Forum » Znanost in tehnologija » [DARPA homing bullets] tehnologija za DARPA vodenimi naboji za ostrostrelske puške?
Andruxa ::
Prejšnja tehnologija od Sandia National Laboratories vsebuje zakrilca na krogli, ki vodijo kroglo do z laserjem označene tarče.
Nova tehnologija od Darpe teh zakrilc očitno nima:
wiki
guns article
kaj bi lahko bila tehnologija za DARPA vodenimi kroglami?
The DARPA EXACTO program uses different methods than Sandia's guided round. It relies on remote-guidance tied to the optics, which may be more reliable than Sandia's guidance method of needing to paint the target with a laser for their projectile to follow, which can be detected, diffused, or blocked. EXACTO models on existing .50 BMG ammunition and rifles instead of needing new hardware, which the Sandia guided dart would need. Although EXACTO is specifically focused on military applications, Sandia is seeking to make commercial sales of their guided sniper projectile.[2]
DARPA test fired the EXACTO in early 2014 and released video of demonstrations in July 2014. Exact technologies used in the bullets were not revealed, but the EXACTO uses a real-time optical guidance system with no visible fins or other steering mechanism on bullet illustrations.
wiki
guns article
Lp, A
Barbarpapa2 ::
Pozdrav
Sedaj lahko samo ugibamo. Predvidevam, da gre za neke vrste "lopute" (podobne zračnim zavoram na nekaterih letalih), ki se bočno odpirajo iz istrelka. Pa tudi wikipedia članek o .50 BMG municiji omenja "guiding vanes" pri odstavku o EXACTO sistemu....
.50 BMG @ Wikipedia
Jože
.50 BMG @ Wikipedia
Jože
- spremenil: Barbarpapa2 ()
Verjetno ni mišljeno da bo sprememba v letu tistega kilometra in pol za meter ali dva. Bolj je tu mišljeno kao malo levo malo desno, pač namesto levega učesa pač med učmi. Za ta namen je dovolj, da se malo spremeni oblika izstrekla v letu v oblik deformacije tistih belih obročev. Nikakor pa ne vidim smisla, da bi nek snajpresi, v letu spreminjl tarčo.
Cash ::
Recimo, da se tista 2 obročka vrtita in sta excentrična oz. vsak je na eni strani odebeljen. Sicer to ni videti, ker je potrebno izjemno malo excentričnosti, drugače bi kugla preveč zavila. Ko hočemo, da gre izstrelek naravnost, sta obročka obrnjena tako, da ima vsak odebeljeni del nasprotno od drugega. Če želimo, da zavije krogla na desno, se obroček obrne z odebeljenim delom na desno, da je upor zraka samo na desni strani.
Tretji obroček je excentričen oz. odebeljen na obeh straneh, da ima izstrelek stabilnost, hahahhaa
- spremenil: Cash ()
| ! | Novosti na področju zračnega hlajenja (strani: 1 2 3 4 5 6 7 8 9 )Oddelek: Hlajenje in modifikacije | 355526 (39029) | yayo |
| » | Razvita atomska ura na čipuOddelek: Novice / Znanost in tehnologija | 14302 (10941) | Okapi |
| » | Darpa namerava razviti nove načine gašenja požarov (strani: 1 2 )Oddelek: Novice / Znanost in tehnologija | 10731 (7695) | globoko grlo |
| » | Samo človek lahko... (DARPA Urban Challenge) (strani: 1 2 3 4 )Oddelek: Znanost in tehnologija | 14898 (11419) | snow |
| » | Compaq pripravlja najmočnejši računalnik na svetuOddelek: Novice / --Nerazporejeno-- | 2575 (2575) | Space Surfer |
