Forum » Igre » Starfield
Starfield
Saj je prav, da ima Steam regionalne cene ampak dokler bodo v EU enotne cene bom kupil tudi preko Cd keys.
Drugače sem že kupil Starfield kar na Steamu, ker sem imel gor še denar od refundirane igre Star Wars.
https://thelegality.com/is-cdkeys-legit/
Kdaj bo možno igrati Starfield.
Premium verzija Starfield 1 september ob 02:00 uri
Navadna verzija igre Starfield 6 september ob 02:00 uri.
Starfield has an 'astonishing' amount of side quests and choices, Bethesda confirms
https://www.gamingbible.com/news/platfo...
Jaz tako kot ponavadi prvo večina stranskih nato glavni questi :)
Starfield reportedly matches Skyrim and Fallout for Achievements on offer
The new RPG will apparently have 50 Achievements at launch
https://www.gamesradar.com/starfield-re...
Talked to someone playing Starfield. This is what they had to say.
https://www.reddit.com/r/Starfield/comm...
Netrunner ::
Vsem, katerim se zdi igra predraga naj enostavno kot jaz počakajo na -75% na steamu. Bo za počakat ene dve leti, da bo cena ugodna vendar kvaliteta igre ne bo potem nič manjša oz. bo še boljša ker bodo bugi odpravljeni.
Izi ::
Kaj pa če vmes umreš? 2 leti je 1/40 življenja. Treba je uživati sproti
Zaenkrat vsi potrjeni kompanjoni v igri Starfield - https://www.ign.com/wikis/starfield/Com...
Glede na Amazon bo pre-load za igro Stalker možen že 9 avgusta ?
Xbox Series S - 1TB Black & Starfield Standard Edition - PRE-PURCHASE - Xbox & Windows 10 [Digital Code]
Pre-load after 08/09/2023. Game will be playable after 09/06/2023.
https://www.amazon.com/dp/B0CCVXJYHX?re...
Starfield is So Freaking Revolutionary it Invented its First of its Kind Genre That Doesn't Exist in Hollywood: "It just clicked"
https://fandomwire.com/starfield-is-so-...
After 23 years, Starfield's ancestor Noctis is still a vision of the future
https://www.eurogamer.net/after-23-year...
Je kdo igral to igro Noctis ?
- spremenil: oo7 ()
Starfield Features Cross-Save Support; "Xbox Play Anywhere" Tag Spotted On The Store Page
The wishes of fans have been heard.
https://exputer.com/news/games/starfiel...
Starfield igra bo imela Mission Boards. Verjetno nekaj podobnega kot Witcher 3 kjer si iz tabel dol pobiral listke.
Mission Boards Side Content Like
Quests
Contracts
Bounty
That would reward you with Exp/Credits/Loot/Resources
Quests
Contracts
Bounty
Kot kaže prelouda za igro Starfield ne bo (vsaj ne 9 avgusta) je bila napaka s strani Amazona.
Furbo ::
Seveda ne, to bodo pacali skupaj do zadnjega dne.
Tribal ::
Saj imaš release day patch v te namene. Kak teden prej pa bo sigurno preload...
- spremenil: Tribal ()
Verjetno bo ja nekaj dni prej preload. Čeprav meni je vseeno ali je preload ali ne, ker odkar imamo optiko bo teh 120 gb naloženih v nekaj minutah :)
111111111111 ::
Ob predpostavki, da bo store odprl tako pipico do tebe. :D
Ales78 je levi fašist.
111111111111 je izjavil:
A ni to odvisno od interneta kako hitro povezavo imaš ?
Sem nalagal MODe igri Ready or Not pa če kaj ni delalo sem zbrisal igro in še enkrat posnel. Tistih 90 GB je bilo naloženih mimogrede.
Določeni steam strežniki so bolj švoh, hrvaški recimo na katerega Slovence pogosto steam sam prešalta.
Buggy ::
Izi ::
Za navadne smrtnike ima Steam praktično neomejeno hitrost.
Če imaš 2,5 Gbitno linijo potem bo začelo občasno štekati ampak ne zaradi Steama, naš PC ne bo zmogel.
Na 2 Gbitni liniji pa Steam testirano vedno vleče do konca tudi v Sloveniji. Polnih 240 MB/s neprekinjeno.
Ampak 125 GB, koliko meri Starfield, tudi na 1 GBitni optiki ni ravno mimogrede kot pravi oo7. 1 GBit linija vleče okoli 120 MB/s kar za 125 GB pomeni 17 minut.
kako sam presalta, ce imas recimo fiksno nastavljeno AT ne dela kar po svoje ali pac?
Meni steam pogosto sam prešalta na hrvaško, Vsakič ko mam slow download je garantirano da se je steam sam ponastavil na CRO dowbload strežnik. Ne vem mogoče me zaradi geografske bližine hrvaškega strežnika prešalta tja.
Nastavim ga na AT in random čez čas spet sam prešalta na CRO.
Does Steam download region matter?
By changing the download region to servers closer to you, it should help to increase your overall Steam download speeds.
Izi ::
Ja, v Steam nastavitvah pod "Download" je nastavitev "Download Region", kjer pa ni Slovenije zato po defaultu izbere Croatio. Ta izbira je neodvisna od naše fizične regije in jo je pametno spremeniti na kakšno bolj razvito Evropsko državo.
Buggy ::
Zanimivo, nisem se tega opazil. Jaz imam fiksno AT tako kot ga nastavim, je pa mozno da se kej spremeni, ko se upgrade-a Steam klient. Mozno da je default vrednost odvisna tudi od tvojega ISP-ja.
- spremenil: Buggy ()
111111111111 ::
Pred optiko mi je igre vleklo dol tudi več ur tako, da je 17 minut za 125GB kar mimgrede :)
To ti pa verjamem. :) Samo včasih se meni na steamu pojavi bottle neck, ko vlečem kakšno večjo igro, pri Epic Games pa je to stalnica. :D
Buggy ::
...ponoci ko bo release pri nas, dvomim da bo kdo tako zagret in zelel spilat tisti trenutek...no vsaj upam da niste tolk nahypani. Dela se problem tam kjer ga ni...sicer pa 120GB za spil je danes nekaj cisto normalnega.
Mogoče ob izidu igre kjer je največ prometa pa zna kaj zaštekat ?
Sploh, ko je kakšna Steam razprodaja prve pol ure ponavadi sploh ne morem na stran.
Saj verjetno bo kakšen dan prej preload. Tudi zagreti bodo, da bodo igrali ob izidu :)
A tole drži če naj bi igra izšla povsod istočasno ?
Starfield is playable this month thanks to a classic trick
For those uninitiated, allow me to introduce you to the timezone trick. To put it simply, by going into your system settings on Xbox or PC and proclaiming that you live in New Zealand, you can essentially time travel several hours into the future.
https://www.gamingbible.com/news/starfi...
Furbo ::
Folk histerira, danes bi vsi vse takoj.
Jaz stalno prestavim na avstrijo, ker mi nekako na hrvate prestavlja. Glede downloada... Če se ne motim, je bil prenos na dan izida gta 5 tako švoh, da je prenašalo tudi manj kot 1mbs. Download ti en drek pomeni, če pa ma tisti, ki uploada premajhen upload ali jih pa več hkrati prenaša in izgublja na moči, ko downloadaš. Verjetno so se danes že pripravili na take mega igre, kjer se pričakuje večji oz masovni naval na igro ob dnevu izida.
Izi ::
Vedno znova in znova se pozablja, da se kabelski internet deli med celotno sosesko. Če si na kabelski in imaš paket v katerem je 1 GBit internet ne moreš nikoli reči, da imaš 1 GBit internet. To linijo si po mestih deliš z vsaj 100 sosedi in ker se danes TV gleda večinoma prek interneta, si ob večerih lahko srečen če vlečeš dol s 100 MBit tudi če imaš v paketu 1 GBit linijo. Če ti Steam zvečer slabo vleče so krivi tvoji sosedje ne pa Steam.
Optika direkt do tvojega računalnik je edini pravi internet, ki je čisto tvoj. Zato je Kebelski internet tako poceni, Optika pa tako draga. Za 1 Gbit interneta preko optike se plačuje okoli 55 €/mesec, na kabelski za ta denar dobiš TV, internet in telefon skupaj.
In tudi če imaš optiko so to ponavadi paketi s TV in potem marsikdo pozabi, da zvečer v eni sobi mama gleda mehiške nadaljevanke, v drugi sobi oče gleda nogomet, v tretji sobi sestra porabi ves upload ko streama svoj live porn video, ti pa poskusiš dol potegniti eno igro in ne gre nikamor
- spremenil: Izi ()
Očitno nameravajo zgraditi eno orenk franšizo okoli igre.
Ja poleg Fallout in Elder Scorls bo to nova franšiza Bethesde. Edino problem je, ker te igre hodijo ven čedalje bolj počasi.
Jaz bom pocakal, da vidim a bo se en Fallout 76 al jih je mogoce kaj izucilo. :>
To si pa upam stavit, da ne bo še en Fallout 76
- spremenil: oo7 ()
| » | Fallout New Vegas 2Oddelek: Igre | 5177 (219) | Zmajc |
| » | Fallout 5 (strani: 1 2 3 4 5 )Oddelek: Igre | 43942 (1237) | Enaplusdva |
| » | Avowed (Obsidian Entertainment) (strani: 1 2 )Oddelek: Igre | 10571 (3753) | TucoX |
| » | Fallout 76 (strani: 1 2 3 4 5 6 7 8 )Oddelek: Igre | 99391 (24148) | todman74 |
