Forum » Strojna oprema » AMD RX Serije
AMD RX Serije
Ciklamen ::
Sapphire NITRO, tista ki je malo "podhranjena" v smislu hitrosti spomina (7000 MHz napram 8000 v Nitro+)
- End of the Post ->
D3m0r4l1z3d ::
https://www.techpowerup.com/231079/is-d...
Obvezno branje za vse dx12 entuziaste, Is DirectX 12 Worth it
NightHawk ::
Predator X je izjavil:
http://www.tomshardware.com/reviews/for...
A ni toms podkupljen? Ali je kdaj OK kdaj pa podkupljen, odvisno od vremena?
AapocalypseE ::
AMD Radeon RX 500 Series to launch in April
The Radeon RX 580 will be rebranded from RX 480. The new model will receive a moderate clock speed bump to 1340 MHz. That's 74 MHz more than RX 480. Meanwhile, the RX 570 is said to be 38 MHz faster than RX 470. Of course, those are just the reference clocks and they might be changed as we get closer to the launch. Both RX 580 and RX 570 will be available in 4GB and 8GB variants.
In entry-level segment, we expect Radeon RX 560 to be rebranded from Radeon RX 460 with 1024 Stream Processors (but that's unconfirmed). We do however have information that RX 560 may be clocked at 1287 MHz (87 MHz above RX 460).
There is one more card mentioned by Heise, which is RX 550. This model is most likely equipped with Polaris 12, a new low-end GPU, which is just as mysterious as Vega11.
https://videocardz.com/66359/amd-radeon...
- spremenil: AapocalypseE ()
D3m0r4l1z3d ::
Pričakovano, tudi konkurenca dela isto, le manjka jim kakšen high end čip, kot je gp102
Malenkosten.
Zgleda, da so yieldi za malenkost boljši. To je pa tudi to
- spremenilo: FireSnake ()
iloveboobz je izjavil:
heh, polaris10 lives on :)
Čip je dober, bojo poglacali proces...mal bo šla dol poraba, frekvenca malo gor, mogoče še kej rama zraven mogoče mal hitrejšega, pa bo ene 15% Boosta, pa smo pri GTX 1070. Za 200 evrov.
Čist solidno.
- spremenilo: Telbanc ()
poper ::
Ima še kdo problem z ventilatorji, ki se občasno ne zaženejo na MSI RX 480 Gaming X kartici? Problem je identičen temu, le da se mi še ni zgodilo da bi se oba ventilatorja istočasno zataknila (včasih se en, včasih drug): .
Svojo bom poslal v garancijo na Mindfactory. Ali mogoče kdo ve če zamenjajo celo kartico ali samo hladilnik/ventilatorje? Kajti sem kar zadovoljen z overclockanjem kartice (1400/2250 stable @ stock volts), tako da bi raje videl, če bi menjali samo cooler :)
GenZNPC ::
Ce jo odvijes se dogaja isto?
Se ti ventilatorji zataknejo za vedno ali pa so na mejni vrednosti slucajno, ko bi se en ventilator moral prizgat?
skibidi
poper ::
Dogaja se tudi ko je kartica na tovarniških nastavitvah.
Ventilator je na meji vrtenja, rahlo trza kot da se hoče zavrteti, a nima moči za to. Tudi ko ročno nastavim fan speed na 100% se ne vrti. Treba ga je ročno zagnati, že rahel dotik je dovolj.
Sumim pa da se to zgodi le, ko se ventilator ustavi v točno določenem položaju. Ker ko ga po tem, ko se zatakne z roko zasučem za nekaj stopinj (seveda ko je ventilator na 0%), se ob naslednji obremenitvi normalno zažene.
neboben ::
mogoč nis prklopu vseh pinov ?
ene kartice rabijo 6-pin in 8-pin priklop.
eh sele zdej vidm da je tvoji samo 8 pinski
- spremenil: neboben ()
i mean, it makes sense. Polaris je kr sestradan za ram, tko da kakšen 11Ghz gddr5x pa ~1350mhz clock bump bi kr pasu
AapocalypseE ::
Če bi to bilo res, bi amd to kartico opeval kot čisto novo tehnologijo in bi bilo hypa zraven na polno...
Predator X ::
AapocalypseE je izjavil:
Če bi to bilo res, bi amd to kartico opeval kot čisto novo tehnologijo in bi bilo hypa zraven na polno...![]()
Se bi lahka ti mal umiril "Irresponsible amounts of trolling"
https://a.disquscdn.com/uploads/mediaem...
D3m0r4l1z3d ::
Lol, so true
Ne bo gddr5x v rebrandeonih, ker so to cheapo midrange segmentirana jajca na nivoju 2014 maxwella
D3m0r4l1z3d je izjavil:
Lol, so true
Na nivoju GTX 980 and above?
Wow. Awesome AMD.
Master_Yoda ::
kompletno grafo. Pa tudi poštnino krijejo
Offtopic:
Uh, te pa res srcno upam da mi moja GTX 960 crkne pred iztekom garancije, ce imajo tako dobro politiko glede garancije.
klinker ::
Edino kar je zdaj za AMD pomembno pri grafah je performans Vege, ki ce ne bo totalno posekal 1080 in bil na nivoju 1080Ti, bo sranje.
Polarisu je cena zdaj padla in je vsekakor boljsi nakup napram vsaki 1060ki, zdaj naj se za highend poskrbijo in bomo vsi veseli.
GenZNPC ::
Hec na stran, kdaj misli AMD prilezt na 1080 kaj sele 1080Ti performance?
Jeseni? Pozimi?
Jeseni? Pozimi?
skibidi
D3m0r4l1z3d ::
Lol, so true
Wow. Awesome AMD.
September 2014 aka z malim je lepo biti zadovoljen.
Predator X ::
uf, sej tu ni noben fanboy.
amd je razocaral v vseh segmentih. i7 7700k pa gtx 1080ti, ostalo so pa console peasants
- spremenilo: Predator X ()
Sami ::
amd je razocaral v vseh segmentih. pa i7 7700k gtx 1080ti, ostalo so pa console peasants
Ob splavitvi in še 2 meseca po tem si imel srečo če si sploh kje dobil RX480, Ryzen je že vnaprej razprodan...res so razočarali ja, mogoče bi morali naviti ceno :D Sej v konzoli si pa tudi na AMD-ju :D
- spremenil: Sami ()
D3m0r4l1z3d ::
Ne razumem, saj si napisal midrange na nivoju highend?
Lepo od tebe, da priznaš, da ne razumeš. En plus za tvoj karakter.
D3m0r4l1z3d ::
D3m0r4l1z3d ::
Nimam, me pa vsakič d3m preseneti, tako da mogoče le pozabljam s kom imam opravka.
Nič, grem v Pascal temo, tam še ni rebrandov.
| » | Grafična kartica (strani: 1 2 3 4 … 206 207 208 209 )Oddelek: Kaj kupiti | 1691400 (4324) | iloveboobz |
| » | Gtx 1060 ali RX 480 (strani: 1 2 3 4 … 25 26 27 28 )Oddelek: Kaj kupiti | 272773 (236485) | Predator X |
| ⊘ | AMD Radeon R9 400 Series (strani: 1 2 3 4 … 118 119 120 121 )Oddelek: Strojna oprema | 957411 (814067) | gddr85 |
