DAB stanje pri nas
DAB stanje pri nas
81 / 84
andimik ::
Yes i was in contact with the technician from Kronehit. It's a timing problem in a hardware, but was not easy to find (on both, radio station side and operator side) and fix it for the moment.
You were right that after returning back at 9:21 the slides and the DL text were hanging. I've immediately reported it as I was in the car by chance.
It might occur in the next weeks again until they replace the hardware.
Note: it seems that only the Mux III StBK was affected, in other regions (including Vienna) there were less or even no issues on Super 80 (and some others).
Radio programs with a software encoder (like VM1) were not affected at all.
  • spremenil: andimik ()
Spc ::
andimik je izjavil:
Yes i also saw this.
Only Mux III StBK had errors.
gb39 ::
Drugače je naslov teme "DAB stanje pri nas", razen če smo spet nazaj pod Avstrijo (nimam nič proti)
Saj je DAB pri nas. Pride preko meje na določenih območjih.
Spc ::
starfotr je izjavil:
Tako ja, "pri nas" v Mariboru dobimo Hrvate in Avstrijce.
Oboje deluje zelo dobro, tudi v zaprtih prostorih jih lahko poslušamo.
Spc ::
Super 80's je spet down.
Ni zvoka in ni seznama kaj se predvaja:
Trenutni radiji, ki ne delajo so (not working):
- Super 80s
- Rot Weiss Rot
Zanimivo ko ima DAB+ težave, sploh ni zvoka.
Pri FM-u recimo vmes malo šumi pri DABu pa radijska postaja obstaja, vse najde in deluje, zvoka pa ni.
  • spremenil: Spc ()
gb39 ::
Spc je izjavil:
Ker je digitalno 1 ali 0. Torej dela ali ne dela.
mancini ::
gb39 je izjavil:
Spc je izjavil:
Tolko postov ima v tej temi, ne pozna pa osnove DAB :D
ko ni signala je pač tišina, kar je precej boljše od šumenja, precej manj nadležno
andimik ::
gb39 ::
Kum, Krim, Ljubljana Šance, Kočevje, Mozirje,...
duh1 ::
Da bo tako dolgo trajal izpad je pa kar zanimivo (Radio 1 90a, Radio Hit, Radio Energija, Radio 1 SLO hiti, Klasik radio...)
  • spremenilo: duh1 ()
gb39 ::
Majo baje kr težave. Smo pa vsaj dobili potrditev, s kod izvira radio Energija...
gb39 ::
Sem slučajno odpiral spletno stran radio.si. Samo 8 programov je na voljo.
duh1 ::
Ja. So samo postaje od Media24. Od Infoneta pa jih ni.
Kolikor sem preizkusil preko spleta ne deluje nobena postaja od Infoneta.
globoko grlo ::
Kaj se zdej dogaja?
Radio 1 slo hiti ne dela. V cem je problem?
ales74 ::
Problem je tole
https://www.delo.si/novice/slovenija/ra...
Od takrat dalje imajo tehnične težave.
Strim za Radio 1 trenutno dela
https://live.radio.si/Radio1
Preko istega linka dela tudi strim za Fantasy in Toti.
Bo treba počakat da porihtajo.
Uživajte, dokler lahko!
cekr ::
Zadnje čase tako hitro uporabijo besede "kibernetski napad".
V resnici se jim je pa samo razsul strežnik. Se zgodi. Še raje pa, če nimajo nikogar, da bi pazil nanj.
rogerg ::
Ne vem, ali je kaj povezano, ker ni DAB. Ali zaradi tega ne delajo določene postaje FM preko interneta? Npr. Rock1radio (tudi uradna stran je nedosegljiva), pa še kakšna druga radijska postaja. Določene (meni bolj nezanime) pa delujejo.
Hvala za odgovor in pojasnilo.
cekr ::
Po znaku vidim, da je zadeva od Odlazka. Tako da je povezano s problemom.
Alexius Heristalski ::
Nespoti kot Proplus.
ales74 ::
gb39 je izjavil:
In od kod izvira? Lastnik licence je firma Radio Obala d.o.o. Lastnik te firme je pa Dalibor Kosmina
https://www.companywall.si/podjetje/rad...
Imaš kakšne informacije o tej osebi?
Imam vprašanje glede Rock Maribor
A ni ta postaja bila ukinjena, namesto nje pa v MB sedaj oddaja Radio 1 Rock?
Zakaj je pol ta postaja 25.8.2025 dobila novo dovoljenje, lastnik je pa firma D PRODUKCIJA d.o.o.?
gb39 ::
Radio 1 Rock je radijska mreža, ki jo sestavljata 2 postaji, Rock FM in Rock Maribor.
Glede Energije, že pred časom smo se pogovarjali v tej skupini, da je glas, ki ga slišimo vsake toliko na tem radiu (glas pove "Radio Energija) zelo podoben kot ga ima Jean Frbežar. Očitno gre za njegov glas.
gb39 ::
Update
Radio.si je nazaj v popolni zasedbi, ponovno delujejo tudi spletne strani.
Škoda.
duh1 ::
gb39 je izjavil:
Update
Ja, ampak na radio.si jih ogromno ne deluje (Radio 1 80-a, Radio 1 90-a, Radio 1 Rock, Radio 1 SLO Hiti, Antena, Toti, Hit, Fantasy,...)
Radio 1 90-a, Radio 1 SLO hiti, Radio Energija na DAB-u še vedno tišina.
Spc ::
duh1 je izjavil:
Tudi na pohorju je tišina.
duh1 ::
V sredo, 18.3. sta že delovala 1 90-a in 1 SLO hiti, Energija pa še vedno ne deluje (danes teče 19. dan tišine).
Tu se vidi, kako (ne)pomembna je odgovornim Energija. Cilj je bil, da pridejo do lastništva Caprisa in Hita. To jim je preko Radio Obala d.o.o. uspelo in Energija jim je sedaj samo en nebodigatreba, ki jo je potrebno držati pri življenju, da ne bi preveč očitno izpadlo, zakaj so jo sploh lansirali. Radio nima svoje spletne strani, nimajo streama, še več, tudi na DAB-u ne oddajajo nič že skoraj 3 tedne.
gb39 ::
Meni je bolj zaskrbljujoče to, da številni programi, ki so na zadnjem razpisu dobili dovoljenje, še vedno ne oddajajo. Eno leto po objavi. Energija je program kategorije "samo da je zraven", tako kot R1 90-a, Aktual Romantika, Veseljak Zlati zvoki,...
duh1 ::
Glede na to, da imamo v Sloveniji 2 veliki korporaciji (Media24/Infonet in Next Media), si to lahko privoščijo. Se prijavijo na razpis z "malo morje" postajami, začne pa oddajati 1, 2 ali mogoče 3. Kot da gre za neko ziheraštvo, saj je očitno, da nimajo namena oddajati z vsemi programi, ki kandidirajo. Smešno je, da na naslednjem razpisu spet brez problema kandidirajo z ogromno postajami. Pač, to je realnost slovenskega DAB-a.
Sicer pa novi programi niso ne vem kakšna obogatitev ponudbe. Radio Hit, Aktual Romantika, Radio 1 90-a, Radio 1 SLO hiti, Veseljak Zlati zvoki, Energija, Center X, Juboks ipd. so izključno glasbene playliste, ki se predvajajo 24/7. Tudi Enter ne zaostaja kaj dosti (vnaprej posnet "voden" program, ki je tako enoličen, da te mine poslušati). Playlista od Entra je tudi ista že ohoho časa. Škoda res, na Enter sem polagal upe, da bo končno en radio, ki ga bom lahko vsak dan poslušal na šihtu, pa v avtu...
Jaz na radiu poslušam večinoma rock radio in prek dab se sliši super.
  • spremenil: mtosev ()
globoko grlo ::
A kdo ve zakaj je radio 1 slo hiti glih ene 2/3 tišji kot recimo Radio Frajer, se VAL 202 je glasnejsi :)
gb39 ::
duh1 je izjavil:
Ali pa se jim ne splača. Zeleni val je prenehal z oddajanjem, Capris in Enter sta znižala kvaliteto,...
duh1 ::
Pomoje ni to, da se jim ne splača. Vsaj velikim. Ne vem zakaj je naprimer Radio Antena d.o.o. kandidiral s tremi programi (Antena Promet 24, Radio Antena Top 100, Radio Antena Top 40), začel pa je oddajati samo Radio Antena Top 100, ki je v praksi Toti DAB (se pravi dejansko ne gre za nov program)
Next Media d.o.o. (A1 Radio, Hitradio SI) ni začel z oddajanjem nobenega.
Radio 2 d.o.o. (Radio 2 Popevke) tudi ne.
Rock Radio d.o.o. (Rock 2, Rock 3, Rock 6) samo program Rock 3, ki je v praksi podcast24.
Radio Center d.o.o. (Center 2, Center 3, Center 4) je tudi v praksi začel z oddajanjem vseh (Center X, Frajer, Juboks).
RGL d.o.o. (Radio Veseljak Znanje, Radio Aktual Znanje) je tudi v praksi začel z oddajanjem obeh (Radio Veseljak Zlati zvoki, Aktual Romantika)
Radio Pro 1 d.o.o. (Radio 3, Radio 1 90-a) je lansiral samo slednjega.
Se pravi iz prejšnjega DAB razpisa programi, ki v skoraj enem letu od pridobitve pravic niso začeli oddajati:
1. A1 Radio
2. Hitradio SI
3. Radio 2 Popevke
4. Rock 2
5. Rock 6
6. Radio 3
7. Antena Promet 24
8. Radio Antena Top 40
Če potegnemo črto: od 16 programov, ki so dobili pravico oddajanja, jih polovica ni začela oddajati.
duh1 ::
https://dab.si/javni-razpis-za-programe...
16.12.2025 je bilo javno odpiranje ponudb. 14 ponudb za R5 in 6 ponudb za R3. Več kot 3 mesece kasneje še vedno ne vemo nič.
deskstar ::
mtosev je izjavil:
Na boljših zvočnikih poslušaj iste pesmi iz DAB-a in CDja. Ugotovil boš, da ima DAB zvok pojačan bas in visoke tone, potem je pa še obdelan s procesorjem, da bi se ustvaril vtis boljšega zvoka in zakrile posledice prevelike kompresije. FM ima avdiofilsko gledano boljšo zvočno transparentnost navkljub omejenosti na 15 kHz. Poslušano na dobrem ozvočenju, seveda.
ales74 ::
Preko streama je pol boljša kvaliteta kot na DAB-u?
Scorpy84 ::
deskstar je izjavil:
mtosev je izjavil:
jaz imam procesor v avtu in lahko vidim, kaj se dogaja, pa ne drži, uporabljajo predvsem remasterde komade. Kot smo že prej govorili, če imaš hud fm sprejemnik, se da izvleči najboljše iz fm, pa seveda stacionarno anteno. Vse drugo je v prid dab, ker s poceni aparatom, prideš do boljše kvalitete zvoka kot pri fm. Torej to debato lahko že enkrat nehamo, ker je vse odvisno od kvalitete sprejemnika. 99% jih ima budget... tudi če daš dobre zvočnike, na isti sprejemnik, bo spet dab imel lepši zvok... Kar se pa tiče pojačan bas, visoke... ni res, oddajajo res nekaj glasneje, kot naprimer radio 1 in njihove sestrske postaje, ki so tišji. Center, salomon, rock vsi imajo višjo glasnost, tudi srednje tone če smo že pri tem. In ko smo že pri tem, s procesorjem lahko izvlečem boljši zvok kot pri fm, ker niso frekvence odrezane zaradi omejitev fm oddajanja. Medtem dab, nima teh omejitev. Pa imam konkretne zvočnike, če smo že pri tem.
deskstar ::
ales74 je izjavil:
Primerjaj bitrate.
gb39 ::
duh1 je izjavil:
Program Radio 3 se je preimenoval v Klasik radio
duh1 ::
Ja, res je. Malo sem bil površen. Potem pa sploh ni tako slabo; od 16 programov jih je začelo oddajati 9 kar je več kot polovica.
gb39 ::
Haha, ko nazdravljaš dejstvu, da so skor vsi začeli oddajat...v tunelih je že signal? Ker so to obljubili že leta 2021
andimik ::
Dva multipleksa (10D in 12C) je mogoče sprejemati skozi celoten predor Karavanke, tudi na Avstrijskem ozemlju!
Vendar ne R4!
andimik ::
https://digitalniradio.si/dab-monitor/
Back to the roots! Retro Radio je sedaj v R3 namesto v R4.
duh1 ::
Glavan je mislil, da bo z donacijami fural radio v R4. Pa se je malo uštel. Je pa vseeno razlika v stroških oddajanja v R4 ali R3. Škoda, da nimamo v Sloveniji več takih ljudi, da bi furali radijske postaje, vsaj v R3, kjer so stroški sprejemljivi.
Imamo pa v R3 Radio Energija in ravno danes mineva 1 mesec, odkar program oddaja tišino. 8-O
On služi s prodajo kapacitet, mislim da Ekspres kupuje od njega, ker ima slot v R1.
duh1 ::
Vprašanje, kako so dogovorjeni.
Namreč, HSG d.o.o., pod katerim sta Ekspres SLO (DAB+) in Rock Radio Ljubljana (FM), ima novega direktorja in sicer Gregor Memedović (Next Media).
Rock Radio Ljubljana ne posluje več pod HSG d.o.o., ampak pod Rock Radio d.o.o..
andimik ::
duh1 je izjavil:
What about the other affected programs? Do you by chance know if they are transmitting a backup program? Because they stil DON'T have dynamic data (= no slideshow, no artist/title in the DLS)
gb39 ::
A so na AKOSu še na dopustu ali mislijo predstavit, kateri programi so dobili pravice za oddajanje in nikoli ne bodo začeli oddajat? 4 mesece je že skoraj od odpiranja ponudb...
andimik ::
Radio Energija je postal Radio1Country, ponovno se uporablja 88 kBit.
2488 Radio 1 Country Radio Obala d.o.o. Brnčičeva ulica 31 - 1231 Ljubljana - Črnuče Dalibor Kosmina Radijski medij., vsak dan, 24ur Dalibor Kosmina Brnčičeva ulica 31 - 1231 Ljubljana - Črnuče radijsko oddajanje Slovenija slovenski Dalibor Kosmina (100.00%)
https://remk.ekultura.gov.si/razvid/med...
https://digitalniradio.si/programi-v-om...
In: Retro Radio (R3) ima samo 56 kBit in slabši PL3A.
81 / 84
FM frekvence radijskih postaj v Kranju
Oddelek: Zvok in slika
181865 (1404) Korzo23
Frekvence radijskih postaj
3510639 (9061) Scorpy84
Italijani drugi pokopavajo FM
388403 (4798) veso266
Norvežani kot prvi pokopavajo analogni radio (strani: 1 2 )
7338202 (34294) CyberPunk
Zakaj imajo Radijske postaje več frekvenc?
4616111 (14468) Scorpia
