena. Če imaš dual boot ali kaj podobnega imaš lahko aplikacijo nameščeno povsod. Edino prijavljat se boš moral(a) ločeno.
Lahko igraš tudi offline, vsaj enkrat pa moraš prej aplikacijo zagnat v online načinu. (Da se aktivira)
Žal (vse)aplikacije ne omogočajo sinhroniziranja crosplatform. Torej če shraniš pod linuxom se ne moreš prijavit v windows okolje in nadaljevat igranje od tam naprej.
ahac ::
Na Androidu ne, drugje (Windows & Mac) pa tako kot so že napisal.
Za katero igro pa gre?
  • spremenil: ahac ()
Zvezdica27 ::
another world ;)
nal sem že star, pa je treba mlade vprašat
zz
ooo...
ooo...
orgazem. Me so happy!
Gog.com - starejšni naslovi, DRM free (strani: 1 2 3 4 … 7 8 9 10 )
Oddelek: Igre
494137727 (1809) bojsi
Igre: podarim kodo (strani: 1 2 3 4 … 40 41 42 43 )
Oddelek: Igre
2146578074 (5890) cyberlev
Brezplačne igre (giveaways) (strani: 1 2 3 4 … 23 24 25 26 )
Oddelek: Igre
1265377928 (8907) acookook
Manj znane igre (strani: 1 2 3 4 )
Oddelek: Igre
15049375 (22115) D3m
The Witcher 2: Assassins Of Kings (strani: 1 2 3 4 5 6 7 8 9 )
Oddelek: Igre
401113711 (82927) yoco
