Google pixel 7 pro kupil pokvarjen
mangoslo ::
od enga nemca sem kupil pixel pro in po 5 minutah začne se zvok ko se pogovarjaš pačit...vedno po 5 minutah govora....postane zvok robotski in začne prekinjat...
so rekli na googlu naj uveljavim garancijo, ki je še...ampak telefon je očitno kupljen v GB ne ebayu in moraš iti fizično v GB in tam dat popravti telefon...saj ne moreš verjeti kako google jebe folk...tako da sem zdaj ostal s pokvarjenim telefonom s katerim ne morem komunicirat več kot 5 minut
Legon ::
In kaj tocno ima google s tem, da te je nek nemc nategnil kot elastiko?
Odogovornost za napake je praviloma stvar trgovine, ce je ta v GB toliko slabse zate.
  • spremenilo: Legon ()
japapajade ::
Mogoče rešitev iz interneta:
I was going to post an update and here I am. Here's my finding and possible workaround.
I have gone through 3 brand new Pixel 7 phones. The store I bought send a 3rd and all three phones had the same issues. All of them were new and completely sealed. I also had a colleague tested on his phone and same issue did indeed occur. Around 8-10 minutes EVERYTIME is where the distortion/crackle happens on all 3 phones.
We tested with both sim cards and both had it.
Here's where the interesting part starts. One of the Dutch providers (50 PLUS) as of 2023 does not support VOLTE and still requires you to have 2G calling enabled otherwise you will not be able to make any calls. Second provider which is a pretty big provider (KPN) in the Netherlands had the same issue. KPN does have VOLTE on by default you do not have to enable manually. However KPN has the same issue, at 8-10 minutes sounds become distorted/crackled. This happens every time.
Then what is the solution? After I turned off 2g calling the issue was gone. No crackle, no distorted sounds. Called for 20 minutes, 30 minutes, 1 hour, 2 hourrs. No issues at all. So the issue lies with 2G calling feature. Somehow Pixel 7 has support issues with this old tech.
People have been reporting crackle issues since the 2022 release. My guess is Google has not bothered fixing it or dedicate resources to it because its an old tech. Not enough people have this issues. 2G should be phased out completely soon in most countries. Sadly my main phone plan with 50 PLUS is one of the very few that do not support VOLTE and requires you to enable 2G. Unfortunately I'm out of luck until they support VOLTE :(
Then what about if you need to have 2g enabled? No VOLTE support from your provider? Then you are sadly out of luck and most likely this issue won't be fixed. I also downloaded Android 14 BETA which is currently in phase 4. This issue still persists in Android 14 BETA.
Hopefully this helps. If you have a provider that supports VOLTE then turn off 2G calling.
Še reddit thread:
https://www.reddit.com/r/GooglePixel/co...
mangoslo ::
ja vem za 2g is sem že izklopil ampak ko izklopim me ne more nihče več klicat? Ne vem v čej je finta? Saj mi kaže da je 4g signal...in če 2G izklopim je telefon nedosegljiv
klical sem ponudnika in pravi da 2G mora biti vklopljen kajti za klicanje in sprejemanje klicev uporabljajo 2g...in ne 4g...ne morem verjet kako stara tehnologija je še v slo
folk ne kupujte šrota od googla
  • spremenilo: mangoslo ()
Reklamacija pri ebayu. Ce nisi zamudil roka, in napaka bi bila omenjena pri prodaji, je to verjetno najlazja resitev.
Druagce pa poslji v VB na popravilo.
mangoslo ::
NE moreš poslat telefona na popravilo v VB.....moraš fizično tja it...google je prfukjen totalno
  • predlagalo izbris: Runner71 ()
Pezdicek ::
Google ja... zakaj pri PM si sploh šel kupit tak telefon, kateri ima znane težave?
Furbo ::
mangoslo je izjavil:
https://www.telekom.si/pomoc/mobilna-te...
Morda preklopi na telekom ali vklopi ta famozni volte?
borut_p ::
Pezdicek je izjavil:
Zato ker ga je dobil za pol cene in se je hotel frajarisit. Zdaj ga pa misica spodaj malo boli
Kaj točno bo servis naredil, če imajo, kot pišete, vsi ta problem?
mojsterleo ::
Furbo je izjavil:
To je res zanimivo. Sama 3G in LTE tehnologija namreč ne podpirata govorne funkcije. Sta samo podatkovna tehnologija. Zato kadar kličeš ali sprejemaš klic, preklopi telefon na 2G in po koncu klica preklopi nazaj. Med klicem tudi ne moreš uporabljati podatkovne povezave.
VoLTE, ko je enablan na telefonu ki ga podpira, omogoča klice direktno preko LTE in hkrati tudi deluje podatkovna povezava.
Hm... kaj sem sploh hotel povedati? V bistvu sem naredil useless post. 8-O Upam da rešiš problem. Iphone 16 kliče! 8-)
Kayzon ::
mojsterleo je izjavil:
Furbo je izjavil:
Zakaj iphone in ne samsung? Zakaj ximaomi ali huwaei?
mangoslo ::
MATERJ VAM GOOGLOVO:::DA SE VAM KUR.. POSUŠIJO
kako naj bi vedel da ti telefoni imajo take težave, vsi so pixel samo hvalili
Google Pixel (strani: 1 2 3 4 … 82 83 84 85 )
Oddelek: Mobilne tehnologije
42271122869 (16814) dejanslo
VoLTE v Sloveniji? (strani: 1 2 3 )
13643569 (11742) sinalko
A1 -voLTE certifikati
457873 (4103) Thomy
Data roaming nastavitev
82317 (2129) starfotr
Telekom ugaša 3G (strani: 1 2 )
Oddelek: Omrežja in internet
7719469 (9447) V-i-p
