cygwin in gcc instalacija
OmegaM ::
Pozdravljeni!
Imam eno tezavico
Instaliral sem si CYGWIN, vendar nisem zravenm instaliral gcc, sedaj pa hocem posebej instalirat pa se mi naredim vse lepo kot pise:
# Install Cygwin, including the gcc and make packages, if you have not already done so.
# Download the W3C libwww libraries, as sources or precompiled binaries, and save them in your Cygwin home directory (normally this will be c:\cygwin\home\your-Windows-login-name).
Perform the remainder of the installation from within a Cygwin terminal window.
# If you downloaded the sources: Unpack, compile, and install them using these commands:
tar xfvz w3c-libwww-5.4.0.tar.gz
cd w3c-libwww-5.4.0
./configure --with-zlib //do sem mi vse lepo uspe
make //od make naprej pa ne, ker mi ukaza ne najde
make install
Kaj storiti?
Hvala
Ni nam lahko, bo pa boljše!!!
Windows 10 bo dobil bash! (strani: 1 2 3 )
11463247 (55514) Jst
Microsoft odgovoril Evropski komisiji (strani: 1 2 )
Oddelek: Novice / Tožbe
639177 (8085) MrStein
[C] random do poljubne številke
Oddelek: Programiranje
172493 (2160) napsy
[Flamewar] Firefox in mogočna vrnitev IE (strani: 1 2 )
606148 (5404) veteran
Suse 9.0 (strani: 1 2 )
Oddelek: Operacijski sistemi
666330 (5616) moj_nick
