Problem s trdim diskom pri instalaciji WINDOWS XP
Tullio ::
Ko bootam xp ...se vse lepo zažene, vendar ko pride do Setup is now starting windows al nekaj takega, se mi prikaže moder zaslon s tekstom:
"A problem has been detected and windows has been shut down to prevent damage.
blabla...
Check for viruses on your computer. Remove any newly installed hard drives or hard drive controllers. Check your hard drive to make sure it is properly configured and terminated. Run CHDSK /F to check for hard drive corruption and then restart your computer.
Technical information:
*** 0x0000007B(0xF7C7....
Vse kar je navedeno zgoraj sem tudi storil...ampak nič ne pomaga...
Kaj je narobe?
Hvala.
**edit: sem slikal zaslon: http://img201.imageshack.us/img201/5097/dsci1805le7.jpg
  • spremenilo: Tullio ()
Tr0n ::
Tezava s hardwarom.
Tullio ::
s čim pa?
Problem z diskom : 0x0000007B error
82831 (1880) crayz43
Asrock 939 dual (strani: 1 2 3 4 … 12 13 14 15 )
72945707 (26266) igor0203
Slo-Tech NEST 06 slike
Oddelek: Slo-Tech
359054 (5303) Good Guy
en windows
Oddelek: Operacijski sistemi
111188 (1090) Good Guy
Če bi imeli na STju izbiro svojega avatarja, kakšnega bi imeli?
372534 (1830) Tarzan
