Forum » Strojna oprema » Epox prenehal s proizvodnjo 8RDA+ :(
kuglvinkl ::
Od EpoxTech:
According to the product manager, EPoX has discontinued the 8RDA+. Whether it will be back or not, we have no news at all - it may or may not be speculation. The 8RDA3+/G is the official replacement for the 8RDA/+ boards and was always planned as such AFAIK. At some point, board revisions become more cumbersome than simply releasing a new model and the 8RDA+ has been through more revisions than most (this is just my personal opinion).
Remember that just because it is discontinued does not mean it is not supported. Once again from my personal standpoint, most BIOS updates for the 8RDA3 series would seem to be applicable to the 8RDA series with little effort (look at the last batch of updates for both series - they contain the same fixes), and we may see BIOS updates for the 8RDAs for some time to come. For the North American customers at least, your boards came with two year warranties - and better yet we have no time limit, cutoff or anything like that when it comes to support on out of warranty boards (we just can't RMA them).
kuglvinkl ::
Vasko, ne najdem?
Ampak so pa beboti. Edini plati z MCP-T sta 8RDA+ in 8RGA. Kar sploh ne bi bilo hudo, če bi imeli v roadmapu nove revizije z MCP-T, amapk jih NI.
Tole je seznam plat.
In tole:
Tole:
naj bi bil novi high-end.Super se mi zdi (Dual LAN, externi sicer), samo zakaj zaboga se ne morejo stegnt še za MCP-T, tako in tako bi ga plačali.
Specifications of mainboard
• 5 x PCI slots
• 1 x AGP 8 x Slot colour coded purple
• 3 x DDR400 DIMM slots
• Agere 323 IEEE1394a with 3 ports by flywire bracket
• 1 Floppy drive controller - 2 serial ports - 1 parallel port
• 2 standard IDE ports for ATA-133, backwards compatible with ATA-33/66/100
• 4 USB 2.0 ports
• Onboard sound, 6 channel CMedia C9739a Audio Supports Digital SPDIF and software AC-3
• Standard ATX format 305 x 245mm
• Onboard Dual 10/100 LAN
• Onboard Serial ATA support for 2 drives (including RAID) (EP-8RDA3+ Only)
• Onboard P80P diagnostics LED
• Multiphase power solution for increased stability, including 12v supply adaptation for CPU
In tole:
Tole:
• 5 x PCI slots
• 4 USB 2.0 ports
Samuel ::
ne vem o cem ti govoris, a dal si link od 8RDA3+ in sicer v2.x,
ki jo itak lahk kupis ze nekaj casa v SLO.
jaz govorim o 8RDA+, ki bo kmalu na voljo;
bo pa verzija 2.0 za razliko dosedanjih verzije 1.0 in 1.1.
nodes ::
In kdaj bo izginila is cenikov, to včasih traja.
res ni zamenjave, za to ceno, čeravno ni imala SATA, kar bi pa postal problem.
Zakaj revizija? a bo potem to 3 s tem zvokom.
kuglvinkl ::
Govorim ti o tem, da bodo nehal delat 8RDA+ 2.0. Link zgoraj je naslednik 8rda+, ki NIMA MCP-T. Če bo dobavljiva, bo to iz lagrov.
Bentim nad tem, da ne bo (razen, če ima Vasko oz. AOA prav) NOVE plate z MCP-Tjem.
Upam pa, da jih sreča pamet. Ker 8RDA+ je IMO najboljša zadeva, ki se je Epoxu zgodila po KT266A.
Samuel ::
v Evropi sta bili na voljo le verziji 1.0 in 1.1 (8RDA+), verzije 2.0 ni bilo.
V kratkem bo na voljo tudi 8RDA+ v2.0, kar si ze verjetno ugotovil (ce si sel se kam kaj prebrat).
na kratko: ploščo so vrnili v proizvodnjo in bo na voljo v kratkem...
8RDA3+ je pa na voljo ze kar nekaj mesecev.
nodes ::
rev 1. System clock supports 200/266/333MHz
rev 1.1 System clock supports 200/266/333MHz + 2 ports IEEE 1394 (firewire™)
rev 2.0 System clock supports 200/266/333/400 MHz
kar nekaj časa sem jih že kupoval
kuglvinkl ::
Ok, ti bom narisal.
Rev. 2.0 so že NEHALI DELAT. Edino kar je, jo utegnejo vrniti v proizvodnjo.
from ET: Due to very popular demand, the EP-8RDA+ will soon be back...........
morphling1 ::
Mondeo 8RDA 2.0 je že lep čas v Sloveniji, kolega jo je kupil pri Mlacomu vsaj dva meseca nazaj pač enako kot 8RDA 1.1 samo da ima nforce2 ultra čipset oz. SPP.
Je pa res škoda da jo bodo prenehal izdelovat, tudi meni je bila to zelo dobra plata.
morphling1 ::
Vem kaj misliš
, samo so mu v bistvu zamenjal za umrlo 8RDA rev 1.1
VASkO ::
@Mondeo
8RDA+ v2.0 se je ze kar nekaj casa dala dobiti pri nas, 2.1 pa sploh ne
@kuglvinkl
http://www.aoaforums.com/forum/showthread.php?t=20603
poglej post #15
@kuglvinkl
poglej post #15
OwcA ::
Vsi, ki govorite o rev 2.0, ki bi jih naj pri nas kupili. Hočete reči, da je na PCBju pisalo rev 2.0 in je bil SPP aktivno hlajen, MCP-T pa pasivno?
OwcA ::
@nodes: tisto je rev 1.x, 2.x ima aktivno hlajenje SPPja, pasivno hlajenje MCP-Tja, dodaten +12 V konektor za napajanje procesorja in iz BIOSa nastavljiv Vdd.
nodes ::
Narobn link sem zalepu. Jasno je 1.1
Sam Epox nima nobene ažurnosti.
Naj ne bi nobena 8RDA+ imela aktivnega hlajenja.
Me ma, da bi nalepko dol utrgu......sam ni moj komp
Tamle je škatla, ki je enaka, etiketa je drugačna nič ne piše revizije.
Škatla od ultre potem ne more biti plata not 1.1.
ko bom ugasnu še mal bios prebrskam.
OwcA ::
Hm, malo zamešal, očitno ima samo 8RDA3 rev 2.0 aktivno hlajenje.
Seveda je laahko.
| » | Epox 8RDA3+ in USBOddelek: Strojna oprema | 1603 (1536) | Samuel |
| » | Navijanje NF7-SOddelek: Navijanje | 2140 (1492) | MEDENA |
| » | Dobra plata za amdOddelek: Kaj kupiti | 1815 (1563) | MEDENA |
| » | Katero nForce2 plato (strani: 1 2 3 4 … 7 8 9 10 )Oddelek: Kaj kupiti | 37305 (23900) | Jaffa |
| » | Epox 8rda+ ali Asus A7N8X-XOddelek: Kaj kupiti | 1600 (1526) | TribesMan |
