Root Uninstaller
Root Uninstaller
Someoneilove ::
Z root uninstaller sem zbrisala nekaj aplikacij. Po nesreči sem zbrisala tudi aplikaciji "dialer.apk in phone.apk". Phone storage.apk imam se vedno. Po tem ko sta bili te dve aplikaciji odstranjeni je zacel telefon vibrirat in mi posiljat error da se ne odziva in da se mora zapreti. Telefon sem resetirala, ampak je bil problem se vedno enak. Ugotovila sem da ne morem klicati nikogar, prav tako tudi nihce ne more klicati mene. Iz google-play sem downloadala One Dialer, ampak to se vedno ni resilo problema. Poskusila sem veliko aplikacij vendar zaman. Poskusila sem narediti "factory reset" in spet sem dobila error. Klicnih nastavitev mi sploh ne odpre in mi napise error. Ne vem vec kaj naj naredim. Prosim, ce mi kdo ki se na to spozna pomaga.
Telefon; Samsung Galaxy 5- Gt i5500
Hvala ze vnaprej
I've used Root uninstaller to remove some applications but accidently i also removed dialer.apk and phone.apk . (phone storage.apk is still here).
After that my phone started vibrating and giving me errors as phone.apk is not responding and that the application needs to close.. I re-booted my phone and it was still the same.. I tried to call but it won't let me. It always gives me the same error over and over again. I installed an application onedialer.apk from google play and it's still the same. I tried to do a factory reset and i will get the error again. Also in the settings pannel - call settings is giving me the error. I don't know anymore what to do. I would need a real help.
My phone; Samsung Galaxy 5 - Gt i5500
Please help me
Halfdead987 ::
Flešaj original rom nazaj.
Someoneilove ::
Halfdead987 je izjavil:
Kako ?
Halfdead987 ::
Odin.
LordPero ::
Vse najdeš v prvih linkih.
LordPero
D3 GO, Amis MobiaTV, T-2 tv2go [Hacked APK][ROOT] (strani: 1 2 3 4 … 7 8 9 10 )
Oddelek: Mobilne tehnologije
482186659 (44857) yani2000
Odprto pismo, izzvano z nespodobnim povabilom britanskih obveščevalcev
Oddelek: Novice / Zasebnost
2310322 (8354) zavajon
Android -ROOT (strani: 1 2 )
598931 (5562) max157
Obupno počasen Android
4011868 (10548) joze67
Dialer.apk Error
51360 (1295) andromedar
