Telemachov HD sprejemnik - samo 50Hz?
Fifty ::
Uporabljam omenjen HD sprejemnik in me zanima, če kdo ve če se da nastaviti na več kot 50Hz? Resolucija gre gre sicer normalno do 1080p. LP
Ted ::
The field rate of 1080i is typically 60 Hz for countries that use or used System M as analog broadcast television system (such as United States, Canada, Japan and Brazil) or 50 Hz for regions that traditionally used television systems with 25 frames/s rate (such as in Europe, Australia, much of Asia, Africa). Both variants can be carried by both major digital television transmission formats: ATSC and DVB.
1080i @ Wikipedia
DVB signal pri nas nima več kot 50Hz, tega ne moreš nastavljat. To da je TV 100 ali 200Hz je tehnologija (boljšega?) prikaza slike na sprejemniku in nima veze s signalom.
Mah...
Prvi televizijski kanal v ločljivosti 4K (strani: 1 2 3 )
Oddelek: Novice / Zasloni / projektorji / ...
12649352 (44447) M-XXXX
kateri lcd tv
4710991 (8065) simic12
Full HD TV (strani: 1 2 3 4 … 16 17 18 19 )
Oddelek: Zvok in slika
942124601 (41588) Kovalchuk
HDTV se širi po Evropi (strani: 1 2 )
5610189 (8587) Jaka83
Linux / ATI Radeon / problem z driverji
Oddelek: Operacijski sistemi
132214 (2031) ahac
