Forum » Igre » tribes2 pomoč
tribes2 pomoč
ro3b ::
včeri sm si posnel to igro iso FairLight (warez) pa ne vem kaj moram točno naredit s tem patchom napiše takole
#1: copy orignal tribes2.exe and glon32.dr7 from cd/gamedata dir
#2: apply patch
#3: unzip 2 files from the zip file to gamedata dir overwriting the ones there
and play
This patch is necessary, so make sure you install it !
če je že kdo posnel to igro naj mi prosim pove kako se to nardi
hvala za odgovor
#2: apply patch
and play
hvala za odgovor
| » | S.T.A.L.K.E.R. (strani: 1 2 3 4 … 8 9 10 11 )Oddelek: Igre | 112149 (30029) | Meizu |
| » | Čiščenje C diskaOddelek: Pomoč in nasveti | 5990 (5115) | r3dkv1c4 |
| » | Command & Conquer Generals - Zero Hour - razna vprašanja (strani: 1 2 )Oddelek: Igre | 8912 (4667) | Vesoljc |
| » | Trackmania nations SLO zastava, SLO himna ...Oddelek: Igre | 2385 (1923) | Slo-One |
| » | Runtime error pri igrah.Oddelek: Pomoč in nasveti | 1474 (1357) | Dead_Eye |
