apache 2.52-r1 ma dost težav
Senzacionale ::
apache2ctl -t
Syntax OK
moj apache2.conf
### /etc/apache2/conf/apache2.conf
### $Id: apache2.conf,v 1.1 2004/03/22 21:17:57 stuart Exp $
### Main Configuration Section
### You really shouldn't change these settings unless you're a guru
ServerRoot /usr/lib/apache2
ServerName localhost
#LockFile /etc/apache2/apache2.lock
PidFile /var/run/apache2.pid
ErrorLog logs/error_log
LogLevel warn
DocumentRoot /var/www/localhost/htdocs
### Dynamic Shared Object (DSO) Support
### You should always leave these three, as they are needed for normal use.
### mod_access (Order, Allow, etc..)
### mod_log_config (Transferlog, etc..)
### mod_mime (AddType, etc...)
LoadModule access_module modules/mod_access.so
LoadModule auth_module modules/mod_auth.so
LoadModule auth_anon_module modules/mod_auth_anon.so
LoadModule auth_dbm_module modules/mod_auth_dbm.so
LoadModule auth_digest_module modules/mod_auth_digest.so
LoadModule include_module modules/mod_include.so
LoadModule log_config_module modules/mod_log_config.so
LoadModule env_module modules/mod_env.so
LoadModule mime_magic_module modules/mod_mime_magic.so
LoadModule cern_meta_module modules/mod_cern_meta.so
LoadModule expires_module modules/mod_expires.so
LoadModule headers_module modules/mod_headers.so
LoadModule usertrack_module modules/mod_usertrack.so
LoadModule unique_id_module modules/mod_unique_id.so
LoadModule setenvif_module modules/mod_setenvif.so
LoadModule proxy_module modules/mod_proxy.so
LoadModule proxy_connect_module modules/mod_proxy_connect.so
LoadModule proxy_ftp_module modules/mod_proxy_ftp.so
LoadModule proxy_http_module modules/mod_proxy_http.so
LoadModule mime_module modules/mod_mime.so
LoadModule status_module modules/mod_status.so
LoadModule autoindex_module modules/mod_autoindex.so
LoadModule asis_module modules/mod_asis.so
LoadModule info_module modules/mod_info.so
LoadModule cgi_module modules/mod_cgi.so
LoadModule cgid_module modules/mod_cgid.so
LoadModule vhost_alias_module modules/mod_vhost_alias.so
LoadModule negotiation_module modules/mod_negotiation.so
LoadModule dir_module modules/mod_dir.so
LoadModule imap_module modules/mod_imap.so
LoadModule actions_module modules/mod_actions.so
LoadModule speling_module modules/mod_speling.so
LoadModule userdir_module modules/mod_userdir.so
LoadModule alias_module modules/mod_alias.so
LoadModule rewrite_module modules/mod_rewrite.so
LoadModule php4_module extramodules/libphp4.so
### New Modules for 2.0 (some are experimental)
LoadModule file_cache_module modules/mod_file_cache.so
LoadModule echo_module modules/mod_echo.so
LoadModule charset_lite_module modules/mod_charset_lite.so
LoadModule cache_module modules/mod_cache.so
LoadModule disk_cache_module modules/mod_disk_cache.so
LoadModule mem_cache_module modules/mod_mem_cache.so
LoadModule ext_filter_module modules/mod_ext_filter.so
LoadModule case_filter_module modules/mod_case_filter.so
LoadModule case_filter_in_module modules/mod_case_filter_in.so
LoadModule deflate_module modules/mod_deflate.so
#LoadModule optional_hook_export_module modules/mod_optional_hook_export.so
#LoadModule optional_hook_import_module modules/mod_optional_hook_import.so
#LoadModule optional_fn_import_module modules/mod_optional_fn_import.so
#LoadModule optional_fn_export_module modules/mod_optional_fn_export.so
#LoadModule bucketeer_module modules/mod_bucketeer.so
LoadModule logio_module modules/mod_logio.so
### Global Configuration
# Splitting up apache2.conf into two files makes it easier to support
# multiple configurations on the same serer. In commonapache2.conf
# you keep directives that apply to all implementations and in this
# file you keep server-specific directives. While we don't yet have
# multiple configurations out-of-the-box, this allows us to do that
# in the future easily. (PERLPROXIED *ahem*)
# For Apache2 we load all conf files in conf/modules.d
Include conf/modules.d/*.conf
Include conf/commonapache2.conf
### IP Address/Port
#BindAddress *
Listen 80
### Log configuration Section
IfModule mod_log_config.c
#Single logfile with access, agent and referer information
#This is the default, if vlogs are not defined for the main server
CustomLog logs/access_log combined env=!VLOG
#If VLOG is defined in conf/vhosts/vhosts.conf, we use this entry
#CustomLog "|/usr/sbin/apache2splitlogfile" vhost env=VLOG
/IfModule
### Virtual Hosts
# We include different templates for Virtual Hosting. Have a look in the
# vhosts directory and modify to suit your needs.
#Include conf/vhosts/vhosts.conf
#Include conf/vhosts/dynamic-vhosts.conf
#Include conf/vhosts/virtual-homepages.conf
### Performance settings Section
# Timeout: The number of seconds before receives and sends time out.
Timeout 300
# KeepAlive: Whether or not to allow persistent connections (more than
# one request per connection). Set to "Off" to deactivate.
KeepAlive On
# MaxKeepAliveRequests: The maximum number of requests to allow
# during a persistent connection. Set to 0 to allow an unlimited amount.
# We recommend you leave this number high, for maximum performance.
MaxKeepAliveRequests 100
# KeepAliveTimeout: Number of seconds to wait for the next request from the
# same client on the same connection.
KeepAliveTimeout 15
# prefork MPM [THIS IS THE DEFAULT]
# StartServers: number of server processes to start
# MinSpareServers: minimum number of server processes which are kept spare
# MaxSpareServers: maximum number of server processes which are kept spare
# MaxClients: maximum number of server processes allowed to start
# MaxRequestsPerChild: maximum number of requests a server process serves
IfModule prefork.c
StartServers 5
MinSpareServers 5
MaxSpareServers 10
MaxClients 150
MaxRequestsPerChild 0
/IfModule
# worker MPM
# StartServers: initial number of server processes to start
# MaxClients: maximum number of simultaneous client connections
# MinSpareThreads: minimum number of worker threads which are kept spare
# MaxSpareThreads: maximum number of worker threads which are kept spare
# ThreadsPerChild: constant number of worker threads in each server process
IfModule worker.c
StartServers 2
MaxClients 150
MinSpareThreads 25
MaxSpareThreads 75
ThreadsPerChild 25
/IfModule
# perchild MPM
# NumServers: constant number of server processes
# StartThreads: initial number of worker threads in each server process
# MaxThreadsPerChild: maximum number of worker threads in each server process
# MaxRequestsPerChild: maximum number of connections per server process
IfModule perchild.c
NumServers 5
StartThreads 5
MinSpareThreads 5
MaxSpareThreads 10
MaxThreadsPerChild 20
/IfModule
če zakomentiram
pol
apache2 -k start
apache2 -k stop
apache2 -k restart
dela brez problemov in tudi zacetna stran dela. Toda ne vem ka v resnici pomeni tale unique... in kaj dela.
/etc/init.d/apache2 ima pa vedno isto napako
/sbin/runscript.sh: line 32: /var/lib/init.d/softlevel: No such file or directory
zato sem probu nardit ta direktorij mkdir /var/lib/init.d/softlevel in vse je zacelo delat brez napak. Če pa odkomentiramt LoadModule unique_id_module modules/mod_unique_id.so nič ne dela kot bi mogl.
Zakaj to. A bi blo bolš da ostanem na 2.5.0 kjer sem bil prej in je delal vse brez problema mysql, php, postregsql ,... čeprav zdej na 2.52-r1 dela tud ko ono zakomentiram. Ja pa še to. Če kir dobi slučajno isti da mu javlja napako
* Apache2 has detected a syntax error in your configuration files:
Syntax error on line 44 of /usr/lib/apache2/conf/modules.d/41_mod_ssl.default-vhost.conf:
SSLCertificateFile: file '/usr/lib/apache2/conf/ssl/server.crt' does not exist or is empty
naj si naredi svoj kluč pa bo delal vse ok še prej pa mapo mkdir /etc/apache2/conf/ssl
openssl req -newkey rsa:1024 -keyout server.key -nodes -x509 -out server.crt
ter pogleda če obstaja ta fajl
ls -l /usr/lib/apache2/logs/error_log
http://www.dostavahrane.si
Lualah ::
rad bi si naredu nov kluč. Tale tvoj res dela sam je samo en mesec veljaven. Kak nardim da bo veljaven kako leto in malo bolj napreden z več funkcijami.
Hvala
Postavitev Apache serverja s podporo za PHP in MySQL (strani: 1 2 3 4 5 6 7 )
Oddelek: Izdelava spletišč
322276825 (20726) miko22
Namestitev Apache SVN na strežnik Apache
Oddelek: Programska oprema
81315 (1065) Ales
Apache vprašanje - virtual host
161270 (1113) Goldee
Apache - localhost JA, IP naslov NE
Oddelek: Omrežja in internet
187284 (7143) ManDriver
apache+python+mod_python
Oddelek: Programiranje
51487 (1426) grim_
