Forum » Pomoč in nasveti » Transmission GUI + Synology NAS
Gogo ::
Pomoč rabim.
RAd bi povezal Synology NAS in Transmission GUI. Transmission sem že instaliral na NAS. In ročno dela vse OK.
Sedaj me muči Transmission GUI. Port in path.
Rahla pomoč bi bila več kot dobrodošla.
Thx.
Thx.
Gigabyte Aorus B550 Elite|Ryzen 3 3100|Gainward RTX 2060 Ghost, 6 GB GDDR|
TG Delta RGB 16GB CL 16|ADATA XPG SX8200 PRO 512GB NVMe SSD M.2|
Chieftec Photon Series 650W RGB ATX| Antec PerformanceOne P7 Silent Black|
s6c-gEL ::
transmission-daemon kot torrent klient, primerno za nas
https://code.google.com/p/transmisson-r...
remote host: lan ip Synology (192.168.1.X)
port: 9091
če bi rad dostopal preko web browserja : 192.168.1.X:9091
Za username/ pass, urediš settings.json
http://superuser.com/questions/113649/h...
port: 9091
Do these things in the exact order:
Shutdown: /etc/init.d/transmission-daemon stop
Write the rpc-password in the /etc/transmission-daemon/settings.json file, in double-quotes.
Save that file
Startup: /etc/init.d/transmission-daemon start
Login to the page, it's at port 9091
Type in your password.
The password that's being overwritten is a hash. The program is smarter than usual and detects that your password is not a hash, so it overwrites the password with the hash to be secure. So your password should work.
- spremenilo: s6c-gEL ()
Gogo ::
Preko web dostopam normalno. Port je 9091 in ga vidim v nas-u.
Muči me verjetno RPC path:________________________.
Bom pogledal settings.json file pa poročam.
thx za sedaj.
thx za sedaj.
Gogo ::
Rešeno, putty in vi + edit settings.json.
hvala vsem.
hvala vsem.
| » | eTRAYz (strani: 1 2 3 4 … 9 10 11 12 )Oddelek: Strojna oprema | 83496 (23744) | misek |
| » | [Alternatvni Firmware za router] Vprašanja in težaveOddelek: Operacijski sistemi | 2071 (1341) | BivšiUser2 |
| » | uTorrent za win 8.1Oddelek: Operacijski sistemi | 1257 (1078) | BorutK-73 |
| » | Raspberry PI in OpenElec (strani: 1 2 )Oddelek: Strojna oprema | 14972 (9721) | Matija82 |
| » | clarkconnect rabim poomoč pri inštaliranju! (strani: 1 2 3 4 5 )Oddelek: Operacijski sistemi | 18982 (10521) | Gapi |
