333 DDR ram in Bus Speed v Sandri, Cpu-Z
aambro ::
Imam 333 DDR ram, ki se zgleduje po FSB frekvenci. FSB imam na 193Mhz, V Sandri pa mi v Memory bandwidth benchmark napise: Memory Bus Speed: 1x 193 (193Mhz Data Rate).
Prav tako mi Cpu-Z napise frekvenco 193Mhz.
Ker imajo ostali, ki imajo DDR ram vsi frekvenco pomnoženo z 2 (npr. 2x193) ali 386, me zanima, ali imam kaj narobe nastavljeno?
Bios mi prepozna DDR 333 ram.
Sandra mi temu primerno javi Tip:
Notice N5406 - System bandwidth appears to be memory limited. Generally this means that memory bandwidth is < 50% FSB bandwidth, thus CPU is starved. This generally indicates a mismatch between memory and system. Note that this does not indicate that memory timings are wrong, but the memory itself is slow.
Fix: Use higher performance memory (e.g. DDR or RDRAM) or use any additional memory channels (if present) to increase memory bandwidth performance.
- ki se mi zdi malo cuden :)
boštjan ::
don'z belive everything she sais;)
Golden eye ::
Povej kakšne razultate dobiš v Sandri v memory benchmark?! Pa si probal najnovejšo verzijo sisioftsandre?? :\
BTW:poglej moj podpis(moj proc) :D
rfmw ::
@golden_boy
ej a mas samsung C-TCB3 ali D-TCB3?
tnx!
Legendary 8RDA+ (reCAPed ;), XP1700+ 2108 @ 1.84 V, SLK900A AS3 @ 2500 rpm
1,5GB Samsung DDR333+Geil DDR400+SuperTalent DDR400 @ DC 200 MHz @ 6-3-3-2.5
Golden eye ::
imam C-TCB3 in mi dela stabilno na 185 mhz (fastest setings 2,3,6,3,2):D
AMD 2500+ dela samo na 1100mhz 100fsb
201794 (1430) DJ MartiNi
Baza RAM timingov
Oddelek: Navijanje
383341 (2277) DimmniBurek
Kvaliteten RAM (strani: 1 2 3 4 … 9 10 11 12 )
Oddelek: Navijanje
55047762 (39560) bodom
Približni rezultat 3000+ Athlona (strani: 1 2 3 4 )
Oddelek: Navijanje
16511517 (9242) Zoidberg
Kateri ram DDR?
322581 (1847) Clemento
