Forum » Problemi človeštva » Arktika v plamenih
Arktika v plamenih
http://www.bbc.com/future/story/2019082...
Fires in the Arctic also have huge implications for the global climate. Boreal forests and Arctic tundra cover 33% of the global land surface, and hold an estimated 50% of the world’s soil carbon – more carbon than is stored in all the world’s vegetation, and equal in size to the amount of carbon in the atmosphere.
Because conditions in the north are so cold, microbial growth and decomposition are much slower than in the tropics, so carbon is stored in layers of permafrost rather than recycled back into the nutrient cycle through vegetation growth.
In other words, if the forests burn and tundra melts, we could dramatically increase the amount of carbon in our atmosphere – essentially rendering useless even the most coordinated global attempts to cut global emissions.
In a research paper from 2015, Turetsky explains how smouldering fires are actually a much greater threat to the global climate. They burn for much longer, so they can transfer heat much deeper into the soil and permafrost, overall consuming twice as much carbon-rich fuel as normal fires.
“The really bad news is that big fires can move through a landscape and tap into old carbon layers that had been removed from the atmosphere thousands of years ago,” explains Turetsky. “When 100,000-year-old carbon is released back to the atmosphere, that’s the stuff of true positive feedback.
- zaklenilo: zee ()
Vazelin ::
Dokler to ne bo na CNN ne bo nihče tule triggeran.
https://edition.cnn.com/2019/07/24/worl...
https://edition.cnn.com/2019/08/06/asia...
Semafor ::
Skrajni čas da povišamo co2 davke, da bojo lahko elite zgradile svoje vile na lokacijah ki ima ugodno klimo.
Aaa, ledeniki nam gorijo! Arktika je vendar Hladilnik planeta, bo kdo ukrepal?
Nakar dobiš take članke:
https://www.forbes.com/sites/michaelshe...
- spremenil: Miki N ()
Semafor ::
Same elite in moralni vodje ki živijo v vilah, se naokoli furajo s privat jeti in raji velijo da si morajo rit brisat z roko ker skret papir škoduje naravi.
zmaugy ::
Uvodna misel OPa pa je? Copy-paste?
Biseri...
neumnosti.
neumnosti.
Zgolj ozaveščanje kolega. Bi paste-al v vašo temo, pa ste jo tako zatrolali, da so jo zaklenili.
https://www.newsweek.com/fracking-u-s-c...
- spremenil: Poldi112 ()
49106 ::
Povej, kdo požiga gozdove, da vemo koga poslati na gulag.
Ne vidim povezave z Arktiko v plamenih.(Priznam, da sem članek preletel)
Povezava je, da je oboje slabo kar se tiče globalnega segrevanja. V gulag pa lahko pošlješ one, ki rušijo okoljsko regulacijo in se gredo fracking.
49106 ::
Kdo to počne v primeru Arktike v plamenih?
Že, že, ampak to paše v drugo temo, na primer v tisto o globalnem segrevanju.
- spremenilo: 49106 ()
Ravno zato te imajo naši otroci pravico umoriti in pravilno kompostirati, preden še bolj ogroziš njihov obstoj s svojim neodgovornim vedenjem.
- spremenilo: jype ()
Semafor ::
Vazelin ::
Jaz se ne furam z zasebnimi letali po svetu kot razni okoljevarsvetniki tipa Di Caprio, ki mislioj da lahko delajo kar hočejo, če dajo malo organizacijam ki se kao ukvarjajo z okoljem
- spremenilo: Vazelin ()
Vazelin ::
Če vsak dan kupim 10 plastičnih vrečk oznesanžim v življenju manj od ene poti z zasebnim letalom povprečnega "okoljevarstvenika"*
* 10 x pod narekovaji
Urbano#Desno ::
Če vsak dan kupim 10 plastičnih vrečk oznesanžim v življenju manj od ene poti z zasebnim letalom povprečnega "okoljevarstvenika"*Slab si v računstvu.
Urbano#Desno je izjavil:
Lepo jih vzgajaš. :=) Lahko so ti v revolucionarni ponos. A nje tovarišTako kot imaš ti pravico do samoobrambe, jo imajo tudi oni.
Semafor ::
Otroci lepijo slike pepeta na fejsbuk pa sošolcem pravijo kakšen pederas je služabnik njihove mame.
Teli sodobni naciji so res pojave. Vsi se prilagodiji času, da lahko uspevajo... Žalostno videt kako nizko lahko nekateri padejo.
Vazelin ::
Kdor potuje z letalom zaradi turizma in za zabavo je okoljski kriminalec
jype itak potuje po svetu z električnim vlakom :D
zee ::
Tole je pa eskaliralo prav ekspresno.
zee
- spremenilo: zee ()
| » | Leto 2019 drugo najtoplejše leto (strani: 1 2 3 4 )Oddelek: Novice / Znanost in tehnologija | 55402 (51492) | BigWhale |
| » | CS-1, računalnik z največjim procesorjem v zgodoviniOddelek: Novice / Procesorji | 10479 (9299) | zee |
| » | Global hoaxOddelek: Loža | 16346 (15383) | vostok_1 |
| » | IPCC: Hitrost globalnega segrevanja manjša, a le po naključju (strani: 1 2 3 )Oddelek: Novice / Znanost in tehnologija | 45484 (35446) | NSA Agent |
