Forum » Programiranje » [C] random do poljubne številke
drejc ::
Imam en zlo simpl problem. Kako dobiti random stevilko na intervalu recimo 0-16 v gnu c?
Cifre so vedno večje od 16, čeprav je rand max spremenjen kot je navedeno v dokumentaciji. Če ne uporabim srand(time(0)) je output vedno 0.
#include <stdlib.h>
#include <stdio.h>
#define RAND_MAX 16
int main() {
srand (time (0));
int num1 = rand();
printf("random iz %d rand max is %d \n",num1,RAND_MAX);
"Rise above oneself and grasp the world"
- Archimedes of Syracuse
napsy ::
poskus tole.
int rand(int od, int _do)
return ((rand() / (double)do) + _od);
"If you die, you die. But when you live you live. There is no time to waste."
gumby ::
x=RAND_MAX/16;
y=rand()/x;
takole probaj
edit:
"#define RAND_MAX" brisi, to je ze v headerju doloceno, kot mora biti.
y=rand()/x;
takole probaj
edit:
my brain hurts
- spremenil: gumby ()
Alec999 ::
nevem sicer zakaj ne uporabis npr.
#define MOJ_MAX 16
int num1 = rand() % MOJ_MAX;
ampak OK. Mogoče bi ti ustrezala spodnja rešitev:
#define MOJ_MAX 16
#include <stdlib.h>
#include <stdio.h>
#include <time.h>
#ifdef RAND_MAX
#undef RAND_MAX
#define RAND_MAX 16
#define rand() ( rand()%RAND_MAX )
#endif
int main()
srand (time (NULL));
int num1 = rand();
printf("random iz %d rand max is %d \n",num1, RAND_MAX);
return 0;
BigWhale ::
man srand
Vsega deset udarcev po tipkovnici...
In Numerical Recipes in C: The Art of Scientific Computing (William H.
Press, Brian P. Flannery, Saul A. Teukolsky, William T. Vetterling; New
York: Cambridge University Press, 1992 (2nd ed., p. 277)), the follow-
ing comments are made:
"If you want to generate a random integer between 1 and 10, you
should always do it by using high-order bits, as in
j = 1 + (int) (10.0 * (rand() / (RAND_MAX + 1.0)));
and never by anything resembling
j = 1 + (rand() % 10);
(which uses lower-order bits)."
Random-number generation is a complex topic. The Numerical Recipes in
C book (see reference above) provides an excellent discussion of prac-
tical random-number generation issues in Chapter 7 (Random Numbers).
- spremenil: BigWhale ()
drejc ::
Ok tnx, sem potem tut sam pogledal man...silly me :).
Zanima me, kak zdej ta exe pripravim do tega da se bo lahko poganjal iz windows konzole. Namrec skompajlal sem zadevo znotraj cygwin okolja in se mi potem pritozuje da ne najde cygwin1.dll. Je mozno da zlinkam tale dll zraven v exe nekako?
drejc ::
no, ce dodam -mno-cygwin flag v ccju sicer lahko poganjam v win cmd.exe, le random ni ravno random...spremeni se vsakih 10 sekund pa se to samo za +1.
drejc ::
Taka je koda, output je ravnotako isti oz se poveca +1 na vsake par sekund tudi ce skompajlam z minGWjem.
#include <stdlib.h>
#include <stdio.h>
#include <time.h>
int main(){
int j;
int k;
srand(time(NULL));
j = 1 + (int) (356.0 * (rand() / (RAND_MAX + 1.0)));
k = (int) (357.0 * (rand() / (RAND_MAX + 1.0)));
printf("nakljucna stevilka na intervalu 1 do 357 je %d \n",j);
//printf("nakljucna stevilka na intervalu 0 do 357 je %d \n",k);
Gundolf ::
Se kaksn rand() prej klic pa se bo spremenil. Tale srand in time ocitno nista najboljsa kombinacija na mingw-ju.
drejc ::
En rand() prej klicu in zadeva gre skroz tudi pod cygwinom z -mno-cygwin flagi.
A je to kaksen poseben razlog zaka je treba random klicat dvaput?
Gundolf ::
Očitno rand tako deluje, da najprej vzame seed in (pogojno) vrne rezultat, potem pa šele popravi seed, za naslednjo random številko. Ker je seed nastavljen na trenutni čas potem dobiš to, kar si ti dobil, da je prvi rand dokaj povezan z nastavitvijo seeda, se pravi s trenutnim časom. To bi lahko bil razlog, čeprav ne vem zakaj bi rand tako deloval.
BigWhale ::
capybara code $ ./lala
nakljucna stevilka na intervalu 1 do 357 je 332
nakljucna stevilka na intervalu 1 do 357 je 104
nakljucna stevilka na intervalu 1 do 357 je 55
nakljucna stevilka na intervalu 1 do 357 je 180
nakljucna stevilka na intervalu 1 do 357 je 131
nakljucna stevilka na intervalu 1 do 357 je 258
capybara code $
Na Linuxu dela povsem ok...
Ce pa kdaj vrne isto vrednost je pa to takrat, ko pozenes program v isti sekundi.
Must be a cygwin thing... Or windows
Gundolf ::
Ja definitivno se v winsih tko obnaša kot Drejc pravi. Lahko pa da je seveda to gcc 3.4.4 thing :)
'FireSTORM' ::
to je zaradi srand(time(NULL));
pognal programček 3x v sekundi:
fire@xendria:~/programing$ ./test
1182293401
1182293401
1182293401
pa koda:
time jemle čas samo po sekundah, ne zavzema stotink itd. zato je tudi logično v enaki sekundi enak time, z srand pa "ustvariš" random pool
če bi v srand dal kakšno vrednost ki je v vsakršni stotinki različna bi blo že drugače...
Jaz sem to "rešil" tako da sem večkrat klical srand, prvič z time, potem sem zrandomiziral še eno cifro velikosti do 235446 in z tem še enkrat zagnal srand, torej:
srand(nova_randomized_stevilka);
Če že rabiš vsako stotinko drugo številko, jaz sem jo :P
1182293401
1182293401
1182293401
pa koda:
int main()
cout << time(NULL) << endl;
return 0;
Those penguins.... They sure aint normal....
- spremenil: 'FireSTORM' ()
napsy ::
seed problem pri rand() funkciji bi lahko rešil takole:
Ali pa bi uporabil kernel drajver za random števila kot je to že nekdo prej omenil:
#include <stdio.h>
#include <stdlib.h>
#include <sys/time.h>
#include <time.h>
int main()
struct timeval tv;
gettimeofday(&tv, NULL);
srand(tv.tv_sec + tv.tv_usec);
printf("Random: %d\n", rand());
return 0;
#include <stdio.h>
#include <stdlib.h>
int main()
FILE *rnd_f;
int n;
rnd_f = fopen("/dev/urandom", "rb");
fread(&n, 1, sizeof(int), rnd_f);
printf("Random: %d\n", n);
fclose(rnd_f);
return 0;
'FireSTORM' ::
Za /dev/urandom sem slišal da vendarle ni tako random...baje
kolko je resnice v tem nevem, ker nisem ravno šel raziskovat
napsy ::
Če /dev/urandom ne zadošča pa zato openssl knjižnica ponuja izvrstne algoritme za generacijo psevdo-random števil.
... en grdi hek
... en grdi hek
#include <stdio.h>
#include <stdlib.h>
#define RND_LEN sizeof(int)
int main()
FILE *ssl_rnd;
char cmd[64];
int n;
sprintf(cmd, "/usr/bin/openssl rand %d", RND_LEN);
if ((ssl_rnd = popen(cmd, "r")) == NULL) {
perror("Zagon openssl spodletel");
exit(-1);
fread(&n, 1, RND_LEN, ssl_rnd);
printf("Random stevilo: %d\n", n);
pclose(ssl_rnd);
return 0;
- spremenil: napsy ()
| » | Vprašanje v zvezi z rand() funkcijoOddelek: Programiranje | 7436 (6626) | fireice |
| » | [C++] Generiranje naključnih števil tipa doubleOddelek: Programiranje | 2222 (2131) | mn |
| » | C++Oddelek: Programiranje | 1548 (1284) | BALAST |
| » | [C] Random funkcijaOddelek: Programiranje | 2764 (2595) | primozsu |
| » | srand in program v Cju???Oddelek: Programiranje | 1901 (1771) | nuclear |
