Forum » Pomoč in nasveti » Ubuntu - problem s paketom
Grizzly ::
Poskušam namestiti en program (sudo apt-get install), vendar mi izpiše tole:
Kako se rešim te napake, da bom program lahko namestil?
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
kolourpaint4 : Depends: kde-runtime but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Grizzly ::
sudo apt-get install kde-runtime
Če napišem "sudo apt-get install kdelibs5-plugins", mi spet javi neko drugo napako. Tako se vrtim v začaranem krogu.
kde-runtime : Depends: kdelibs5-plugins (>= 4:4.13.0) but it is not going to be installed
Grizzly ::
Tudi to javi podobno napako. Škoda živcev, pa tudi časa za ugibanje nimam. Bom verjetno jutri formatiral in si prihranil čas.
Grizzly ::
Tudi to ne dela. Pregledal sem že vsako stran, ki jo Google najde. Več nimam kaj iskat. Nekje je prišlo do napake in sedaj večino programov ne morem instalirat, tako da s takim sistemom nimam kaj delat.
| » | inštalacija starejše verzije vlc na linux mintOddelek: Pomoč in nasveti | 1668 (1452) | hogorq |
| » | Ubuntu vprašanja (strani: 1 2 3 4 … 19 20 21 22 )Oddelek: Operacijski sistemi | 247939 (116778) | poweroff |
| » | [ARM] Problem pri prevajanju kodeOddelek: Programiranje | 1230 (1135) | Hayabusa |
| » | Debian Gnu/Linux kot workstation (strani: 1 2 3 4 … 37 38 39 40 )Oddelek: Operacijski sistemi | 127630 (43304) | RedDrake |
| » | [ubuntu] nepreverjeni paketi na si.archive.ubuntu.com ?Oddelek: Programska oprema | 1310 (1195) | MrStein |
