Linux / ATI Radeon / problem z driverji
ahac ::
Imam problem z driverji za Radeona (imam 9100) v Linuxu.
3D ne dela nič.
Recimo Enemy Territory izpiše tole:
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
...loading libGL.so.1: Initializing OpenGL display
...setting mode 4: 800 600
Using XFree86-VidModeExtension Version 2.2
XF86DGA Mouse (Version 2.0) initialized
XFree86-VidModeExtension Activated at 800x600
Using 8/8/8 Color bits, 16 depth, 0 stencil display.
GL_RENDERER: Mesa GLX Indirect
 You are using software Mesa (no hardware acceleration)!
 Driver DLL used: libGL.so.1
 If this is intentional, add
       "+set r_allowSoftwareGL 1"
 to the command line when starting the game.
...WARNING: could not set the given mode (4)
...setting mode 3: 640 480
XFree86-VidModeExtension Activated at 640x480
Received signal 11, exiting...
glxinfo pa tole:
[sedusak@localhost sedusak]$ glxinfo
name of display: :0.0
display: :0  screen: 0
direct rendering: No
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context
client glx vendor string: ATI
client glx version string: 1.3
client glx extensions:
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context,
    GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_ATI_pixel_format_float,
    GLX_ATI_render_texture
GLX extensions:
OpenGL vendor string: Mesa project: www.mesa3d.org
OpenGL renderer string: Mesa GLX Indirect
OpenGL version string: 1.3 Mesa 4.0.4
OpenGL extensions:
    GL_ARB_imaging, GL_ARB_multitexture, GL_ARB_texture_border_clamp,
    GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
    GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3,
    GL_ARB_transpose_matrix, GL_EXT_abgr, GL_EXT_blend_color,
    GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_texture_env_add,
    GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
    GL_EXT_texture_lod_bias
glu version: 1.3
glu extensions:
    GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess
   visual  x  bf lv rg d st colorbuffer ax dp st accumbuffer  ms  cav
 id dep cl sp sz l  ci b ro  r  g  b  a bf th cl  r  g  b  a ns b eat
0x23 24 tc  1 24  0 r  y  .  8  8  8  0  0 16  0  0  0  0  0  1 0 None
0x24 24 tc  1 24  0 r  y  .  8  8  8  0  0 16  8 16 16 16  0  1 0 None
0x25 24 tc  1 24  0 r  y  .  8  8  8  8  0 16  8 16 16 16 16  1 0 None
0x26 24 tc  1 24  0 r  .  .  8  8  8  8  0 16  8 16 16 16 16  1 0 None
0x27 24 dc  1 24  0 r  y  .  8  8  8  0  0 16  0  0  0  0  0  1 0 None
0x28 24 dc  1 24  0 r  y  .  8  8  8  0  0 16  8 16 16 16  0  1 0 None
0x29 24 dc  1 24  0 r  y  .  8  8  8  8  0 16  8 16 16 16 16  1 0 None
0x2a 24 dc  1 24  0 r  .  .  8  8  8  8  0 16  8 16 16 16 16  1 0 None
XF86Config-4 narejen z fglrxconfig, ki pride poleg driverjev izgleda takole:
# File: XF86Config-4
# File generated by fglrxconfig © ATI Research, a substitute for xf86config.
# Note by ATI: the below copyright notice is there for servicing possibly
# pending third party rights on the file format and the instance of this file.
# Copyright (c) 1999 by The XFree86 Project, Inc.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
# THE XFREE86 PROJECT BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
# WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF
# OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
# Except as contained in this notice, the name of the XFree86 Project shall
# not be used in advertising or otherwise to promote the sale, use or other
# dealings in this Software without prior written authorization from the
# XFree86 Project.
# Refer to the XF86Config(4/5) man page for details about the format of
# this file.
# DRI Section
Section "dri"
    # Access to OpenGL ICD is allowed for all users:
    Mode 0666
    # Access to OpenGL ICD is restricted to a specific user group:
    # Group 100    # users
    # Mode 0660
EndSection
# Module section -- this  section  is used to specify
# which dynamically loadable modules to load.
Section "Module"
    # Option    "omit xfree86-dga"
    # This loads the DBE extension module.
    Load "dbe"  	# Double buffer extension
    # This loads the Type1 and FreeType font modules
    Load "type1"
    Load "freetype"
    # This loads the GLX module
    Load "glx"   # libglx.a
    Load "dri"   # libdri.a
    # This loads the miscellaneous extensions module, and disables
    # initialisation of the XFree86-DGA extension within that module.
    Subsection "extmod"
        EndSubsection
EndSection
# Files section.  This allows default font and rgb paths to be set
Section "Files"
    # Multiple FontPath entries are allowed (which are concatenated together),
    # as well as specifying multiple comma-separated entries in one FontPath
    # command (or a combination of both methods)
    # If you don't have a floating point coprocessor and emacs, Mosaic or other
    # programs take long to start up, try moving the Type1 and Speedo directory
    # to the end of this list (or comment them out).
    # FontPath   "/usr/X11R6/lib/X11/fonts/local/"
    FontPath "/usr/X11R6/lib/X11/fonts/misc/"
    FontPath "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
    # FontPath   "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
    FontPath "/usr/X11R6/lib/X11/fonts/Type1/"
    FontPath "/usr/X11R6/lib/X11/fonts/Speedo/"
    FontPath "/usr/X11R6/lib/X11/fonts/75dpi/"
    # FontPath   "/usr/X11R6/lib/X11/fonts/100dpi/"
    # The module search path.  The default path is shown here.
    # ModulePath "/usr/X11R6/lib/modules"
    # The location of the RGB database.  Note, this is the name of the
    # file minus the extension (like ".txt" or ".db").  There is normally
    # no need to change the default.
    RgbPath "/usr/X11R6/lib/X11/rgb"
EndSection
# Server flags section.
Section "ServerFlags"
    EndSection
# Uncomment this to cause a core dump at the spot where a signal is
# received.  This may leave the console in an unusable state, but may
# provide a better stack trace in the core dump to aid in debugging
# Option "NoTrapSignals"
# Uncomment this to disable the <Crtl><Alt><BS> server abort sequence
# This allows clients to receive this key event.
# Option "DontZap"
# Uncomment this to disable the <Crtl><Alt><KP_+>/<KP_-> mode switching
# sequences.  This allows clients to receive these key events.
# Option "Dont Zoom"
# Uncomment this to disable tuning with the xvidtune client. With
# it the client can still run and fetch card and monitor attributes,
# but it will not be allowed to change them. If it tries it will
# receive a protocol error.
# Option "DisableVidModeExtension"
# Uncomment this to enable the use of a non-local xvidtune client.
# Option "AllowNonLocalXvidtune"
# Uncomment this to disable dynamically modifying the input device
# (mouse and keyboard) settings.
# Option "DisableModInDev"
# Uncomment this to enable the use of a non-local client to
# change the keyboard or mouse settings (currently only xset).
# Option "AllowNonLocalModInDev"
# Input devices
# Core keyboard's InputDevice section
Section "InputDevice"
    Identifier "Keyboard1"
    Driver "Keyboard"
    Option "XkbModel" "pc105"
    Option "XkbLayout" "si"
    # Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
    # Option "Xleds"      "1 2 3"
    # Option "LeftAlt"    "Meta"
    # Option "RightAlt"   "ModeShift"
    # To customise the XKB settings to suit your keyboard, modify the
    # lines below (which are the defaults).  For example, for a non-U.S.
    # keyboard, you will probably want to use:
    # Option "XkbModel"   "pc102"
    # If you have a US Microsoft Natural keyboard, you can use:
    # Option "XkbModel"   "microsoft"
    # Then to change the language, change the Layout setting.
    # For example, a german layout can be obtained with:
    # Option "XkbLayout"  "de"
    # or:
    # Option "XkbVariant" "nodeadkeys"
    # If you'd like to switch the positions of your capslock and
    # control keys, use:
    # Option "XkbOptions" "ctrl:swapcaps"
    # These are the default XKB settings for XFree86
    # Option "XkbRules"   "xfree86"
    # Option "XkbModel"   "pc101"
    # Option "XkbLayout"  "us"
    # Option "XkbVariant" ""
    # Option "XkbOptions" ""
    # Option "XkbDisable"
    # For most OSs the protocol can be omitted (it defaults to "Standard").
    # When using XQUEUE (only for SVR3 and SVR4, but not Solaris),
    # uncomment the following line.
    # Option "Protocol"   "Xqueue"
    Option "AutoRepeat" "500 30"
EndSection
# Core Pointer's InputDevice section
    # Identifier and driver
    Identifier "Mouse1"
    Driver "mouse"
    Option "Protocol" "ImPS/2"
    Option "Device" "/dev/mouse"
    # When using XQUEUE, comment out the above two lines, and uncomment
    # the following line.
    # Baudrate and SampleRate are only for some Logitech mice. In
    # almost every case these lines should be omitted.
    # Option "BaudRate"   "9600"
    # Option "SampleRate" "150"
    # Emulate3Buttons is an option for 2-button Microsoft mice
    # Emulate3Timeout is the timeout in milliseconds (default is 50ms)
    # Option "Emulate3Buttons"
    # Option "Emulate3Timeout"    "50"
    # ChordMiddle is an option for some 3-button Logitech mice
    # Option "ChordMiddle"
    Option "ZAxisMapping" "4 5"
EndSection
# Other input device sections
# this is optional and is required only if you
# are using extended input devices.  This is for example only.  Refer
# to the XF86Config man page for a description of the options.
# Section "InputDevice"
# Identifier  "Mouse2"
# Driver      "mouse"
# Option      "Protocol"      "MouseMan"
# Option      "Device"        "/dev/mouse2"
# EndSection
# Identifier "spaceball"
# Driver     "magellan"
# Option     "Device"         "/dev/cua0"
# EndSection
# Identifier "spaceball2"
# Driver     "spaceorb"
# EndSection
# Identifier "touchscreen0"
# Driver     "microtouch"
# Option     "Device"         "/dev/ttyS0"
# Option     "MinX"           "1412"
# Option     "MaxX"           "15184"
# Option     "MinY"           "15372"
# Option     "MaxY"           "1230"
# Option     "ScreenNumber"   "0"
# Option     "ReportingMode"  "Scaled"
# Option     "ButtonNumber"   "1"
# Option     "SendCoreEvents"
# EndSection
# Identifier "touchscreen1"
# Driver     "elo2300"
# Option     "MinX"           "231"
# Option     "MaxX"           "3868"
# Option     "MinY"           "3858"
# Option     "MaxY"           "272"
# Option     "ButtonThreshold"    "17"
# EndSection
# Monitor section
# Any number of monitor sections may be present
Section "Monitor"
    Identifier "Monitor0"
    HorizSync 31.5 - 68.7
    VertRefresh 50 - 70
    Option "DPMS"
    # === mode lines based on GTF ===
    # VGA @ 100Hz
    # Modeline "640x480@100" 43.163 640 680 744 848 480 481 484 509 +hsync +vsync
    # SVGA @ 100Hz
    # Modeline "800x600@100" 68.179 800 848 936 1072 600 601 604 636 +hsync +vsync
    # XVGA @ 100Hz
    # Modeline "1024x768@100" 113.309 1024 1096 1208 1392 768 769 772 814 +hsync +vsync
    # 1152x864 @ 60Hz
    # Modeline "1152x864@60" 81.642 1152 1216 1336 1520 864 865 868 895 +hsync +vsync
    # 1152x864 @ 85Hz
    # Modeline "1152x864@85" 119.651 1152 1224 1352 1552 864 865 868 907 +hsync +vsync
    # 1152x864 @ 100Hz
    # Modeline "1152x864@100" 143.472 1152 1232 1360 1568 864 865 868 915 +hsync +vsync
    # 1280x960 @ 75Hz
    # Modeline "1280x960@75" 129.859 1280 1368 1504 1728 960 961 964 1002 +hsync +vsync
    # 1280x960 @ 100Hz
    # Modeline "1280x960@100" 178.992 1280 1376 1520 1760 960 961 964 1017  +hsync +vsync
    # SXGA @ 100Hz
    # Modeline "1280x1024@100" 190.960 1280 1376 1520 1760 1024 1025 1028 1085 +hsync +vsync
    # SPEA GDM-1950 (60Hz,64kHz,110MHz,-,-): 1280x1024 @ V-freq: 60.00 Hz, H-freq: 63.73 KHz
    # Modeline "GDM-1950"  109.62  1280 1336 1472 1720  1024 1024 1026 1062 -hsync -vsync
    # 1600x1000 @ 60Hz
    # Modeline "1600x1000" 133.142 1600 1704 1872 2144 1000 1001 1004 1035 +hsync +vsync
    # 1600x1000 @ 75Hz
    # Modeline "1600x1000" 169.128 1600 1704 1880 2160 1000 1001 1004 1044 +hsync +vsync
    # 1600x1000 @ 85Hz
    # Modeline "1600x1000" 194.202 1600 1712 1888 2176 1000 1001 1004 1050 +hsync +vsync
    # 1600x1000 @ 100Hz
    # Modeline "1600x1000" 232.133 1600 1720 1896 2192 1000 1001 1004 1059 +hsync +vsync
    # 1600x1024 @ 60Hz
    # Modeline "1600x1024" 136.385 1600 1704 1872 2144 1024 1027 1030 1060 +hsync +vsync
    # 1600x1024 @ 75Hz
    # Modeline "1600x1024" 174.416 1600 1712 1888 2176 1024 1025 1028 1069 +hsync +vsync
    # 1600x1024 @ 76Hz
    # Modeline "1600x1024" 170.450 1600 1632 1792 2096 1024 1027 1030 1070 +hsync +vsync
    # 1600x1024 @ 85Hz
    # Modeline "1600x1024" 198.832 1600 1712 1888 2176 1024 1027 1030 1075 +hsync +vsync
    # 1920x1080 @ 60Hz
    # Modeline "1920x1080" 172.798 1920 2040 2248 2576 1080 1081 1084 1118 -hsync -vsync
    # 1920x1080 @ 75Hz
    # Modeline "1920x1080" 211.436 1920 2056 2264 2608 1080 1081 1084 1126 +hsync +vsync
    # 1920x1200 @ 60Hz
    # Modeline "1920x1200" 193.156 1920 2048 2256 2592 1200 1201 1203 1242 +hsync +vsync
    # 1920x1200 @ 75Hz
    # Modeline "1920x1200" 246.590 1920 2064 2272 2624 1200 1201 1203 1253 +hsync +vsync
    # 2048x1536 @ 60
    # Modeline "2048x1536" 266.952 2048 2200 2424 2800 1536 1537 1540 1589 +hsync +vsync
    # 2048x1536 @ 60
    # 1400x1050 @ 60Hz M9 Laptop mode
    # ModeLine "1400x1050" 122.000 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync
    # 1920x2400 @ 25Hz for IBM T221, VS VP2290 and compatible display devices
    # Modeline "1920x2400@25" 124.620 1920 1928 1980 2048 2400 2401 2403 2434 +hsync +vsync
    # 1920x2400 @ 30Hz for IBM T221, VS VP2290 and compatible display devices
    # Modeline "1920x2400@30" 149.250 1920 1928 1982 2044 2400 2402 2404 2434 +hsync +vsync
EndSection
# Graphics device section
# Any number of graphics device sections may be present
# Standard VGA Device:
Section "Device"
    Identifier "Standard VGA"
    VendorName "Unknown"
    BoardName "Unknown"
    # The chipset line is optional in most cases.  It can be used to override
    # the driver's chipset detection, and should not normally be specified.
    # Chipset     "generic"
    # The Driver line must be present.  When using run-time loadable driver
    # modules, this line instructs the server to load the specified driver
    # module.  Even when not using loadable driver modules, this line
    # indicates which driver should interpret the information in this section.
    Driver "vga"
    # The BusID line is used to specify which of possibly multiple devices
    # this section is intended for.  When this line isn't present, a device
    # section can only match up with the primary video device.  For PCI
    # devices a line like the following could be used.  This line should not
    # normally be included unless there is more than one video device
    # installed.
    # BusID       "PCI:0:10:0"
    # VideoRam    256
    # Clocks      25.2 28.3
EndSection
# === ATI device section ===
Section "Device"
    Identifier "ATI Graphics Adapter"
    Driver "fglrx"
    Screen 0
    BusID "PCI:1:0:0"    # vendor=1002, device=514d
    Option "FSAAMSPosY0" "0.000000"
    # === disable/enable XAA/DRI ===
    Option "no_accel" "no"
    Option "FSAAMSPosX3" "0.000000"
    # === Center Mode (Laptops only) ===
    Option "CenterMode" "off"
    Option "TVHPosAdj" "0"
    Option "TVVSizeAdj" "0"
    # === OpenGL specific profiles/settings ===
    Option "Capabilities" "0x00000000"
    Option "FSAAMSPosY2" "0.000000"
    Option "VRefresh2" "unspecified"
    # === Pseudo Color Visuals (8-bit visuals) ===
    Option "PseudoColorVisuals" "off"
    Option "FSAAMSPosX5" "0.000000"
    Option "TVStandard" "NTSC-M"
    Option "UseInternalAGPGART" "yes"
    # === FSAA Management ===
    Option "FSAAScale" "1"
    # === FireGL DDX driver module specific settings ===
    # === Screen Management ===
    Option "DesktopSetup" "0x00000000"
    Option "GammaCorrectionII" "0x00000000"
    Option "TVVPosAdj" "0"
    Option "FSAAMSPosX1" "0.000000"
    Option "FSAAMSPosY3" "0.000000"
    Option "FSAACustomizeMSPos" "no"
    Option "FSAADisableGamma" "no"
    # === disable PnP Monitor  ===
    #Option "NoDDC"
    # === OpenGL Overlay ===
    # Note: When OpenGL Overlay is enabled, Video Overlay
    # will be disabled automatically
    Option "OpenGLOverlay" "off"
    Option "FSAAMSPosY1" "0.000000"
    Option "ForceGenericCPU" "no"
    Option "StereoSyncEnable" "1"
    Option "IgnoreEDID" "off"
    Option "BlockSignalsOnLock" "on"
    Option "MonitorLayout" "AUTO, AUTO"
    Option "HSync2" "unspecified"
    Option "FSAAMSPosX2" "0.000000"
    Option "FSAAMSPosX4" "0.000000"
    Option "TVHStartAdj" "0"
    Option "FSAAMSPosY4" "0.000000"
    # === Misc Options ===
    Option "UseFastTLS" "0"
    Option "FSAAMSPosY5" "0.000000"
    # === QBS Management ===
    Option "Stereo" "off"
    # === TV-out Management ===
    Option "NoTV" "yes"
    Option "ScreenOverlap" "0"
    Option "TVHSizeAdj" "0"
    Option "TVColorAdj" "0"
    Option "GammaCorrectionI" "0x00000000"
    # === Video Overlay for the Xv extension ===
    Option "VideoOverlay" "on"
    Option "FSAAMSPosX0" "0.000000"
    Option "no_dri" "no"
EndSection
# Screen sections
# Any number of screen sections may be present.  Each describes
# the configuration of a single screen.  A single specific screen section
# may be specified from the X server command line with the "-screen"
# option.
Section "Screen"
    Identifier "Screen0"
    Device "ATI Graphics Adapter"
    Monitor "Monitor0"
    DefaultColorDepth 16
    Subsection "Display"
        Depth 8
        Virtual 1024 768
    EndSubsection
        Depth 15
        Virtual 1024 768
    EndSubsection
        Depth 16
        Virtual 1024 768
    EndSubsection
        Depth 24
        Virtual 1024 768
    EndSubsection
    #Option "backingstore"
    DefaultDepth 24
EndSection
# ServerLayout sections.
# Any number of ServerLayout sections may be present.  Each describes
# the way multiple screens are organised.  A specific ServerLayout
# section may be specified from the X server command line with the
# "-layout" option.  In the absence of this, the first section is used.
# When now ServerLayout section is present, the first Screen section
# is used alone.
Section "ServerLayout"
    # The Identifier line must be present
    Identifier "Server Layout"
    # Each InputDevice line specifies an InputDevice section name and
    # optionally some options to specify the way the device is to be
    # used.  Those options include "CorePointer", "CoreKeyboard" and
    # "SendCoreEvents".
    InputDevice "Mouse1" "CorePointer"
    InputDevice "Keyboard1" "CoreKeyboard"
    # Each Screen line specifies a Screen section name, and optionally
    # the relative position of other screens.  The four names after
    # primary screen name are the screens to the top, bottom, left and right
    # of the primary screen.
    Screen "Screen0"
EndSection
HELP? :\
dexter_II ::
Se zmeri se ti Mesa opengl driver zalavfa:|
pa je slo OK skozi instalacijo ati driverjev v linuxu ?
ni sporocu nobenih napak?
si naredu ./make.sh in ./make_install.sh?
drugace lahko malo pogledas post tukaj s podobnimi problemi?
nisi napisal kateri kernel, meni je sele z 2115 zalavfalo?
jlpktnst ::
kaj ti je napisalo pri inštalaciji driverja?
konfiguracija mi izgleda pravilno...
poglej /var/log/XF86[nekaj]... - tu nekje je log od zadnjega zagona, preberi kaj piše, napake so označene z [EE]. prilepi le relevantne stvari (če gre).
možnosti je seveda še mnogo...
ahac ::
driver je bil rpm paketk
bom jutr kaj več napisal .. zdaj sem v Winsih
ahac ::
(WW) Option "XkbOptions" requires an string value
(WW) fglrx(0): board is an unknown third party board, chipset is supported
(WW) fglrx(0): Cannot read colourmap from VGA. Will restore with default
(II) fglrx(0): doing DRIScreenInit
drmOpenDevice: minor is 0
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is -1, (No such device)
drmOpenDevice: Open failed
[drm] failed to load kernel module "fglrx"
(II) fglrx(0): [drm] drmOpen failed
(EE) fglrx(0): DRIScreenInit failed!
(WW) fglrx(0): ***********************************************
(WW) fglrx(0): * DRI initialization failed! *
(WW) fglrx(0): * (maybe driver kernel module missing or bad) *
(WW) fglrx(0): * 2D acceleraton available (MMIO) *
(WW) fglrx(0): * no 3D acceleration available *
(WW) fglrx(0): ********************************************* *
jlpktnst ::
mislim da bo to
na kratko pojdi v konzolo (ctrl+alt+F1), tipkaj brez "#":
[WW] postopek napisan je le za izgradnjo že instaliranega kernel module (driverja) posebej za tvoj sistem
[WW] instaliran mora biti rpm z driverjem in kernel headerji (paket=kernel source)
- login kot root
# init 3
# cd /lib/moduels/fglrx/build_mod
# ./make.sh
# ./make_install.sh
# init 5
če je vse pravilno boš dobil po zagonu make_install.sh opozorilo(warnin) "kernel tainted". bodi pozoren na sporočila pri tem procesu.
Če pa si to že naredil sporoči (je pa rešitev mogoče v dexterjevem linku).
v vsakem primeru pa lahko preiščeš www.rage3d.com - forum - linux
  • spremenil: jlpktnst ()
ahac ::
sem probal to.. pa pri ./make.sh napiše tole:
kernel includes at /usr/src/linux/include not found or incomplete
file:/usr/src/linux/include/linux/version.h
:O
jlpktnst ::
nimaš inštaliranih kernel headerjev -> inštaliraj paket "kernel source" (seveda iste verzije kot imaš kernel!) najbolje seveda ker s cdjev iz katerih si inštaliral linux. kateri linux pa imaš?
ahac ::
imam mandrake 9.2
bom probal...
hvala
ahac ::
hm.. mislm, da je tisto na CDjih, ki jih jaz nimam.. ne netu pa tud ne najdem..
kernel je 2.4.22 ..
jlpktnst ::
to pa je težava...
če dobiš točno isto verzijo kernela source pa ga inštaliraš bi šlo, samo ima verjetno mdk kje prirejeno, bom malo pogledal
niti mi ni všeč zadeva, njihova stran...
imam dve rešitvi:
1. najdeš USTREZEN kernel source (ali pa vsaj kernel header-je) - MOGOČE ti bo šlo z default verianto (www.kernel.org)
2. najdeš najnovejši kernel (ti tudi priporočam 2.4.22, na isti strani, ga inštaliraš IN prevedeš - tako boš prepričan da je zadeva združljiva...)
ima kdo boljšo rešitev? meni nobena ni preveč všeč.
Gandalfar ::
ahac: dej pokazi uname -a
pa ime .rpm paketka k vsebuje tvoj kernel
dexter_II ::
jest sem tudi imel probleme z napakami pri ./make.sh pa ./make_install.sh
pa sem probal vse od 20-8, 20-9 pa gcc sem instaliral
brez napak mi je pa edino naredilo pri kernel-2.4.22-1.2115.nptl.athlon.rpm in kernel-source-2.4.22-1.2115.nptl.i386.rpm (za redhat)
ce dobis ze prevedene za mandrake,fino:|
ups sem pogledal in to je Fedora:)
poglej ce kaj pomaga kernel rpm`s
ahac ::
sem najdu taprav kernel-source, inštaliral in naredil, kot je rekel jlpktnst..
DELA!
HVALA vsem!
hm.. kje je zdej un smalji, k da lupčka.. :))
No sound (Wolfenstein...)
Oddelek: Igre
152590 (2426) Slo-One
radeon 9200 suse10 brightness problem
Oddelek: Operacijski sistemi
252384 (2200) roli
Ati radeon, Xorg in Xv
101865 (1737) MasterMind
Gentoo setup problem
252208 (2032) G2
Suse 8.2 težave z grafično...
92255 (2143) norvalk
