Forum » Igre » Kingdom Come: Deliverance 2
Kingdom Come 2 Most Likely to be Powered by CryEngine
Our editor conducted an extensive interview with Tobias Stolz-Zwilling from Warhorse Studios. One of the topics of the interview was the CryEngine technology, which was used in the development of the RPG Kingdom Come: Deliverance. It is more than likely that the sequel will also be powered by this technology.
https://www.gamepressure.com/newsroom/k...
“We don't want to change it for a simple reason: we've created so many tools for it, we've adapted it well enough... CryEngine hasn't been used in RPGs before. We've done so much around this engine that we're afraid abandoning it would mean starting from scratch. And considering how long it took us to get CryEngine into the game, it would simply be too much. So we hope for further good cooperation with Crytek,” the dev said.
Prva igra je bila kar velik uspeh tako, da ni dvoma, da ne bo drugega dela.
Kurzweil ::
Leta sem čakal prvi del, do sedaj pa sem ga igral točno 30 min. Sem si rekel, da počakam še par popravkov, da bo igra malce bolj optimatizirana in popravljena, kar je normalno pri veliki večini (če ne kar vseh) malce večjih RPGjih. Naj mi nekdo pove, je KC:D sedaj že tolk "popatchana", da se je lahko počasi lotim?
Za drugi del pa mislim, da ni nobenega straha, če bo kreativnost in želja takšna kot pri prvem delu + precej večja ekipa in budget, potem ne vidi razloga za kaj slabega, edino če se ne bo novi lastnik preveč vmešaval, kar se rado zgodi...
Zdaj je že 1 leto in pol od izida tako, da bi morala biti.
edino vprasanje ce bo enako vzdusje, zdej ko so se prodal...
To je zdaj vprašanje ja koliko se bodo vmešavali v njihovo delo.
- spremenil: oo7 ()
LunKi ::
Zadeva je polished and finished. Mislim, da so izdali tudi zadnji DLC in patch in se posvečajo KCD2.
Kurzweil ::
To je uradno, kar se tiče patchov in DLCjev, pa mi naj kdo pove, kako je v praksi? gameplay dela normalno? questi gredo gladko? fight je proper? potem razni glitchi kar se geometrije tiče? še padajo FPSji na določenih grafičnih karticah?
LunKi ::
Preigral. Best game od Mafie naprej. Kot receno je development finished. Meni je vse delalo super, se zadnja dva DLC-ja mam za prespilat. Ni nekih bugov in problemov. Je pa zahteven combat, sploh na zacetku te un se med lokalnim brawlom skoraj zmelje. Potem je lazje. Bolje kot je, ne bo nikoli razen verjetno unofficial patchi:)
Tako dober, da sem po desetletju kupil prvi game, celo collectors edition.
Kurzweil ::
Evo si me prepričal, se je počasi lotim. Prvič, ko sem igral, me je sfocal on čisto ta prvi v vasi
overload ::
Ja, trenutna različica je dodelana dovolj, da med igro nisem naletel niti na en vecji bug. Mogoče največji fail je bil pri enem questu, kjer sem dobil najboljši meč in je bilo relativno na začetku.
Je pa igra ena izmed najboljših, kar sem jih igral. Morda potrebuje še nadgradit bojevanje v areni, da bi bila še kakšna stopnja težavnosti višje, morda boj na konju pa tudi uporaba loka ni bila nekako zelo dodelana.
Se pa že veselim novega dela.
LunKi ::
Evo si me prepričal, se je počasi lotim. Prvič, ko sem igral, me je sfocal on čisto ta prvi v vasi![]()
Evo točno ta mi je ostal v spominu. Res je težak ta prvi oz. moraš biti potrpežljiv, ker kar nekaj časa traja da ga knockaš out.
Drugače ti pa tudi najboljši meč kaj preveč ne pomaga, bolj je potrebno obvladati combat še posebej ko je več nasprotnikov.
Kingdom Come Deliverance sequel could be revealed at E3 2021
https://www.gamesradar.com/kingdom-come...
Prva igra KCD, ko enkrat padeš notri je fenomenalna :)
Čehi ga razturajo. Pa izid še letos, šokiran sem.
DEI aktivisti pa spet v jok in na drevo, ker ne bo not črncev in pedrov.
- spremenil: Zmajc ()
Furbo ::
Hear ye! The official release date for #KCD2 is 11 February 2025.
Polda ::
Saj si zaslužijo pa ne samo nominacije tudi zmago. Ampak ta bo šla verjetno kakšni drugi bolj znani franšizi.
Kurzweil ::
Kingdom Come: Deliverance 2 je dobila na Gamescomu nagrado za najboljšo igro!
Tole bi bilo pa res zanimivo videt z nekega analitičnega stališča, koliko se bo število pre-orderjev recimo zdej povečalo. Na, zdej pa me spet majo, da bom čakal teh par mesecev... lahko samo napišem, respect celotni ekipi Warhorse, da bo od najave do izida igre tako malo časa oz. da je igra očitno ob najavi že bila zelo daleč v razvoju. Pa ravno danes sem pisal v topic od Star Citizena, kako nas flancajo že celih 14 let z razvojem
Tole bi bilo pa res zanimivo videt z nekega analitičnega stališča, koliko se bo število pre-orderjev recimo zdej povečalo. Na, zdej pa me spet majo, da bom čakal teh par mesecev... lahko samo napišem, respect celotni ekipi Warhorse, da bo od najave do izida igre tako malo časa oz. da je igra očitno ob najavi že bila zelo daleč v razvoju. Pa ravno danes sem pisal v topic od Star Citizena, kako nas flancajo že celih 14 let z razvojem![]()
No me veseli, da so dobili nagrado za najboljšo igro.
Glede preorderjev ne vem kar se mene tiče bom kupil ob izidu ampak v fizični obliki hočem škatlo od igre :)
Si ti že preigral prvi del ?
Gregor459 ::
Kingdom Come: Deliverance 2 Preview - Greater and Grander
https://wccftech.com/kingdom-come-deliv...
Evolve ::
Huh tole pa komaj čakam.
Prvi del sem preigral res maksimalno (127 urc) pa bi ga še enkrat, če se bo izid dvojke zavlekel
sparklyslo ::
Jaz sem imel kar precej težav z uprabo meča in mečevanjem nasploh v prvi igri. Končal sem jo tako, da sem v 99% nasprotnike pokončal z lokom, pogosto povsem od blizu. Upam, da bo to možno tudi v drugi igri.
Kayzon ::
sparklyslo je izjavil:
Mene je boj na začetku tudi kar zajebaval potem pa sem veliko treniral pri Bernardu in kasneje mi je postal boj prav všeč. Ni bilo težav rabiti tri cumane ali bandite na enkrat. Sem pa največ uporabljal mace in meč.
V drugi igri bodo loki kot tudi samostreli.
Evolve ::
Prvi del sem preigral res maksimalno (127 urc) pa bi ga še enkrat, če se bo izid dvojke zavlekel![]()
Jaz sem preigral prvi del dvakrat. Obakrat užival maksimalno eden najleših svetov v igrah.
jst sem jo končal pred kratkim, tako da za še eno rundo bo treba mal počakat
Je pa tako kot si napisal, svet izjemen. Nekaj podobnega kot The Witcher 3 za moje pojme, kjer je vse spiljeno do pikice.
hehe tut mene je mečevanje mučilu od začetka, sploh sistem miške in vsega skupaj, ampak pol sem skužil ščit + meč in lok. Kar se je dalo sem pomoril v stealh mode, predvsem ponoči.
V drugem delu bo poleg lokov tudi samostrel, tako da bo še bolje pomoje
V drugem delu bo poleg lokov tudi samostrel, tako da bo še bolje pomoje![]()
Ja Kingdom Come in Witcher verjetno dve najboljši mapi. Boš pa imel v KCD II eno zelo veliko urbano območje z zelo velikim mestom in eno bolj podeželjsko področje s gozdovi, travniki, gradovi.
Ja menda bo mečevanje v drugem delu malo lažje ampak kar se mene tiče bi lahko bilo enako kot v prvem delu. Poleg lokov in samostrelov bo pa tudi zelo zgodnje strelno orožje katero se naj bi že takrat uporabljalo.
Gregor459 ::
Jst sem imel pa težavo z uporabo loka.
Furbo ::
Ja saj tudi lok ni kar snajper takoj, moraš pomoriti za en komplet prebivalstvo Kočevskega gozda, preden si dober z njim.
Gregor459 ::
Furbo ::
To moraš pa vklopiti v nastavitvah od monitorja ;)
Polda ::
Jaz sem v KCD uporabil dva moda. Eden je bil za lok, da mi je kazalo tisto piko in drugi mod za lažji lockpicking.
Kurzweil ::
Mislim, da bo še nekaj krajev iz 1. dela. Mislim, da pomanjšani in manjše bodo tudi razdalje oz. velikosti... sem pa skoraj prepričan, da ne bo celotne mape iz 1. dela. V drugem delu bo sicer mapa 2x večja... to veliko mesto bo mislim da Kutna Hora... sem bil tam velikokrat... v 13. stoletju je bilo to zelo razvito mesto, s precej rudniki, tako da povem mogoče, da bodo tam kakšni kovači in podobno, tudi sicer so tam nekoč izdelovali kovance in podobno. Je pa na Kutni hori tudi kostnica, katero sem že večkrat obiskal... pravi kriminal bo, če ne bo includana v igro. Interier te kostnice je narejen iz 40.000-70.000 človeških skeletov.
Polda ::
Mesto Kutenberg to je najbrž Kutna Hora.
A potem kot neke vrste Pariške katakombe. Nisem vedel, da imajo na Češkem tudi to.
Kurzweil ::
Ne ne, manjša zadeva, dejansko cerkev/kapela. Vidim, da je celo v Slovenščini -> Kostnica Sedlec
... nekak se mi zdi, da nalašč za includad v igro tip KCD.
p,s.
Ja, Kuttenberg je Kutna Hora... pomeni pa drugače Kutna Hora po naše nekak rudarska gora... seveda tudi idealno za igro tipa KCD...
p,s.
- spremenil: Kurzweil ()
Kurzweil ::
Kuttenberg bo mesto kjer se bo dogajalo. Vavra je rekel, da je zelo veliko mesto. Upam, da bo vsaj tako dobro kot Novigrad v witcherju ali še boljše :)
Ja, kot sem napisal... to veliko mesto bo Kutna Hora...
Kaj drugega tako ne more biti, ker je to kraj, ki je bil tudi takrat največji, tako po prebivalstvu, kot po gospodarstvu, razvitosti... torej za tisti čas ogromno mesto, še posebej za vasice, kot so v KCD... ko pa se sprehajaš tam pa vidiš, da niti ni veliko mesto... je recimo manjše kot neko Velenje, s tem, da zaradi arhitekture, torej ker ni veliko blokov... izgleda še manjše. Za čas, ko se dogaja KCD pa seveda veliko mestece, polno obrti...
Je pa zelo zanimivo dejansko tam hodit, ker se v igri res trudijo poustvarit zadevo. Ko sem se pogovarjal z Vavro, takrat še za prvi del mi je dejal da je trajalo mesece, ko s core ekipo hodili po teh krajih, slikali, merili...
Komaj čakam, da vidim kaj so naredili s tem mestom v igri KCD II.
V prvi igri naselje Rattay je bil res nekaj posebnega.
A tukaj v Rattay Rataje nad S%C3%A1zavou @ Wikipedia si tudi že bil kjer se dogaja prva igra ?
Gregor459 ::
Izi ::
Collector's Edition ima vključeno igro, Gold edition (ki sama stane 90€), zato je treba paziti katero verzijo kupiš za PC ali za konzole.
Collector's Edition so začeli prodajati en teden nazaj in do sedaj še ni bilo nikjer zaslediti nobene verzije za PC. Vse je samo za konzole.
Izbrali so samo dva ekskluzivna prodajalca, enega za Evropi in enega za Ameriko. Vse skupaj je primer za ekonomiste kako se zadeve ne smeš lotiti. Spet bodo služili samo preprodajalci
Collector's Edition v Evropi prodaja ekskluzivno samo Amazon. Ta je imel en teden nazaj na voljo par kosov za konzole, ki so pošli takoj. Od tedaj nimajo nič več. Cena je bila okoli 220 €.
V Ameriki ima ekskluzivo GameStop, ta pa ima ves čas zalogo ampak tudi ta samo za konzole. Cena je 200$. To je verjetno cena brez davka.
O Zbirateljski PC verziji zaenkrat ne diha ne sluha.
Daniel Varva na x-u
Yesterday, we were counting with our lead designer Prokop Jirsa, how much we actually wrote for KCD2. So guess how big the script is?
2 200 000 WORDS!
Or 11,000 typical screenwriting pages.
That's a 100 scripts for a typical two-hour movie.
Or about 25 average novels.
https://x.com/DanielVavra/status/182912...
Kingdom Come: Deliverance 2 is currently on track to set a new world record for the longest video game script of all time, a senior Warhorse Studios official has said. The said record is presently held by Baldur's Gate 3.
2 200 000 WORDS!
| » | The Witcher 4 (nova trilogija) (strani: 1 2 3 4 5 6 7 )Oddelek: Igre | 71250 (1112) | Gregor459 |
| » | Kingdom Come SalvationOddelek: Igre | 2176 (380) | oo7 |
| » | Kingdom Come: Deliverance (strani: 1 2 3 4 … 14 15 16 17 )Oddelek: Igre | 175705 (14040) | Predsednik11 |
| » | Clair Obscur: Expedition 33Oddelek: Igre | 3956 (1581) | Zmajc |
| ⊘ | Kingdom Come: Deliverance 2Oddelek: Igre | 1184 (1029) | BigWhale |
