Ipv6 dosegljivost
Ipv6 dosegljivost
sporhetC ::
Preko ipv6 imate nedosegljivo stran ...
trace in ping delujeta ..
nslookup www.slo-tech.com
Server: xxx.xxx.xxx
Address: 2001:15c0:65ff:87ce::2:15
Non-authoritative answer:
Addresses: 2001:67c:2730:1::2
91.236.1.130
Tracing route to www.slo-tech.com [2001:67c:2730:1::2]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms xxx.xxx.xxx [2001:15c0:65ff:87ce::1]
2 1 ms 1 ms 1 ms gw-1999.mbx-01.si.sixxs.net [2001:15c0:65ff:7ce::1]
3 1 ms 1 ms 1 ms simbx01.sixxs.net [2001:15c0:ffff:7::2]
4 1 ms 1 ms 1 ms mx-mb1-te-1-2-0-v4.amis.net [2001:15c0:ffff:7::1]
5 3 ms 1 ms 1 ms mx-mb1-te-1-3-1.amis.net [2001:15c0:ffff:d::c]
6 3 ms 3 ms 5 ms mx-lj1-te-1-2-1.amis.net [2001:15c0:ffff:d::a]
7 153 ms 6 ms 201 ms ljubljana9-te-1-4.amis.net [2001:15c0:ffff:d::f]
8 4 ms 3 ms 3 ms six2.ilol.si [2001:7f8:46:0:1:0:19:8524]
9 4 ms 3 ms 3 ms slo-tech.com [2001:67c:2730:1::2]
Trace complete.
Pozdrav..... AMD-hisni radiator
AndraZK ::
Lahko potrdim. Tudi jaz sem mislil, da ste v izpadu, nakar ugotovim, da na ipv4 pa dela.
The Matrix Has Me...
Gandalfar ::
še vedno ne dela?
sporhetC ::
nep ... stran preko ipv6 ni dosegljiva....
Gapi ::
In še vedno ne dela...........
No person is rich enough,to buy back his past.
To je zihr pri tebi neki narobe ;)
sporhetC ::
Pri meni ziher ni ... :)
Vse ipv6 strani se ok odpirajo ...
Ps .. nmap kaže, da sta porta http in https odprta, torej ne deluje web strežnik .. (vsaj na ipv6 ne) ..
stb ::
Iz T-2 sta dostopna oba:
IPv4:
$ ncat -4 --ssl -v slo-tech.com 443
Ncat: Version 6.00 ( http://nmap.org/ncat )
Ncat: SSL connection to 91.236.1.130:443. Primoz Bratanic
Ncat: SHA-1 fingerprint: 86A7 30DE AB28 C8A3 2BB2 309D D20A 2F68 4A28 0458
HEAD / HTTP/1.0
Host: slo-tech.com
HTTP/1.1 200 OK
Server: nginx
Date: Mon, 05 May 2014 13:14:51 GMT
Content-Type: text/html
Connection: close
X-XRDS-Location: http://slo-tech.com/openid.xrd
ETag: 0-0-1-1399295246
Public-Key-Pins: max-age=864000; pin-sha1="OyQfwFWwPetofrq4QgBGntWNXQE="; pin-sha256=    "Pg3jOFnf1wQ/Dpw9plV0pH+8h0cIAak3Mq+11qvddCI="; pin-sha1="ZZ3+lHfJ5/gOfvDXfL0SNPN9QNI    ="; pin-sha256="PdXc7eygtW9owJOeMCcJAcCPb6WqIUCkF1xFoIg/yWI="; pin-sha1="EQfrgD/OYyd7    IpzQFcRL/mB6pWg="; pin-sha256="X67Dx20SFBWwutgQKWT2EZrS9GQca/pJM+2KXKPUplw="
X-Frame-Options: SAMEORIGIN
Strict-Transport-Security: max-age=16070400
Ncat: 36 bytes sent, 595 bytes received in 6.94 seconds.
...in IPv6:
$ ncat -6 --ssl -v slo-tech.com 443
Ncat: SSL connection to 2001:67c:2730:1::2:443. Primoz Bratanic
HEAD / HTTP/1.0
Host: slo-tech.com
HTTP/1.1 200 OK
Server: nginx
Date: Mon, 05 May 2014 13:15:01 GMT
Connection: close
Ncat: 36 bytes sent, 595 bytes received in 2.93 seconds.
  • spremenil: stb ()
sporhetC ::
pri meni pa javlja timeout ... (v službi uporabljam 6 in 4 preko sixxs - pop amis), doma pa ipv6 preko siola..
Vsepovsod imam enak rezultat .. na obeh straneh je mikrotik , povezava se do vas vidi v seznamu ...
Ncat: Connection timed out.
Brane22 ::
Sem na T-2. Sem probal ravnokar na -4 in -6.
Pri meni dela.
* About to connect() to slo-tech.com port 443 (#0)
* Trying 2001:67c:2730:1::2... connected
> GET / HTTP/1.1
< HTTP/1.1 200 OK
Deluje.
stb ::
  • spremenil: stb ()
AndraZK ::
Zanimivo.
Meni na linux routerju deluje (ncat test je OK), na lokalnem računalniku win7 pa še vedno javlja timeout.
Vse ostale ipv6 strani mi delujejo z ipv6 (fb, google, siol.net, t-2.net, yt, funtech, podnapisi.net, ...). Ping ipv6 na slo-tech.com deluje. HTTPS z brskalniki pa ne dela (chrome, ff, ie). V vseh brskalnikih drugače dobim popolne score na ipv6 testnih straneh.
IPv6 imam na T2, VDSL (se pravi z ročno dodanim neighbourjem).
Poskusil sem še z ncat za windows, -4 je OK
c:\..>ncat -4 --ssl -v slo-tech.com 443
Ncat: Version 6.46 ( http://nmap.org/ncat )
-6 pa NI OK:
c:\..>ncat -6 --ssl -v slo-tech.com 443
Ncat: .
Isto Google -6 dela:
c:\..>ncat -6 --ssl -v www.google.si 443
Ncat: SSL connection to 2a00:1450:4005:809::1018:443. Google Inc
Ncat: SHA-1 fingerprint: 4DD0 4AE9 D8DB 04A4 4F3C A6C3 29CC 43A4 A292 0BBE
HEAD / HTTP/1.0
Host: www.google.si
HTTP/1.0 200 OK
Date: Tue, 06 May 2014 19:51:57 GMT
Je pa OK slo-tech z -6 na 80 port, kjer dobim 301, kot je prav. Se pravi zaplete se samo pri: slotech + SSL + ipv6.
Promet sem še posnifal:
V wiresharku vidim uspešen IP handshake, nato SSL Client Hello z moje strani in pravi ACK od slotecha. Nato pa zanimivo od slo-techa dobim še en continuation data, ki se pritoži, da prejšnjega ni zajel. Seq skoči iz 1 na 5777, stran pa seveda ne dela brez tega vmesnega paketa :) Moj še poskusi z duplicate ACK ampak neuspešno.
Je pri ostalih, ki jim ne dela, težava identična?
PS: še traceroute
Tracing route to slo-tech.com [2001:67c:2730:1::2] over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  ########
  2    12 ms    12 ms    12 ms  2a01-260-1017--1.link6.t-2.net [2a01:260:1017::1]
  3    51 ms    53 ms    53 ms  2a01-260-1-1--32.core6.t-2.net [2a01:260:1:1::32]
  4    12 ms    13 ms    12 ms  2a01-260-1-1--28.core6.t-2.net [2a01:260:1:1::28]
  5    13 ms    13 ms    13 ms  six2.ilol.si [2001:7f8:46:0:1:0:19:8524]
  6    59 ms    60 ms    61 ms  slo-tech.com [2001:67c:2730:1::2]
Trace complete.
PS2: ncat za win: http://nmap.org/download.html
sporhetC ::
Pri meni je čisto enaka stvar ..
Testiral preko dveh različnih ponudnikov (sixxs in siol)....
Bakunin ::
http://ipv6chicken.com/ mi dela. slo-tech ne dela. [amis pppoe ipv6]
kriko1 ::
Isto pri meni.
Ncat: Version 6.40 ( http://nmap.org/ncat )
In opažam isto prek wiresharka kot AndraZK - identično. Vsi ostali servisi prek ipv6 pa delujejo nemoteno.
  • spremenil: kriko1 ()
jure@havelock:~$ ncat -6 --ssl -v slo-tech.com 443
Ncat: Version 5.21 ( http://nmap.org/ncat )
GET / HTTP/1.1
Host: slo-tech.com
HTTP/1.1 200 OK
Server: nginx
Date: Thu, 08 May 2014 17:28:15 GMT
Content-Type: text/html; charset=iso-8859-2
Transfer-Encoding: chunked
Connection: keep-alive
ETag: 0-0-1-1399568315
Public-Key-Pins: max-age=864000; pin-sha1="OyQfwFWwPetofrq4QgBGntWNXQE="; pin-sha256="Pg3jOFnf1wQ/Dpw9plV0pH+8h0cIAak3Mq+11qvddCI="; pin-sha1="ZZ3+lHfJ5/gOfvDXfL0SNPN9QNI="; pin-sha256="PdXc7eygtW9owJOeMCcJAcCPb6WqIUCkF1xFoIg/yWI="; pin-sha1="EQfrgD/OYyd7IpzQFcRL/mB6pWg="; pin-sha256="X67Dx20SFBWwutgQKWT2EZrS9GQca/pJM+2KXKPUplw="
f81
<!DOCTYPE HTML>
<html xml:lang="sl" lang="sl" dir="ltr">
<head>
        <meta http-equiv="content-type" content="text/html; charset=iso-8859-2" />
        <title>Slo-Tech - Tehnolo&#353;ki koti&#269;ek spleta</title>
Če koga zanima, kako je videti tcpdump povezave, ki deluje (T2 VDSL):
http://bou.si/rest/slo-tech.pcap
Traceroute je videti takole:
jure@havelock:~$ traceroute6 slo-tech.com
traceroute to slo-tech.com (2001:67c:2730:1::2) from 2a01:260:4076:2::8b, 30 hops max, 24 byte packets
 1  router (2a01:260:4076:2::1)  0.362 ms  0.301 ms  0.415 ms
 2  * * *
 3  2a01-260-1-1--6.core6.t-2.net (2a01:260:1:1::6)  14.681 ms  14.737 ms  14.726 ms
 4  six2.ilol.si (2001:7f8:46:0:1:0:19:8524)  14.993 ms  15.552 ms  15.703 ms
 5  slo-tech.com (2001:67c:2730:1::2)  17.209 ms  15.324 ms  16.448 ms
  • spremenilo: jype ()
Bakunin ::
očitno pppoe >> MTU issue
ampak kot rečeno na ostalih ipv6 https dela bp.
Bakunin> pppoe
se ne ujema z
AndraZK> IPv6 imam na T2, VDSL (se pravi z ročno dodanim neighbourjem).
Bakunin ::
morda ima tudi on "zaprt" icmp6...
je pa fakt da ne dela nobenemu, ki ima ipv6 preko pppoe oz. ima kaksen tunel [sixxs].
Tule je še dump prometa z Windows 7 mašine, kjer tudi normalno deluje:
http://bou.si/rest/slo-tech-win7.pcap
sporhetC ::
Bakunin je izjavil:
Ja samo zakaj ne dela samo slo-tech .. vse ostalo pa dela čist vredu ..
Če bi bil kriv MTU potem nebi smelo nič delati na ipv6 ... niti google ne ..
Bakunin ::
MTUsomething na s-t, ne pri uporabniku...
sporhetC ::
Ping pa deluje normalno... tudi port 80 in 443 vidim ...
tudi trace zgleda ok ..
1 1 ms 1 ms 1 ms 2a00:ee2:f100:3d00::1
2 41 ms 41 ms 39 ms 2a00:ee0::7:0:0:4
3 39 ms 40 ms 41 ms 2a00:ee0:0:572::1
4 43 ms 44 ms 43 ms six2.ilol.si [2001:7f8:46:0:1:0:19:8524]
5 43 ms 46 ms 44 ms slo-tech.com [2001:67c:2730:1::2]
mogoče je kaj na web strežniku ni pravilno nastavljeno ..
Bakunin ::
zdaj dela tudi meni
Kaj si pa spremenil?
sporhetC ::
Zudi meni zdaj deluje ....
Zgleda so nekaj na slo-tech strežnikih uredili
Bakunin ::
jaz nic.
ask admin@s-t ;)
sporhetC ::
Ja tudi jaz bi rad vedel kaj ni bilo pravilno nastavljeno :)
Primoz ::
ip ro cache flush table main :D
zgleda bo treba kernel zamenjat.
There can be no real freedom without the freedom to fail.
AndraZK ::
lahko potrdim, tudi meni deluje :)
IPv6 (strani: 1 2 3 4 5 6 7 8 )
Oddelek: Omrežja in internet
363117472 (35487) Klemen86
Težave - internet
302241 (1979) megy
Slotech mi ne odpre
215024 (4128) crniangeo
Preverjanje, če je spletna stran enaka
Oddelek: Programiranje
81752 (1411) Hayabusa
Naj Slo-Tech leti!
143323 (2849) podtalje
