Pristanek na luni s 40 letno zamudo
5 / 15
Malajlo ::
evo, zbirka PROTI in potem še več ZA. Apollo Moon Landing hoax conspiracy theories @ Wikipedia
Malajlo ::
Zdej me pa samo še zanima, če sem res blesav...
...al so si kamni res podobni ter enako odaljeni drug od drugega. Ozadje oziroma hribi so res malo drugačni, vendar pomoje zaradi drugega kota kamere. Ja, pa nasa naj bi rekla, da je blo to slikano na različnih lokacijah.
No, se mi je zdelo, da nekaj minut narazen, ne milj.
Bad: The other ``identical background'' segment shows an astronaut on a hilltop. A second video shows two astronauts on the same hill (and this time it really is the same hill), and claims that NASA itself says these two videos were taken on two different hills separated by many kilometers. How can this be? They are obviously the same hill, so NASA must be lying!
Good: Never attribute to malice what you can attribute to a mistake. A videotape about Apollo 16 ironically titled ``Nothing So Hidden...'' released by NASA does indeed make that claim, but in this case it looks to me to be a simple error. I asked Eric Jones, who is the editor of the Apollo Lunar Surface Journal, and he told me those two clips were taken about three minutes apart. Eric's assistant, Ken Glover, uncovered this problem. He sent me this transcript (which I edited a bit to make links to the video clips) of the Fox show with his comments, which I will highlight in red:
[.... v linku...]
So that's why the hill looks the same. It's the same hill, and the two clips were not taken a day apart, but from three minutes apart or so. Again, had the program producers bothered to check their sources, they would have received a prompt answer. That's all I did: I emailed the editor of the ALSJ. It was pretty easy to do, and he answered me in minutes.
Tale, ki je tole sestavil, je bil res togoten. link Zbrana dela, lol
Azrael ::
Bravo!
Končno ena konstruiuktivna samokritika v vsem smetju, ki si ga prilepil do sedaj.
Nekoč je bil Slo-tech.
dbevfat ::
@Malajlo: dober link
The project involved about 20000 companies, 200 Universities, 80 Research institutes and over 400000 people along with the former USSR agencies spying on the USA, which is impossible to cover-up information by killing a few dozens of highly unrelated astronauts.
(Citat s konca odstavka.)
Torej, kot ponavadi pri teorijah zarot, tudi ta zaide v slepo ulico. 400K vpletenim ljudem je ratalo vsa ta leta skrivati dejstvo, da je vse skupaj nateg. Nor dosežek.
nvr2fat
Malajlo ::
Slabih 150 mio ljudi v USA ne ve, na kateri strani je Pacifik in nakateri Atlantik. Pol mio ljudi ni nič. ;)
Ne, saj linki so podoben vir kot tisti, ki jih hoaxerji lepijo. Ampak nekako mi zdrava pamet govori, da bolj verjamem prvim.
kotnikd3:
MrStein
ne govori o stvareh, o katerih nimaš pojma.
A lahko to malo obrazložiš ?
Aja, aplavz za omembo Flat Earth Society, ti so šele pacienti. Stran sem jim že videl, tal FAQ pa je prijetno presenečenje. :D
ROTFL !
dbevfat ::
ne gre za to, kako neumni so. Gre za to, da ne obstaja skrivnost, ki jo lahko 400K ljudi skriva 40 let. :)
nvr2fat
carot ::
Ponavadi se skrivnosti skriva za 50 let in ne samo 40, tko da bomo morali pocakati se kakih 10 let za resnico, ker neki okoli lune dosbesedno smrdi, ker je res premalo informacij glede nje, kar daje sumini, da nekaj prikrivajo. Me prav zanima, kako so ta zgodovinski trenutek predvajali v javnosti, oziroma, kje bi se dalo dobiti vse o tem zgodovinskem trenutku. Bi morali narediti kdaj intervju z armstrongom na skrivaj, ker verjetno je pod kontrolo, da bi vidli, kaj bi rekel, aja, sem pa videl enkrat en dokumentarec, ko so jim dali biblijo astronavtom, da naj priznajo na njej, da so bili na luni in marsikdo ni mogel priznati, ker ocitno so veliki verniki, booo.
urban99 ::
tole analiziraj - redkokdaj dobi človek toliko informacij v štirih sekundah ;)))
carot ::
Ja dober link, sej zraven je bil tudi tale, samo zdaj so ocitno izbrisali AUDIO, google and youtube is watching you, sej zraven je ogromno povezanega materjala.
Zanimivi posnetki iz "lune".
Nobene slike astronavtov z odprtim vizirjem.
http://news.nationalgeographic.com/news...
Kako fantazirajo iti na luno leta 2012. Ma kaj se bodo sli peljati po luni ali kaj? Dandanes pa je sploh enostavno fejkat polet na luno, saj nocejo ponoviti napak iz preteklosti.
  • spremenil: carot ()
carot ::
http://history.nasa.gov/alsj/a16/a16f.g...
Tle se res ne vidi dlje kot 100m
http://history.nasa.gov/alsj/a16/video1...
Tle je pa arhiv nasinih posnetkov v nizki resoluciji sramota, pa se ogromno manjka.
hamax ::
Ok. Se ne vidi. In kaj to pomeni? Da je bil studio dolg ravno 100m in so dali na koncu kar crne zavese, ali da so morda na hribu?
Kaj?
Se strinjam.
Ja, moon hoaxerji.
BigWhale ::
Ta link je neuporaben. Ne dokazuje nic. Nekaj napisov in brez audia. Ta link je dokaz, da na YouTube brisejo copyrighted material.
Bravo! ;)
Ja, res so. Povej kaj dokazujejo. Meni se ne zdi nic spornega na tem posnetku. Na Luni so se astronavti premikali tako pocasi in okorno tudi zaradi skafandrov. Stvar je precej nerodna. Ce potem zavrtis vse malo hitreje zgleda hecn. Sploh, ko meceta tiste predmete po zraku. Si videl kako je letela tist 'cunja' karkoli je ze bilo. Tako kot, da ne bi bilo zraka! :) Pa poglej kako se prah obnasa. Nic ni vrtincenja prahu in prahu v oblakih, ker bi za tak 'efekt' potreboval zrak, v katerem bi se prah vrtincil. Tako pa samo 'sprica' naokrog in pade na tla brez vsakrsnega upora.
In kaj to dokazuje? Sej niso sli gor turiste spilat. "Jaz in ta skala, jaz in una skala, jaz in kup peska, jaz in dve skali ..." Zaprti vizirji? Ves zakaj, zato, ker bi astronavti prehitro oslepeli, ce bi stalno gledali z odprtimi vizirji. Luna je precej svetla rec in tudi odbita svetloba iz luninih tal je zelo mocna.
V tem videu so rekli 2020 :) A vseeno, kaj to dokazuje?
Malajlo ::
Kakšen jutjub... Linke z nasine strani lepite, potem se pa pogovarjamo. Ta montiran jajc na jutjubu je pa res referenca.
Sploh pa kaj vse ljudje vidijo v teh posnetkih. Eden je recimo s teleskopom snemal luno, pa je avion mimo priletel. In iz tega potem delajo teorije, da je pa 380.000 km daleč en avion mimo priletel. Ki je sploh NLP, ne pa B747!
Mal pameti v roke in je svet takoj bolj enostaven.
tinlad3n ::
Ma takrat sploh niso mel tehnilogije za tako kvalitetno montažo posnetkov, saj video sploh še ni bil dobro razvit.
Pa, ko mečejo stvari eden drugemu, a to so tud montiral? Ko roko premakne je v normalni hitrosti, potem ko leti predmet je počasi itd...???
Malajlo ::
Gor so peljali ene prvih video kamer, ki so zmogle 10fps, resolucija je bila pa 320 vrstic. Nekaj takega kot prve VHS kamere. Ki so naredile crap od slike, ampak takle smo imeli takrat. Fant, pisalo se je leto 1969!!! Tukaj o foto opremi
Ne štekam, kaj bi rad povedal? Če sem prav videl, leti predmet v horizontalni smeri z enako hitrostjo kot se je premikala roka. Ker pa je gravitacija 1/6 Zemljine, tvoji predsodki in navajenost 1G ne morejo dojeti počasnejšega letenja.
tinlad3n ::
Ma sej sploh ne znam razložit, kaj hočem povedat :D Uglavnem moje mnenje je tako, da takrat niso bli sposobni narest takih video montaž, kot pravjo moonhoaxerji.
Malajlo ::
Itak da so jih lahko naredili. Saj veš, NASA pa hightech.
Ampak, zlomek, jih niso.
White&Nerdy ::
Pomoje če bi jih naredili nebi blo tolko "kao napak" v slikah in filmu... Bi se verjetno že bolj potrudili ne?
tinlad3n ::
Pisalo se je leto 1969. Hightech my ass. Če so to ponaredki, so še danes odlični ponaredki. Pa vemo, da tudi danes narejene ponaredke hitro najdemo in jih razvozlamo.
Malajlo ::
Če govorimo o ponaredkih, poglej Armagedon. Tipi pristanejo na meteoritu, roba pada stran kot ob potresu na Japonskem, po površini hodijo kot po zemlji, medtem ko drillerji letajo po luftu... Če so tako mimo butnili pred leti, kaj bi šele naredili za Luno. Torej, ni ponaredkov in BILI SO GOR 20.7.1969@20:17 in Armstrong je stopil na Luno 21.7.1969@02:56!!! (časi so UTC, leta 1969 pa poleti še nismo premikali ur, zato prištej eno uro zraven)
Če bi živel takrat, bi bil ziher pred TVjem (najbrž pri sosedu, ki je delal v Nemčiji) in celo noč buljil v ekran. Heh, B&W romantika...
Malajlo ::
Ker je ravno 40letnica, me Apollo 11 precej matra.
In medtem, ko brskam po fotkah in podobnem, recimo tudi na brezvezni fotki
sence niso vzporedne. Zakaj hoaxerji te fotke nikoli ne priložijo med dokaze?
Na tejle ima astronavt noge krive! Poglej senco, pa ti je takoj jasno, da Armstrong ali pa Aldrin ne moreta biti, ker nista fuzbalerja! In da ne omenjam kabla, ki je viden. O tem NASA nikoli nič ni rekla! Hoax!!!
Malajlo ::
Križci, 77-ič...
križec skoraj izgine na belini nahrbtnika. Optika in fizika je jasna zdaj?
hamax ::
A se sence v studiju obnasajo drugace kot na luni?
Malajlo ::
Menda. Ker je izvor svetlobe preblizu objektom.
Ja, pa v studiju tudi veljajo drugačni fizikalni zakoni ! ;)
driver_x ::
A so imeli pod skafandrom plenice ali so jim dali kateter?
Launch čez dobrih 20 minut !!!
http://wechoosethemoon.org/
Malajlo ::
Yes!!!!!:D
doh, je že preobremenjeno ... minuto in pol pred izstrelitvijo :(
bi lepo multicast uporabili ...
PaX_MaN ::
Men samo zvok ne dela. :(
Ja, saj drugega tak ne oddajajo ;)
Sem se probal na mail listo prijaviti:
A system error occurred while processing your request.
A to je ista firma delala kot londonsko borzo ? :|
Malajlo ::
Heh, background se sliši, ampak capcom in ap11 pa ne...
Background je nekajsekundni posnetek, ki se ponavlja.
Se je komu uspelo na mail listo prijavit ?
Je kaki arhiv, da bi za nazaj prebral ?
Malajlo ::
Da best :D
Jst ::
V Operi mi prikaže samo črnino... :// Poslušam prek IE7. menda drugič pognan .exe na tej nekajletni inštalaciji OSa.
Whe Choose The Moon
Svaka jim čast, da so uspeli pred 40imi leti!
vorantz ::
vsi hoaxerji pozabljate važno dejstvo...
ful teh teorij so začeli taki ljudje :))
sprasujem ::
Zakej ne iščemo dokaz zdaj, ne pa posnetke nazaj? A niso Američani al Rusi oznanil del Lune kot svoje s postavitvijo zastav in jih pustil tam? Kje so zdej vse te zastave? Zakaj jih Hubble teleskop ne posname danes.Al so vse na napačni strani Lune. So vse postaljene na hrbtni strani,stran od vidika Zemlje? Naj mi na to nekdo odgovori! Pa ne mi rečt, da jih je skrbelo onesnaženje?
sprasujem> Naj mi na to nekdo odgovori!
Hubble lahko na luni vidi le reči, ki so več sto metrov velike. Namenjen je fotografiranju galaksij, ne pa zastav.
Opkow ::
Ti pa res samo sprasujes... Beres pa nic, ne?
PrimozR ::
VCASIH JE POMEMBNO, KAJ VSE NE VIDIMO, POLEG TEGA, TUDI DANDANES NIMAMO SE TELESKOPA, KI BI LAHKO POTRDIL, ALI SMO BILI NA LUNI ALI NE, TAKO, DA NEHAJTE FANTAZIRATI O RUSIH, DA SO TAKRAT OPAZOVALI VSE, KER NI BILO SE TEHNOLOGIJE NA RAZPOLAGO, SAJ JE NITI DANDANES NI!!!!
Teleskopa ni iz preprostega razloga, ki je tukaj napisan - moral bi biti 'Hubble' z 250 m ogledalom. Praktično? Hja, ne. Tehnologije pa res ni. Sploh še nismo bili v vesolju rpavzaprav. Vse to so samo amaterske rakete in samo izgledajo kot da grejo neki ful visoko. Satelitov ni, Hubble je pofejkan, it's all a lie.
Kaj ti streljas zdaj na pamet o teleskopu z 250m diagonalo ali kaj? Glede tehnologije, pa mislim, da sem se malo zlagal ko sem reku, da je ni, saj ali ste pogledali google? Zakaj imamo tam tako podrobne slike, saj lahko vidimo avte, itd..., tako, da tehnologija je in to ze vec let, na luno in mars pa posiljajo staro tehnologijo, kjer je resolucija maximalno 10 metrov na pixel, vsaj uradno za javnost tako, pa se te slike ne objavijo kaj dosti, oziroma jih sproti umaknejo, saj sem videl ze marsikatero sporno sliko.
Ker je z zemlje do lune 250 milijonov milj oz. 400 milijonov kilometrov, iz zemljine orbite pa kvečjemu 100-150? In ne, ne milijonov, 100-150 km. Hubble je na višini 480 km (cirka).
tinlad3n ::
Od zemlje do lune je 400.000 km ne pa 400 mil. km. :D
In precej ljudi verjame, da Hubble lahko posname ne le zastave, ampak tudi stopinje na Luni... Saj je vendar Hubble!
BigWhale ::
Ja, zdej k ma ocala ziher lahk! :P
tinlad3n ::
Haha.
No vglavnem pri mythbusterjih so z laserjem namerili na luno, namesto, kjer je apollo 15 pustil tiste odbojnike svetlobe in so nazaj prejeli fotone, ko pa so namerili na random prostor na luni pa ni bilo nič. Beat that moonhoaxers.
tinlad3n> No vglavnem pri mythbusterjih so z laserjem namerili na luno, namesto, kjer je apollo 15 pustil tiste odbojnike svetlobe in so nazaj prejeli fotone, ko pa so namerili na random prostor na luni pa ni bilo nič.
Mislim, da to ni dovolj jasen dokaz. Če si moonhoaxer, potem nič razen avtobusne vozovnice do Morja miru ne bo dovolj dobro.
5 / 15
Sojuzova raketa odpovedala, astronavta varno ušla
3728217 (24528) jerry_p
Pred pol stoletja je Apollo 1 spremenil varnost vesoljskih poletov
3510002 (7840) Invictus
Orion Flight Test - danes 13.05
3412295 (11287) PrimozR
Raziskovanje osončja: NASA uradno naznanila projekt Orion, Rusija in Kitajska načrtuj (strani: 1 2 )
9616905 (15268) Gundolf
