Forum » Pomoč in nasveti » Windows 10 izklop posodobitev
Taubek66 ::
Pozdravljeni,
Mene zanima ali obstaja kakšen način za izklop posodobitev v windows 10 pro x64?
Hvala :)
Hvala :)
izklopiš windows update servis
al pa zalaufaš Destroy windows spying
- spremenil: iloveboobz ()
kixs ::
Podosobitve lahko izklopis, ce nastavis tvojo internet povezavo kot "metered":
https://www.howtogeek.com/226722/how-wh...
krneki0001 ::
S powershellom:
Clear-Host
Write-Host "0 -> Change setting in Windows Update app (default)"
Write-Host "1 -> Never check for updates (not recommended)"
Write-Host "2 -> Notify for download and notify for install"
Write-Host "3 -> Auto download and notify for install"
Write-Host "4 -> Auto download and schedule the install"
Write-Host "Enter any character to exit"
Write-Host
switch(Read-Host "Choose Window Update Settings"){
0 {$UpdateValue = 0}
1 {$UpdateValue = 1}
2 {$UpdateValue = 2}
3 {$UpdateValue = 3}
4 {$UpdateValue = 4}
Default{Exit}
$WindowsUpdatePath = "HKLM:SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\"
$AutoUpdatePath = "HKLM:SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU"
If(Test-Path -Path $WindowsUpdatePath) {
Remove-Item -Path $WindowsUpdatePath -Recurse
If ($UpdateValue -gt 0) {
New-Item -Path $WindowsUpdatePath
New-Item -Path $AutoUpdatePath
If ($UpdateValue -eq 1) {
Set-ItemProperty -Path $AutoUpdatePath -Name NoAutoUpdate -Value 1
If ($UpdateValue -eq 2) {
Set-ItemProperty -Path $AutoUpdatePath -Name NoAutoUpdate -Value 0
Set-ItemProperty -Path $AutoUpdatePath -Name AUOptions -Value 2
Set-ItemProperty -Path $AutoUpdatePath -Name ScheduledInstallDay -Value 0
Set-ItemProperty -Path $AutoUpdatePath -Name ScheduledInstallTime -Value 3
If ($UpdateValue -eq 3) {
Set-ItemProperty -Path $AutoUpdatePath -Name AUOptions -Value 3
If ($UpdateValue -eq 4) {
Set-ItemProperty -Path $AutoUpdatePath -Name AUOptions -Value 4
- spremenilo: krneki0001 ()
krneki0001 ::
Izklop Windows update:
Vklop Windows update:
https://betanews.com/2016/02/22/control...
stop-service wuauserv set-service wuauserv -startup disabled
set-service wuauserv -startup manual start-service wuauserv
Taubek66 ::
Stvar je taka, da je treba to nastaviti na cca 25 racunalnikov in me zanima način kako to narediti čim bolj praktično, ter hitro. Težava pri metered connection je v tem, da ni te opcije pri ethernet povezavi. Obstaja rešitev za to? Hvala :D
krneki0001 ::
A imaš na vseh računalnikih skrbniški račun? Preko mreže narediš skripto, ki se na vsak računalnik poveže in štarta skripto za izklop posodobitev.
En for stavek v powershell skripti. Tukaj imaš primer, kako remote laufaš powershell skripte (beri post od drack69):
https://www.reddit.com/r/PowerShell/com...
crniangeo ::
Imate active diectory? V kolikor je/ postavi wsus server
Convictions are more dangerous foes of truth than lies.
| » | Powershell primerjaj in kopirajOddelek: Programiranje | 1585 (1222) | Blisk |
| » | SMB povezava Winows 10 s Synology NASOddelek: Operacijski sistemi | 4419 (3685) | dukedl |
| » | Windows 10 Update OFF!!!Oddelek: Pomoč in nasveti | 2849 (2645) | Machete |
| » | Zaradi hude ranljivosti bodo Intelovi procesorji do 50 odstotkov počasnejši (strani: 1 2 3 4 … 10 11 12 13 )Oddelek: Novice / Procesorji | 185072 (155064) | krneki0001 |
| » | Windows 10 z reklamami tudi v Raziskovalcu (strani: 1 2 3 )Oddelek: Novice / Operacijski sistemi | 58563 (52127) | D3m |
