Forum » Omrežja in internet » Še komu ne gre na podnapisi.net?
BorutK-73 ::
Včasih jim nagaja login server, z računom se stran ne odpre, brez pa brez problema
edit
trenutno dela stran
edit
trenutno dela stran
- spremenil: BorutK-73 ()
Gogo ::
Dela, pravkar pogledal.
Gigabyte Aorus B550 Elite|Ryzen 3 3100|Gainward RTX 2060 Ghost, 6 GB GDDR|
TG Delta RGB 16GB CL 16|ADATA XPG SX8200 PRO 512GB NVMe SSD M.2|
Chieftec Photon Series 650W RGB ATX| Antec PerformanceOne P7 Silent Black|
zila90 ::
Meni ne dela. Brskalnik mi vedno javlja, da spletno mesto ne more zagotoviti varne povezave (ERR_SSL_PROTOCOL_ERROR).
Lahko kako zaobidem to napako?
krho ::
Ja, nehaj uporabljat Chrome.
donvito ::
Poskusi s tem:
https://duckduckgo.com/?q=podnapisi+net...
kajnepoves ::
Ni kriv samo Chrome, tudi na Operi ne dela, deluje pa z Mozillo Firefox. Zgleda da je težava na podnapisi.net in ne Chrome in Opera. Ali se motim?
Raziskujem problem.
Na FF dela, vidim da stran tam uporablja sledeče:
FF @ podnapisi.net, klik na ključavnico, connection secure, more information, view certificate
1. podnapisi.net
[Subject Name]
Common Name: podnapisi.net
[Issuer Name]
Country: US
Organization: Let's Encrypt
Common Name: R3
[Validity]
Not Before
Tue, 31 Oct 2023 17:03:01 GMT
Not After
Mon, 29 Jan 2024 17:03:00 GMT
2. R3
[Subject Name]
Country: US
Common Name: R3
[Issuer Name]
Country: US
Organization: Internet Security Research Group
Common Name: ISRG Root X1
[Validity]
Not Before Fri, 04 Sep 2020 00:00:00 GMT
Not After Mon, 15 Sep 2025 16:00:00 GMT
[Public Key Info]
Algorithm: RSA
Key Size: 2048
Exponent: 65537
Modulus:BB:02:15:28:CC:F6:A0:94:D3:0F:12:EC:8D:55:92:C3:F8:82:F1:99:A6:7A:42:88:A7:5D:2 ...
ter
3. ISRG Root X1
[Subject Name]
Country: US
[Issuer Name]
Country: US
Not Before Thu, 04 Jun 2015 11:04:38 GMT
Not After Mon, 04 Jun 2035 11:04:38 GMT
Algorithm: RSA
Key Size: 2048
Exponent: 65537
Modulus: AD:E8:24:73:F4:14:37:F3:9B:9E:2B:57:28:1C:87:BE:DC:B7:DF:38:90:8C:6E:3C:E6:57:A0...
in če gledam tu ssllabs
https://www.ssllabs.com/ssltest/analyze...
se vidi da FF (isto Palemoon portable 32.x) uporabljata
SS iz Palemoon
prva izbira
Server Key and Certificate #1
Valid from Tue, 31 Oct 2023 17:03:01 UTC
Valid until Mon, 29 Jan 2024 17:03:00 UTC (expires in 2 months and 14 days)
Key RSA 4096 bits (e 65537)
druga izbira
Additional Certificates (if supplied)
#2
Subject R3
Valid until Mon, 15 Sep 2025 16:00:00 UTC (expires in 1 year and 10 months)
Key RSA 2048 bits (e 65537)
Issuer ISRG Root X1
tretja izbira
#3
ne more uporabljati nihče več, kajti DST Root CA X3 je potekel 09/2021 https://letsencrypt.org/docs/dst-root-c...
letsencrypt certifikati so na voljo tu:
https://letsencrypt.org/certificates/
Chrome uporablja sistemsko (OS) windows "bazo" certifikatov (trusted root certification authorities, intermediate certification authorities, in ostali tabi), tam vidim da je taisti certifikat (ISRG Root X1) že notri
https://woshub.com/updating-trusted-roo...
Managing Trusted Root Certificates in Windows 10 and 11
How to see the list of trusted root certificates on a Windows computer?
1 To open the root certificate store of a computer running Windows 11/10/8.1/7 or Windows Server 2022/2019/2016, run the mmc.exe console;
2 Select File -> Add/Remove Snap-in, select Certificates (certmgr) in the list of snap-ins -> Add;
3 Select that you want to manage certificates of local Computer account;
4 Next -> OK -> OK;
5 Expand the Certificates node -> Trusted Root Certification Authorities Store. This section contains the list of trusted root certificates on your computer.
bližnjica: start, run , certlm.msc
v "trusted root certification authorities" imam ISRG Root X1 4.6.2035
v "intermediate certification authorities" imam R3 (Let's Encrypt 15.9.2025
a še vedno na Chromu ne dela.
1. podnapisi.net
[Subject Name]
[Issuer Name]
Country: US
Common Name: R3
[Validity]
Not Before
Not After
2. R3
[Subject Name]
Country: US
Common Name: R3
[Issuer Name]
Country: US
[Validity]
[Public Key Info]
Algorithm: RSA
Key Size: 2048
Exponent: 65537
ter
3. ISRG Root X1
[Subject Name]
Country: US
[Issuer Name]
Country: US
Algorithm: RSA
Key Size: 2048
Exponent: 65537
SS iz Palemoon
prva izbira
druga izbira
#2
Subject R3
Issuer ISRG Root X1
tretja izbira
#3
4 Next -> OK -> OK;
- spremenilo: sbawe64 ()
Update
Na linux (porteous) 5.01 xfce in chromium ungoogled 117 stran dela, uporablja Server Key and Certificate #1, tako kot FF in PM.
Windows 7 x32, chromium woolyss 109 (novejši ne delajo), stran se lepo odpre, uporablja Server Key and Certificate #1, tako kot FF in PM.
Tiger ::
Ali je kdo izklopil funkcijo "Preload pages" v Google Chrome-u (oz. po slovensko "Vnaprejšnje nalaganje strani"). To se izklopi v nastavitvah brskalnika -> Performance (v slo. Učinkovitost delovanja).
Na telefonu meni dela (Chrome).
Nekdaj stvari za preveriti
https://www.maketecheasier.com/fix-err-...
https://sectigostore.com/blog/how-to-fi...
Na win 7 x64 in chromium woolyss 109 tudi dela (Server Key and Certificate #1).
Drugače na podnapisi.net strani Developer tools F12, Security, View Certificate
https://superuser.com/questions/1160502...
En trik , mogoče dela
https://stackoverflow.com/questions/626...
Just type the letters: thisisunsafe.
Just click anywhere on the tab to give it focus (no button), and type the letters. (The letters will not be visible or show up in a field or anything.) After completing the words, the website loads, but will show as 'insecure' in the left of the address bar.
Edge will mark the website as "allowed", unless this operation is done in an inPrivate window. After it's saved, it works even with inPrivate.
Update1
Na linux (porteous) 5.01 xfce in chromium ungoogled 119 stran NE dela.
Rešitev
Update2
chrome://flags
Allow sha-1 server signatures in TLS
Iz default na enabled.
Rešitev
Update2
chrome://flags
klemenSLO ::
Update1
Rešitev
Update2
chrome://flags
Hvala za (začasno) rešitev - DELUJE!
Kot piše bo delalo najmanj do verzije 123
https://chromestatus.com/feature/483285...
Imho morajo na podnapisi.net odstraniti to legacy funkcijo, drugače se bo zgodba z verzijo 123 ponovila.
Za FF ne najdem, kdaj bodo ukinili support za sha-1 server TLS handshake.
Našel samo stare članke iz 2016, kjer so to naredili in potem restorali nazaj
https://www.zdnet.com/article/firefox-b...
https://www.eweek.com/enterprise-apps/m...
chromium, naložena problematična stran, developer , security
SS
drugače je za FF dober extension: indicate tls https://addons.mozilla.org/en-US/firefo...
SS
relevantno iz slike
signature:
rsa-pkcs1-sha1
En dober site za tls test strani:
https://www.wormly.com/test_ssl
btw, edge 119 v "edge://flags/" ni več opcije "Allow sha-1 server signatures in TLS".
SS
SS
relevantno iz slike
signature:
rsa-pkcs1-sha1
Konec zabave, tudi flag sha-1 enabled/disabled/default ne pomaga več.
chromium 119.0.6045.160
stran odpre, a napiše samo:
Internal Server Error
ali
502 Bad Gateway
medtem v FF 120 odpre kot mora (dejanska stran).
ali
502 Bad Gateway
kajnepoves ::
In v čem je zdaj keč? Ali je težava Chrom, Opera, Microsoft Edge da ne odpre strani ali je težava pri podnapisi.net?
ali
502 Bad Gateway
Update
na chromium 120.0.6099.71 sedaj stran odpre
Stran še vedno uporablja sha-1 za server signature.
| » | podnapisi.net (strani: 1 2 3 4 5 )Oddelek: Izdelava spletišč | 58073 (3359) | Anney |
| » | Davčne blagajne (strani: 1 2 3 4 … 24 25 26 27 )Oddelek: Programiranje | 389293 (129296) | Macketina |
| » | Samopodpisan certifikat na Outlook Office 365/Win10Oddelek: Operacijski sistemi | 3872 (3481) | poweroff |
| » | Ipv6 dosegljivostOddelek: Slo-Tech | 3558 (2772) | AndraZK |
| » | Prevzem digitalnega potrdila KDP - težaveOddelek: Omrežja in internet | 5199 (5096) | fosil |
