Požari v Avstraliji
Požari v Avstraliji
Redorange ::
Se vam ne zdi, da bi bil čas da začnemo pisat pisma našim predstavnikom vlade, naj pritisnejo na PM Avstralije, da se že enkrat stvar obrne na bolje? Pa to ne mislim samo na Slovenijo, govorim o celi EU in naprej po svetu.
Al počakamo da gre k vragu. Zgorelo je že več kot je velika Slovenija.
Odgovor enega vojaka ko sem povprašal na redditu če jim vojska pomaga:
When we get deployed to “fight fires” in aid to civil powers operations, we aren’t actually firefighters.
We’re a self-sustaining, low-pay, large-scale labour force that doesn’t have workers’ rights. What that means is why task a firefighter who makes $450 a day digging fire guards in shift work when you can have a company of infantrymen do the work around the clock for less than half the cost. The military is also a federally-funded organization so if you’re a local government then you don’t even need to pay for them. Soldiers are also the only group in the country subject to unlimited liability. If the police or firefighters say a mission is too risky, they can refuse to do it. We can’t. What the military actually does is just simply the cleanup of forest fires and maybe sweeping the ground for embers. We don’t fight fires.
Don’t get me wrong, I love helping my country. However, it’s become very clear that provincial governments often take advantage of the military to save a lot of money on cleanup or labour. It’s gotten to the point where we now need to bill the local governments because it was happening so often.
Požari v Avstraliji so tako veliki, da ustvarjajo svoje vreme - "pirocumulonimbus" nevihte, ki lahko začnejo več požarov
bajsibajsi ::
Lahko bi jim poslali donacijo za ognjemet, glede na to, da porabljajo nekaj financnih sredstev za gasenje pozara.
s1m0n ::
Samo so pa res gromozanske površine to...
Požar je celo povozil tistega iz 1851 že skoraj za 1/5.
scipascapa ::
Noro je to dol, samo imam občutek, da državna vlada in lokalne oblasti naredijo premalo.
CO2 tax vsekat po njih, dokler se ne zganejo. Naj že nekdo pinga Greto.
Alfa Dog ::
Nemudoma je potrebno ustanoviti facebook skupino "ustavimo požare v Avstraliji" in odločno zahtevati da vsi ti požari nemudoma ugasnejo. To bo to.
Matevz96 ::
Redorange je izjavil:
Ne boš verjel ampak tako se pač gasi požare v naravi, pa naj se ta vojak še tako pritožuje.
#hooldthedoor
keba ::
Najlažje je itak pametovat iz udobnega fotelja doma.
Misliš da si teh požarov želijo in jih načrtno ne gasijo?
Redorange ::
Glede na politiko in dejanja avstralskega PM ti na drugo vprašanja res ne znam odgovorit.
Ja doma iz fotelja, kaj pa pametujem? O tem kako naj se gasi ali o tem da je potrebno preko naših predstavnikov prit do avstralca, ki si je med največjimi požari v zgodovini privoščil dopust na nevemkaterih otokih?
vostok_1 ::
Morate vedet, da gozni požari so nekako esencialni za nekatere gozdove. Obnovitev, ki sledi je toliko večja. Včasih so se požari redno dogajali, razlika je ta, da se niso plebsi naselili v vsak kotiček dežele iz katerega jih je bilo pol potrebno reševati.
There will be chutes!
It came from the lab.
vostok_1 je izjavil:
Mhm, absolutno. Pa malo manj esencialni za ljudi in živali, ki v njih pomrejo.
Redno se še vedno, a zdaj se tudi pogosto. Včasih so se na 200-250 let, zdaj se pa na 2-5 let.
vostok_1 ::
To pa zato ker 1 čik ga lahko že zaneti.
  • spremenil: vostok_1 ()
Pa ker je zaradi večanja koncentracije antropogenih toplogrednih plinov v atmosferi vedno več ekstremnih vremenskih pojavov.
OP, zakaj bi se mi ukvarjali s požari, ki so na drugem komcu sveta, na eni izmed najbolj oddaljenih točk od nas?
Naj se oziji s tem ukvarjajo. Če ne zmorejo, naj vprašajo kivije za pomoč. Če še to ne reši problema, pa naj vprašajo azijske kolege.
Sicer je pa Avstralija imela res stalno gospodarsko rast, brez recesij, brez upadov prihodkov, bodo že rešili, imajo dovolj denarja in sredstev, who cares.
starfotr je izjavil:
Zatu k na maram mešat s peram, pa zatu k so mojga brata z nožam.
AndrejO ::
jype je izjavil:
V vseh treh stavkih si brcnil v temo.
Boš poskusil ponovno in za spremembo povedal nekaj, kar res drži?
AndrejO je izjavil:
Ne.
Američani itak izgubljate bitko: https://www.bbc.com/news/world-middle-e...
  • spremenilo: jype ()
AndrejO ::
jype je izjavil:
AndrejO je izjavil:
Ne.
Včasih si bil bolj intelektualno pošten.
Ker pa se tebi ne da, bom jaz namesto tebe:
Da, za nekatere gozdove je dokazano nujno, da se v njih dopusti naravne požare. Ker smo v industrijski družbi pridobili možnost takšne požare nadzorovati, če ne kar onemogočati, kar smo v nevednosti izdano izkoriščali, smo tako povečali že tako velik problem. Odsotnost manjših požarov v gozdovih vodi k naslednjim posledicam:
- Večanje količine goriva, kar vodi k večjim in manj obvladljivim ali kar neobvladljivim požarom.
- Večji požari, ki zajamejo večje površine, bodo veliko živalim onemogočili pravočasen beg, ker bi moral ta beg biti hitrejši (dinamika hitrosti širjenja požara) in daljši (faktor utrujenosti). K temu dodaj še večjo možnost, da požar obkroži večje področje in katastrofa je tu.
- Omogočanje nove rasti v ekosistemu. Čeprav je lepo govoriti o tisočletnih drevesih, pa so to še vedno minljivi živi organizmi. Ko bodo ti odmrli, bodo tam morali biti že novi, da jih nadomestijo. Ali veš, da npr. sekvoje za svojo prokreacijo potrebujejo gozdne požare?
In, ko smo že pri požarih ... za sekvoje znanstveniki ocenjujejo, da potrebujejo požare vsakih 5-15 let. Če bi bilo o požarih govora vsakih 200-250 let, potem bi evolucija za ta drevesa v teh gozdovih verjetno privedla do drugačne metode pomlajevanja.
Tako, da ... žal lenoba ne bo šla skozi. Nova znanstvena spoznanja so tukaj. Človek je tudi s svojim tovrstnim ravnanjem pomembno prispeval k trenutnem problemu.
In preden pozabim, tudi Avstralija ima gozdove, ki potrebujejo požare, ker so jih kot takšne "vzgojili" prvi ljudje, ki so prispeli na kontinent. Narava se je skozi tisoče let tem okoliščinam prilagodila. Prihod evropskih priseljencev je v to dinamiko znova posegel in to na način, da omogoča večje in bolj nevarne požare.
Seveda klimatske spremembe pomembno prispevajo k problemu, samo ne pozabiti, da ima trikotnik tri oglišča in eno izmed njih je tudi gorivo.
jype je izjavil:
Mhm, zato ker je Bližnji vzhod resnično on-topic, mar ne?
zmaugy ::
jype je izjavil:
Tale je kul:
https://twitter.com/seanpowerAU/status/...
Pa tale slikca iz tweeta:
https://mobile.twitter.com/Ashfallen0/s...
Ker je atmosfera ena?
Biseri...
neumnosti.
  • spremenilo: zmaugy ()
AndrejO je izjavil:
Drži. Glede na to, da fake news koncept odlično deluje in da je vedno sestavljen iz zrna resnice tel kopice ideološkega balasta, ne vidim razloga, da tehnike ne bi uporabljal, dokler se jo dovoli katerikoli strani.
AndrejO je izjavil:
Ne, ni, a nič za to.
AndrejO je izjavil:
Ja, za "redwood forests" to resnično drži, a hkrati nima nobene povezave s tem, da so požari danes pogostejši in večji predvsem zato, ker je v atmosferi več antropogenih toplogrednih plinov, posledica so pa ekstremni vremenski pojavi, med katere spada tudi večletna suša.
AndrejO je izjavil:
Ja, saj, vostok je evropejec.
To, da kitajci spuščajo v zrak, vodo in zemljo vse živo, te pa ne moti? Prav tako ne, da 24/7 izginjajo tropski deževni gozdovi in podobne katastrofe, ki jih tudi zaradi našega lagodja izvajajo po vsem svetu.
Tako, da, sekiraj se za vse katastrofe tega sveta. Ali pa za nobeno. Manj stresno je drugo.
Vidim, da tebe ne moti, da tvoj sosed otrokom daje v juho strihnin.
Samo tvoji dobivajo to.
Če bi te motilo, bi kaj rekel!
vostok_1 ::
jype je izjavil:
Spet se tako sramuješ svoje arijske polti. Afrika je dandanes zelo dostopna, ne vem kaj še delaš na nacističnem severu.
Reycis ::
Globalno segrevanje, pljuča sveta gorijo, katastrofa, co2, AaAaAaAaAaA. Takoj moramo začet živet kot amiši in vse premoženje (vključno s teritorijem) predat plemenitim črncem*. To je edini način da preprečimo totalno globalno katastrofo.
*to dejansko pomeni njihovim belim zaveznikom (aka. Jajpu in njegovi klapi) ker samo oni to lahko izpeljejo pravilno in pravično.
Riff ::
tole pa je en velik problem tile požari v Astraliji :8)
zmaugy ::
Kdo pravi, da me ne moti?
Reycis je izjavil:
A si danes že pojedel kakšen bankovec za 20 EUR?
Biseri...
neumnosti.
nsa_ag3nt ::
Kanadarjev (cl 415) in podobnih zadev nimajo ?
Gledam posnetke in vidim samo neke male helikopterčke.
https://gizmodo.com/c/goodbye-big-five
  • spremenilo: nsa_ag3nt ()
Reycis je izjavil:
Dej drugič vsaj TRR napiši zraven, da folk ve, kaj mora naredit.
Ti pomagam, kaj pravijo australci o pozigih v https://australiascience.tv/the-amazon-...
Redorange ::
Eni ste res polni samih sebe. Pripravljeni ste se dajat po forumu, raje kot usmerit to energijo, da bi kaj dosegli. Fanj, vso srečo naprej v življenju s takim odnosom.
Scott Morrison rejects calls for more bushfire help, saying volunteer firefighters 'want to be there'
Australian PM Scott Morrison says he will 'accept the criticism' for vacationing in Hawaii as fires raged back home
in še zadnja njegova
Australia's PM Scott Morrison says there's 'no better place to raise kids' as deadly wildfires burn
Drgač dim je dosegel Novo Zelandijo do te mere, da stavijo mokre brisače pod vrata. Slike so v komentarjih
Australia's bushfire smoke spreads to NZ as Canberra's air quality is more than 21 times the hazardous rating
MasterTade ::
požare so si sami izvolili
Mors omnia aequat
Tako je. Naši desničarji pa še kar sanjajo, da jim bomo dovolili enako storiti pri nas.
O smiselnosti gasilskih društev (strani: 1 2 3 )
11524579 (9765) titovili
Zakaj Slovenija nima "kanaderja" (strani: 1 2 3 )
11929359 (14563) Goran's Blog
Štirideset let po nesreči pri vrtanju krater še vedno gori (strani: 1 2 )
7424533 (18888) WarpedGone
Požari (strani: 1 2 )
688306 (6950) Thomas
