Far Cry 1 Problem
Far Cry 1 Problem
Sandi1987 ::
Ne morem se premikati z miško ampak samo s tipkovnico. Imam 1.4 Patch in Windows 7 x64 SLO.
Moraš resetirat kontrole (Optison -> control settings -> klik na Default). To je problem s Patchem 1.4.
Sem ga imel tudi sam. Zanimivo, da so to poštimali na verziji, ki se prodaja na gog.com.
Problem: When you install "Far Cry 1.4" in Vista, the mouse works in the menus but does not work in-game.
Fix: At the main menu, go to Options -> Control Options.
Select Default -> Yes.
Go back to the main menu and exit "Far Cry."
Restart "Far Cry."
http://forums.hexus.net/hexus-gaming/88...
http://forums.filefront.com/farcry-prob...
http://www.romsteady.net/blog/2007/07/f...
Sandi1987 ::
Hvala. Dela.
Far Cry 5 (strani: 1 2 3 4 … 9 10 11 12 )
Oddelek: Igre
580118216 (43422) oo7
Far Cry 4 (strani: 1 2 3 4 … 8 9 10 11 )
Oddelek: Igre
517121499 (88705) krefi
Far cry 2 (strani: 1 2 3 4 … 9 10 11 12 )
Oddelek: Igre
564132673 (86485) Assass1n
FarCry brezplačno (strani: 1 2 3 )
Oddelek: Novice / Igre
10519450 (12577) R33D3M33R
Matto4, mod za Far Cry
Oddelek: Igre
81941 (1761) Mercenary
