Chemtraili ali "kemični repi" so neobičajne sledi za neidentificiranimi reaktivnimi letali
A paper published by the National Academy of Sciences in 1992, "Policy Implications of Greenhouse Warming: Mitigation, Adaptation, and the Science Base," speculates that commercial airliners could use contrails or spread dust to combat global warming.
In the geoengineering section of the study (p.459), the paper states, "Cloud stimulation by provision of cloud condensation nuclei appears to be a feasible and low-cost option capable of being used to mitigate any quantity of CO2 equivalent per year."
The paper also says, "These possibilities appear feasible, economical and capable of mitigating the effect of as much CO2 equivalent per year as we care to pay for ... Such systems could probably be put into full effect within a year or two of a decision to do so, and mitigation effects would begin immediately."
We are fine without wings.
Arto ::
  • spremenil: Arto ()
arto
cloud!=could
PaX_MaN ::
And the decision is where to be read?
PacificBlue> cloud!=could
S tem si želel povedat, da ne znaš angleško?
Arto ::
arto
cloud!=could
Sem popravil skoraj takoj. :P Ampak moj point še vedno velja.
823483 ::
Samo nekaj...kaj so zdaj Chemtraili? Snovi, ki naj bi jih metali z letal in naj bi ohlajevale zemljo ali snovi, ki naj bi jih metali z letal in naj bi zastrupljale ljudi? Ali kar oboje skupaj?
Če je oboje skupaj, kakšen problem je reči, da so iznašli rešitev za globalno segrevanje, po medijih sporočiti, da je stvar popolnoma neškodljiva, zadržati informacije o učinkovinah oz. lagati o njih in potem to vreči v zrak? Ne bi bilo prvič...
bluefish ::
Dejansko še naši vrli hoaxerji nimajo pojma ali enotnega stališča - enkrat so bili takorekoč železovi opilki, drugič neka super-duper spojina, kmalu so nastali virusi odporni na grozne temperature etc.
  • spremenil: bluefish ()
Matev ::
spet bo kak zarotnik prilimal kako angleško besedilo
Karaya 52 ::
swamigi> Lep primer,kako pilot vključi in izključi škroplenje večkrat.
To letalo niti približno ne leti na 6000 čevljih, kar je borih 2000m. Lahko zaključimo da je avtor posnetka (ne swamigi) bedak, ki se spozna na letalstvo toliko kot zajec na boben. Prikazano letalo leti vsaj na 25.000 čevljih kjer pa se contrails dejansko tvorijo (odvisno od kupa dejavnikov).
swamigi> Ni res. Ta letala so potniška letala. Letala imajo na zadnjem delu dodatni rezeorvar ki je popolnoma neodvisno od letala. Pumpo se krmili iz tal oz preko satelitov.
Druga neumnost. Piloti v vzletno maso letala računajo še kovčke ki jih potniki zložijo v nadglavne prtljažnike. Vsak potnik dobi točno določen sedež (izjemnega pomena za ohranjanje težišča), razen takrat kadar so vsi sedeži polni. Po tvoji "logiki" so letalom vgradili dodatne rezervarje v zadnji del letala, brez da bi pilote obvestili o dodatnih 5000l - 10000l? Se zavedaš kakšna neumnost je to?
In 1990, a NATO report detailed how high-flying aircraft can modify the atmosphere by spraying polymers to absorb electromagnetic radiation.44 U.S. patent number 6315213 describes how cross-linked aqueous polymers dispersed into a storm diminish rain.
http://www.patentstorm.us/patents/63152...
Arto ::
In kakšno vezo ima to s "chemtraili"? Tukaj je govora o šprejanju oblakov (bolj natančno o preprečevanju dežja - snov tvori skupaj z vodo želatinasto zmes), zakaj potem to pršijo po jasnem nebu?
Zato, ker oboje vpliva na vreme. Pa še na Haarp ne pozabi.
PaX_MaN ::
Še zahvalit bi se jim moral, da tako skrbijo za naše zdravje:
7. The methods of claim 1 wherein said aqueous solidifier is biodegradable and nonhazardous.
  • spremenilo: PaX_MaN ()
Hm, hm
Polymer chemist Dr. R. Michael Castle has studied atmospheric polymers for years. He has found that some of them contain bioactive materials, which can cause "serious skin lesions and diseases when absorbed into the skin."46 He has identified microscopic polymers comprised of genetically-engineered fungal forms mutated with viruses. He says that trillions of fusarium (fungus)/virus mutated spores, which secrete a powerful mico-toxin, are part of the air we breathe.
PaX_MaN ::
Ajde, najdi enega izmed teh, ki so v "some of them", v tem patentu. Oziroma, ne!, napiši kemijsko formulo/ime/LD50 vsaj enega izmed teh, ki naj bi bili strupeni k' svina.
swamigi ::
Jaz že cel čas pravim,da so tole vojaška letala.Tile piloti,ki pa škropijo te zadeve pa dobro vedo kaj delajo.
Vi,ki pa govorite da so te sledi bile na nebu v 70,80,90-ih pa ste očitno podlegli subliminiram sporočilom v reklamah,filmih....
Gandalfar ::
pravis da je tisti video iz leta 44 fake?
bluefish ::
Torej tisti osamljeni raziskovalni center sredi puščave? Ja, ta ima nedvomno globalen vpliv.
dzinks63 ::
Res, da je vse skupaj v loži, samo forumaše imeti za omejene pa vseeno ne spada zraven. Daj zresni se malo, dvakrat si preberi in si razloži kaj tipkaš, preden oddaš sporočilo.
swamigi> Vi,ki pa govorite da so te sledi bile na nebu v 70,80,90-ih pa ste očitno podlegli subliminiram sporočilom v reklamah,filmih....
Prosim, če mi lahko poveš, kaj bi smatral kot dovolj dobro potrditev, da "chemtrails" ne obstajajo. Hvala.
(Če meniš, da se tega ne da dokazat niti z vzorčenjem kondenzacijskih sledi letal, potem tako in tako verjameš tudi v duhove.)
Karaya 52 ::
Dragi oz. swamigi te slike sta posnela v četrtek? Povej ob kateri uri, kje točno si stal in v katero smer si slikal. Gotovo so letala na jetway UL74, kjer je minimalna višina leta 25000 čevljev (zanimivo, ravno na tej višini se contrailsi že tvorijo). Registrsko cifro letal dobiš v petek. Tega jajcanja mam že dovolj.
Highlag ::
@ jype
V bistvu sem tegale mislil : http://www.flickr.com/photos/spixworth/...
borisk ::
lasek je nardil na svečki :))
McMallar ::
Pa ja de... Se še spomnim, ko smo 2-3x na teden zagledali letalo na nebu in se drli: "Glej ga, črto dela!" In glede na mojo starost lahko rečem, da se je to dogajalo že v 80-ih in 90-ih letih.
Because OCT31 = DEC25
Highlag> V bistvu sem tegale mislil : http://www.flickr.com/photos/spixworth/...
To je C-130 Hercules. C-30 ni Hercules, temveč Volvo.
PaX_MaN ::
Z cimrom sva zdej v Četrtek šla V Villach v Avstriji in ko sva se vračala sem posnel te slike. Se oproščam če je kvaliteta mal slaba, slikano je bilo z telefonom.
Prve slike sem posnel na Avstrijski strani prelaza Vršič (semaforji so bli zjebani in je rdeča luč gorela več kot pol ure tako da smo stali na mestu). Kasnejše so slikane na SLO strani.
Enjoy.
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
Slike so "as is", se pravi, niso bile editirane na nikakršen način. Nisem niti spreminjal kota pod katerim so bile slikane, da ne bo slučajno kdo reku da sem uporabljal photoshop.
Na prvi sliki se lepo vidi avio in chemtrail ki ga pušča za sabo. Ta isti chemtrail se je iz jasne drobne črte v zraku razširil v velikansko megleno črto ki se je PREMIKALA Z VETROM. Kondenzacija za avionom pač tega NE DELA več kot URO!
Na eni od vmesnih slik se lepo vidi primerjava med dvema letaloma ki letita na približni višini (sam zaradi drugačne smeri leta izgleda kot da je eno dosti nižje) kjer eden spušča chemtrail, drugi pa ne.
Na zadnjih slikah pa se lepo vidi kako so se tiste čist tanke črtice "contrail" razširile v velikanske meglice primerljive velikosti oblakom. Contrail to pač JASNO da NI!
Nevem no, do zdej sem vedno mislu kako se to dogaja samo v USA in kako je to pri nas redko in ni treba skrbet sploh, sam ko sem vidu kako so 4 letala to naredila nad Avstrijsko-Slovensko mejo in je potem vse prineslo k nam...
Kaj lahko sploh narediš? Mislim, koga na gavge zarad genocida?
Edit: se oproščam. Ko sem še enkrat gledal slike sem opazil, da je prva slikana v Avstriji (in ne SLO kot sem reku).
Swamigi:
[i]Ker ta letala,ki škropijo so vojaška predelena letala posebej za to nalogo :)[/i]
Ni res. Ta letala so potniška letala. Letala imajo na zadnjem delu dodatni rezeorvar ki je popolnoma neodvisno od letala. Pumpo se krmili iz tal oz preko satelitov. Na začetku v preizkušnji so imela to samo vojaška letala ja, sedaj pa ko je projekt v zadnjem stadiju pa imajo to po večini vsa.
Call me blind, toda jaz na teh slikah ne vidim niti enega letala... Na čem torej temelji tvoja ocena, da je tole delo letala? Si morda videl koliko motorjev je imel? Njegovo identifikacijsko številko na repu? Vse kar vidim, je meglica, ki je posledica kondenzacije vode, ko trčita vlažen topli in suh mrzli zrak.
msjr ::
Dragi chemtrail otroci, dobro se spomnim, da smo se v vrtcu igrali, da če se dve črti od aviona prekrižata si lahko kaj zaželiš. To je bilo v sedemdesetih, črt nad Slovenijo je bilo veliko (recimo več kot v devetdesetih, ko je letalski promet zaradi sranja v bivši jugi zamrl)
V otroški knjigi o vremenu, ki sem jo dobil na začetku osemdesetih, se še dobro spomnim besedila, ki je govorilo nekako takole (citiram po spominu):
Po črtah, ki jih za sabo puščajo letala, lahko sklepamo ali bo naslednji dan lepo vreme. Če je črta debelejša in ostane dolgo časa na nebu, je velika možnost da bo jutri dež.
Če bi hoaxerji prebrali vsaj to knjigo, bi se vprašali kakšne idiotizme klatijo. Če pa ne naj se spomnijo na Occamovo britev in se potem vprašajo kaj je res.
BigWhale ::
Ja, po occamovi britvi je tole z vremenom trapast!
EDINA! Logicna razlaga je, da letala zastrupljajo ozracje.
Res!
SanAndreas ::
PaX_MaN -> Se strinjam s tabo, takih chemtrailov sem videl skoraj vsak dan na nebu in to že pred 3 leti. Strupi padajo po vsem svetu in mi to dihamo. Kakšno s*anje na kubik! :P
SanAndreas je doma iz Rimske Galaksije ima srebrn NLP :)
veteran ::
Čez Vršič si prišel v Avstrijo? Dobra. :)
iggy ::
hahahaha razloži kje meji vršič z avstrijo ;((
Hey, you're fat!
PaX_MaN ::
Vau, že pred tremi leti si videl te domnevne kemtrejle? Stari, a se te lahko dotaknem?
Kaj boš pa rekel na to, da so te vaše meglice, ki jim pravite kemtrejli, poznali ŠE KURČEVO PREDEN SO JEBENA LETALA SPLOH LAHKO LETELA TAKO KLINČEVO VISOKO, ŽE JEBENEGA LETA 1905(???!!!), pravzaprav, ŠE PREDEN SO SPLOH IZUMILI MOTORNO GNANA LETALA!
MarkookraM ::
To samo dokazuje, da so nas že takrat zastrupljali! :O
Matev ::
vse je zarota
tudi to da nas želijo prepričati da nas zastrupljajo
Končno je tu tudi rešitev. Če vas skrbijo chemtrailsi, pijte ChemBuster in vseh vaših težav bo konec.
http://www.compat.org/radionika/chem_bu...
SESTAVA:
? Mycoplasma pneumonae 12X(177) -Mikoplazma, ki so jo našli v kemijskih sledeh pri izpuščanju iz avionov. Homeopatski pripravek 1553991
? Baryta carb 12X(177) - Barijev karbonat je sestavni del chemtrailov.
Homeopatski pripravek 5731212
O.
Hudo, tut drugi izdelki so odlični. Must buy many!
PaX_MaN ::
SESTAVA:
Nisem vedel, da v homeopatsko zdravljenje spada okužba z bakterijo, ki povzroča pljučnico. :))
Mislim, to je pa že višek, to je pa še mene šokiralo:D
To je bistvo homeopatije. Vedno vzamejo povzročitelja bolezni ali neko snov, ki povzroča enake simptome, ga razredčijo do nezavesti, da ne ostane več niti en atom od njega, ampak voda si ga dobro zapomni in ko to popiješ, voda s tem spominom pobije povzročitelje bolezni oziroma odpravi simptome.
O.
  • spremenil: Okapi ()
PaX_MaN ::
To je en tak ROTFL. A rdečih krvničk si pa nič ne zapomni in posledično tudi pobije?
PaX_MaN> A rdečih krvničk si pa nič ne zapomni in posledično tudi pobije?
Don't be silly.
PaX_MaN ::
Pol si "zapomne" samo in le tisto, kar si homeopat želi, da si?
hamax ::
Homeopatija je zabavna ja, ampak v tej temi je offtopic.
Ce si zelite naprej debatirati, prosim odprite novo temo.
Matev ::
ne podcenjuj homeopatije
oni že vedo kaj je dobro za njih
swamigi ::
Na ZDF-u napovedovalec vremena pove,da so vojaška letala ustvarla oblake :)
bluefish ::
Ah, točno. Tega vida že precej časa nismo videli, pa je bilo spet potrebno obuditi cikel.
iggy ::
Kondenzacijske sledi niso na našem jedilniku še zaenkrat.
Hey, you're fat!
swamigi ::
Bistvo tega videa je:da delajo umetne oblake,kar je tudi jasno povedano
Ziga Dolhar ::
Bistvo teme je:
(1) v zrak spuščajo strupe in druge snovi, ki kanijo vplivati na človekov DNK.
(2) Takšnih sledi letala "včasih" niso puščala za sabo.
Trditev, da so "vojaška letala ustvarila oblake", je nesklepčna.
https://dolhar.si/
11 / 29
Slovenija na prvem mestu po pogostosti googlanja izraza "Chemtrails" (strani: 1 2 )
7016930 (14256) dzinks63
Ameriško vojaško letalo po nesreči ohromilo civilni informacijski sistem za kontrolo
3717950 (14143) pegasus
čuden objekt na nebu?
234895 (3736) stb
Zaprt zračni prostor
Oddelek: Problemi človeštva
285496 (4684) poweroff
Chemtrails - reakcija na sončni svetlobi? (strani: 1 2 3 )
11412170 (10322) imagodei
