Forum » Programska oprema » [ubuntu] nepreverjeni paketi na si.archive.ubuntu.com ?
Updatam Ubuntu 9.04 in mi za ene pakete teži, da si nepreverjeni (nepodpisani).
server je si.archive.ubuntu.com
Vzrok za skrb?
Vzrok za skrb?
OmegaBlue ::
Šaltaj na drug repozitorij in poglej če je isto?
V angleščini pravi : cannot be authenticated
in: without verification
hmm, na us.archive.ubuntu.com pa ne jamra.
Heknili si.archive ???
Ali pa se admininom ni dalo urediti ključev (ali karkoli je že odzadaj za preverjanje) ...
OmegaBlue ::
Jaz bi raje uporabljal kak drug repozitorij ;)
denial ::
Meni nič ne jamra...
krneki@ubuntu:~$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages will be upgraded:
firefox firefox-3.0 firefox-3.0-branding firefox-3.0-gnome-support
firefox-gnome-support gnome-terminal gnome-terminal-data libpam-modules
libpam-runtime libpam0g xulrunner-1.9 xulrunner-1.9-gnome-support
12 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 10.2MB of archives.
After this operation, 8192B of additional disk space will be used.
Do you want to continue [Y/n]? y
Get:1 http://si.archive.ubuntu.com jaunty-updates/main libpam-modules 1.0.1-9ubuntu1.1 [308kB]
Get:2 http://si.archive.ubuntu.com jaunty-updates/main libpam-runtime 1.0.1-9ubuntu1.1 [96.5kB]
Get:3 http://si.archive.ubuntu.com jaunty-updates/main libpam0g 1.0.1-9ubuntu1.1 [112kB]
Get:4 http://si.archive.ubuntu.com jaunty-updates/main firefox-3.0-branding 3.0.14+build2+nobinonly-0ubuntu0.9.04.1 [202kB]
Get:5 http://si.archive.ubuntu.com jaunty-updates/main xulrunner-1.9-gnome-support 1.9.0.14+build2+nobinonly-0ubuntu0.9.04.1 [39.4kB]
Get:6 http://si.archive.ubuntu.com jaunty-updates/main xulrunner-1.9 1.9.0.14+build2+nobinonly-0ubuntu0.9.04.1 [7561kB]
Get:7 http://si.archive.ubuntu.com jaunty-updates/main firefox-3.0-gnome-support 3.0.14+build2+nobinonly-0ubuntu0.9.04.1 [84.9kB]
Get:8 http://si.archive.ubuntu.com jaunty-updates/main firefox-3.0 3.0.14+build2+nobinonly-0ubuntu0.9.04.1 [888kB]
Get:9 http://si.archive.ubuntu.com jaunty-updates/main firefox 3.0.14+build2+nobinonly-0ubuntu0.9.04.1 [69.4kB]
Get:10 http://si.archive.ubuntu.com jaunty-updates/main firefox-gnome-support 3.0.14+build2+nobinonly-0ubuntu0.9.04.1 [69.3kB]
Get:11 http://si.archive.ubuntu.com jaunty-updates/main gnome-terminal-data 2.26.0-0ubuntu2.1 [610kB]
Get:12 http://si.archive.ubuntu.com jaunty-updates/main gnome-terminal 2.26.0-0ubuntu2.1 [110kB]
Fetched 10.2MB in 33s (301kB/s)
SELECT finger FROM hand WHERE id=3;
Probaj instalirati paket "openvpn", tam recimo mi je zajamral.
denial ::
Nope...
krneki@ubuntu:~$ sudo apt-get install openvpn
[sudo] password for krneki:
The following extra packages will be installed:
liblzo2-2 libpkcs11-helper1 openssl-blacklist openvpn-blacklist
Suggested packages:
resolvconf
The following NEW packages will be installed:
liblzo2-2 libpkcs11-helper1 openssl-blacklist openvpn openvpn-blacklist
0 upgraded, 5 newly installed, 0 to remove and 0 not upgraded.
Need to get 7919kB of archives.
After this operation, 16.3MB of additional disk space will be used.
Get:1 http://si.archive.ubuntu.com jaunty/main openssl-blacklist 0.4.2ubuntu1 [6338kB]
Get:2 http://si.archive.ubuntu.com jaunty/main liblzo2-2 2.03-1 [64.5kB]
Get:3 http://si.archive.ubuntu.com jaunty/main libpkcs11-helper1 1.05-1 [41.8kB]
Get:4 http://si.archive.ubuntu.com jaunty/main openvpn-blacklist 0.3 [1068kB]
Get:5 http://si.archive.ubuntu.com jaunty/main openvpn 2.1~rc11-1ubuntu3 [407kB]
Fetched 7919kB in 4s (1800kB/s)
Suggested packages:
resolvconf
Hmm, gre za čist novo instalacijo. Mogoče... eh kaj jaz vem.
Mogoče so vmes kaj spremenili na serverju (si.archive se resolva v več različnih IP naslovov, mogoče so le eni taki?
| » | inštalacija starejše verzije vlc na linux mintOddelek: Pomoč in nasveti | 1707 (1491) | hogorq |
| » | Debian in nvidiaOddelek: Operacijski sistemi | 3100 (2825) | Icematxyz |
| » | Ubuntu zrcalni strežniki po novem tudi v SlovenijiOddelek: Novice / Operacijski sistemi | 5509 (4055) | kitaj |
| » | Ubuntu compizOddelek: Operacijski sistemi | 2318 (1995) | Loaded |
| » | Ubuntu 5.04 (strani: 1 2 )Oddelek: Novice / Operacijski sistemi | 11151 (9486) | Tarzan |
