inštalacija starejše verzije vlc na linux mint
hogorq ::
z https://download.videolan.org/pub/video... bi rad inštaliral starejšo verzijo, ker je nova prilagojena za 4k tvje očitno in je ui na mojem 768p televizorju prevelik. če se komu da, prosim za step by step navodila, ker nisem znalac.
hvala!
Gapi ::
Na linuxu imaš še vedno isti vmesnik. Ni nič drugačen. Oziroma nič ni kar bi bilo nakazano da je namenjen samo za 4k ekrane. Verjetno imaš ti težave z scaling oz. resolucijo ekrana. Je pa res da v windows store dobiš neko čudno desktop app za win 10. Torej sudo apt install vlc naj bi bil dovolj.
No person is rich enough,to buy back his past.
hogorq ::
Gapi je izjavil:
no, ni. vlc sem imel 2018, vse je normalno delalo. ves čas uporabljam isto konfiguracijo laptop/tv.
torej:
aaaa@aaaa-P7624:~$ sudo apt install vlc
[sudo] password for aaaa:
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
vlc-bin vlc-plugin-qt
Recommended packages:
vlc-l10n vlc-plugin-notify vlc-plugin-samba vlc-plugin-skins2
vlc-plugin-video-splitter vlc-plugin-visualization
The following NEW packages will be installed
vlc vlc-bin vlc-plugin-qt
0 to upgrade, 3 to newly install, 0 to remove and 477 not to upgrade.
Need to get 1,135 kB of archives.
After this operation, 4,215 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Err:1 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 vlc-bin amd64 3.0.4-1ubuntu0.2
404 Not Found [IP: 91.189.88.149 80]
Err:2 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 vlc-plugin-qt amd64 3.0.4-1ubuntu0.2
Err:3 http://archive.ubuntu.com/ubuntu bionic-updates/universe amd64 vlc amd64 3.0.4-1ubuntu0.2
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/u... 404 Not Found [IP: 91.189.88.149 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
zaradi tega. že probal. zanima me inštalacija offline. tar.xz fajl. odpakira se, naprej ne znam.
hogorq ::
pa nimam winsov. o problemu s scalingem sem že bral. rešitev? tnx
Gapi ::
sudo apt update ?
Gapi ::
https://packages.ubuntu.com/bionic-upda... je za i386 za x64 ga ne najdem
hogorq ::
Gapi je izjavil:
sudo apt update ?
ja. in dobim isto. prevelik ui. kako zrihtat scaling, očitno?
Gapi ::
hogorq ::
ne. probal prvo varianto, nič. druge pa ne znam. aberveznik za linux sem. hvala vseeno.
hogorq ::
še to. probal na mintu, gnanemu z usb ključka. tam tega problema ni.
hogorq ::
če bo imel kdo tak problem:
nalimal sem
"export QT_AUTO_SCREEN_SCALE_FACTOR=0 vlc"
v mapo profile, sejval, zaprl in rebootal, hvala gapi in ostali za pomoč.
A very late comment. Having had the same issue, I tested
Code: Select all
OR
export QT_SCALE_FACTOR=1 vlc
in the ~/.profile file. Either one works for me in LM19.1 Cinnamon
Ubuntu težave pri nameščanju novih programov
Oddelek: Operacijski sistemi
132073 (1744) Invictus
Debian in nvidia
223126 (2851) Icematxyz
WiFi ne dela na Lenovo R500 z Ubuntu 10.04 LTS (64 bit)
181963 (1768) Icematxyz
Ubuntu compiz
162331 (2008) Loaded
Bi Linux? Bi Debian? Ubuntu! (strani: 1 2 3 4 … 8 9 10 11 )
53039831 (27372) Trubadur
