Forum » Igre » Fallout New Vegas 2
Fallout New Vegas 2
Fallout New Vegas 2 ni napovedan ŠE ampak je postal realnost sedaj, ko je Microsoft kupil Bethesdo. In velika večina igralcev in ljubiteljev serije Fallout si že več let želi igro Fallout New Vegas 2
Sedaj sta studija Bethesda in Obsidian pod okriljem Microsofta.
Fans Already Want a Bethesda-Obsidian-Microsoft Fallout: New Vegas 2
Both Bethesda and Obsidian are owned by Microsoft now.
https://www.ign.com/articles/fallout-ne...
Sicer igre ne bomo videli še nekaj let ampak upam se staviti, da igra bo narejena saj si to želi velika večina
@Obsidian so Fallout New Vegas 2 is a legit possibility now right!?!?
¯\_(ツ)_/¯
https://twitter.com/Obsidian/status/130...
ahac ::
Eh, brezveze.
Obsidian naj raje dela na drugih stvareh, kjer ne bo omejen tako kot pri Falloutu.
strawman ::
Upam da se ne ponovi klasična zgodba nadaljevanj franšize po prevzemu s strani večjega podjetja.
Na projekt vržeš B ekipo, uporabiš iste tehnologije kot v predhodniku (khm .. engine iz Morrowinda) in za štukanje prodajne luknje zaradi nizke kvalitete uvedeš malo morje DLCjev in loot boxov.
Upam, da Microsoft Bethesdo prisli da menjajo ta drek od bugastega zastarelega pogona ki ga furajo že 20 let preden se kdorkoli loti česarkoli.
- spremenil: Zmajc ()
Starfield, Elder Scrolls 6 To Bring Bethesda's "Largest Engine Overhaul Since Oblivion"
Ampak Obsidian za F:NV2 lahko uporabi tudi svoj pogon ?
Why Obsidian's Secret Project Could Be Fallout: New Vegas 2
Although Microsoft's Bethesda acquisition may be fresh on everyone's mind, it's possible that Obsidian is already working on Fallout: New Vegas 2.
https://gamerant.com/fallout-new-vegas-...
Fallout: New Vegas 2 has been teased by a long-time Valve insider.
https://www.gamesradar.com/valve-leaker...
According to insider Tyler McVicker, who's leaked accurate information under the Valve News Network banner for years, but has begun covering a wider range of companies, including Nintendo and Bethesda, Fallout: New Vegas 2 is indeed in the works.
I expect Fall out New Vegas 2 in the latter half of this decade.
Treba bo še kar dolgo čakati.
Fallout: New Vegas 2 from Obsidian Reportedly in Early Talks
An industry insider claims that Microsoft is in early talks to have Obsidian Entertainment make a Fallout: New Vegas 2 game.
Obsidian founder says the studio wants to make another 'Fallout' game
"There's not even a question of whether or not we would do it, it's just will the opportunity arise?"
https://www.nme.com/news/gaming-news/ob...
Izi ::
Ni važno kaj si oni želijo. Najprej je važno kaj si želi Microsoft, potem se mora strinjati tudi Bethesda, šele potem lahko pri Obsidianu začno razmišljati o izdelavi.
Microsoft ni zaenkrat rekel še nič, Bethesda pa ima v načrtu Fallout 5, ki bo prišel na vrsto po TES 6.
Microsoft je kupil Bethesdo s tem tudi Fallout tako, da Fallout zdaj pripada Microsoftu.
Se upam stavit, da bomo dobili prej Fallout igro od Obsidiana kot pa Fallout 5 od Bethesde
Zakaj bi Microsoft čakal toliko let na nov Fallout, ko pa lahko Obsidian naredi prej in mogoče celo boljše. Obsidian je Fallout New Vegas naredil v 18 meseceih, ker so imeli časovni rok. Si predstavljaš kaj bi naredili npr v 3 letih :)
Kar Microsoft rece, Bethesda naredi in ne obratno oz. Bethesdha je itak zgolj skupina znotraj MS.
Če imajo pri Microsoftu kaj pameti bojo Fallout franšizo premaknili pod okrilje Obsidiana.
Naj Bethesda dela Skyrim klone, Fallout so čisto zavozili.
Se popolnoma strinjam. Vbistvu bi morali odpustiti odgovorne in jih nadomestiti s sposobnimi kadri.
Fallout New Vegas je bil sprva mišljen kot Fallout 3 DLC
Fallout Retrospective - Surviving the Desert Wasteland
Fallout: New Vegas Director Open To Making Sequel
Josh Sawyer has a few ideas about where Fallout could go next.
https://www.thegamer.com/fallout-new-ve...
Obsidian dela na novi še nenapovedani igri ali gre mogoče za New Vegas 2 ?
Lahko pa je ta nenapovedan projekt tudi kaj drugega npr Pilars 3, Grounded 2, Pentiment 2 ali pa nekateri pravijo celo Alpha Protocol Remake/Remaster.
Obsidian poleg te nenapovedane igre dela še na Outer worlds 2 in Avowed kateri pa naj bi se bližal koncu razvoja in naj bi po govoricah izšel enkrat v začetku 2025.
Obsidian bi moral narediti svojo Fallout spin off igro v svojem enginu. Imajo Outer Worlds engine.
Fallout: New Vegas Director Happy To Make Another Fallout Game
New Vegas, helmed by Josh Sawyer, is considered the best in the franchise.
https://exputer.com/news/games/fallout-...
Glavni pisec zgodbe Fallout New Vegas John Gonzales se je po 14 letih vrnil nazaj k Obsidianu, da bo delal na novi igri. Sicer je takoj zatrdil, da ne dela na igri New Vegas 2.
Obsidian ima trenutno dve igri v izdelavi Avowed katera izide kmalu in Outher worlds 2.
Kot je Microsoft kupil Bethesdo je kupil tudi Fallout IP. Microsoft si lasti tudi Obsidian. Microsoft je rekel, da si želi več Fallout iger in,d a ne bo treba čakati tako dolgo na Bethesdin Fallout 5 kateri ne bo prišel pred 2030 tako, da vse je možno kljub zanikanju glavnega pisca.
Bethesda Softworks is currently working on multiple projects based on the Fallout IP, possibly including New Vegas 2, according to a new report.
https://twistedvoxel.com/bethesda-worki...
Kurzweil ::
Jaz imam kar mešane občutke... seveda bom dal priložnost in verjetno bom tudi preigral, kot sem prav vse Falloute od prvega dela dalje do sedaj... ampak od prevzema Microsofta in ko že takole prebereš naslov Fallout: New Vegas 2, dobi človek zelo mešane občutke... deluje precej generično, kot da bi bil zgolj še en del v franšizi, toliko da se obrne denar... upam, da se motim, ampak kar se mene tiče sta bila prva dva Fallouta itak klasike, Fallout 3 je bil od teh novejših de facto najboljši, New Vegas je bil še OK, ampak se je že malce poznalo... 4. del pa je seveda da bil za preigrat, ampak nekako mi ni več to to... sem pa itak od nekdaj nor na razne cyberpunk, post-apokaliptične in podobne fore...
In na katerem enginu/pogonu je zdej sploh Fallout? Še vedno kaj, kar je malce out of date?
Predsednik11 ::
Najbrž Creation Engine 2. Na njem že laufa Starfield in delajo Elder scorls 6.
Kurzweil ::
Sem dejansko včeraj šel gledat v eno FB grupo, kjer so die hard fani Fallouta in tega New Vegasa 2 nihče ne omenja... praktično vsi pa omenjajo remake Fallouta 3 in New Vegasa... torej 2 remaka in še ene 2-3 drugi naslove... ne spomnim se zdej imena, ampak možakar, ki je delal scenarij/zgodbo za Fallout 3 se je bojda vrnil, je pa taisti možakar potrdil, da še ne dela nič za prav nobenega od Falloutov, vsaj zaenkrat ne.
Torej long story short... nobenega New Vegasa 2, vsaj kmalu ne...
matobeli ::
Sej je bolje tako. FNV2 nima niti najmanjše možnosti da bi bil dostojen naslednik FNV. Tudi sama zgodba je zaključena celota. Bi blo pa kul imet F5 recimo v Kaliforniji.
Remake za FNV in F3 je pa jasno obvezen, zastarela grafika in okorni mehanizmi ne dodajo čisto nobenga čara sami igri in je škoda za nove igralce da teh dejanskih biserov ne bi preigrali samo zaradi tehnikalij.
Zdaj je uradno. Obsidian enterteiment dela novo Fallout igro.
Direktor igre bo Josh Sawyer kateri je bil direktor že pri igri Fallout New Vegas.
Nova šefica Xboxa je rekla, da je Fallout ena izmed največji prioritet za XBOx zato so skenslali igro Awoved 2 in gredo na Fallout.
Ni pa še znano ali bo šlo za Fallout New Vegas 2 ali kaj novega.
Je možnost tudi, da bodo delali Fallout 5.
Ko končajo TES 6. NV2 je maslo novega Xbox vodstva, ki je Toddu rekel da ena fallout igra na 25 let ni dovolj.
Microsoft je uradno preuredil strukturo svojih Xbox studiev in Obsidian Entertainment postavil neposredno pod okrilje založnika Bethesda.
Obsidian bo zdaj odgovarjal neposredno vodstvu Bethesde. Glavni cilj te poteze je tesnejša poravnava obeh RPG ekip, medtem ko Obsidian nadaljuje z delom na svojem novem projektu v vesolju Fallout, ki nastaja v tesnem sodelovanju z Bethesda Game Studios.
| » | Fallout 5 (strani: 1 2 3 4 5 )Oddelek: Igre | 44975 (2270) | Enaplusdva |
| » | The Outer Worlds - (Obsidian Entertainment) (strani: 1 2 3 4 5 )Oddelek: Igre | 42582 (6277) | Buggy |
| » | Avowed (Obsidian Entertainment) (strani: 1 2 )Oddelek: Igre | 10841 (4023) | TucoX |
| » | Fallout 76 (strani: 1 2 3 4 5 6 7 8 )Oddelek: Igre | 101286 (26043) | todman74 |
| » | Fallout: New OrleansOddelek: Igre | 3066 (2284) | ahac |
