Ubuntu - problem s paketom
Grizzly ::
Poskušam namestiti en program (sudo apt-get install), vendar mi izpiše tole:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
kolourpaint4 : Depends: kde-runtime but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Kako se rešim te napake, da bom program lahko namestil?
AC_DC ::
kde-runtime prej namesti.
Grizzly ::
sudo apt-get install kde-runtime
kde-runtime : Depends: kdelibs5-plugins (>= 4:4.13.0) but it is not going to be installed
Če napišem "sudo apt-get install kdelibs5-plugins", mi spet javi neko drugo napako. Tako se vrtim v začaranem krogu.
AC_DC ::
Grizzly ::
Tudi to javi podobno napako. Škoda živcev, pa tudi časa za ugibanje nimam. Bom verjetno jutri formatiral in si prihranil čas.
melvin ::
probaj še s tem:
sudo apt-get install -f
Grizzly ::
Tudi to ne dela. Pregledal sem že vsako stran, ki jo Google najde. Več nimam kaj iskat. Nekje je prišlo do napake in sedaj večino programov ne morem instalirat, tako da s takim sistemom nimam kaj delat.
inštalacija starejše verzije vlc na linux mint
101708 (1492) hogorq
Ubuntu vprašanja (strani: 1 2 3 4 … 19 20 21 22 )
Oddelek: Operacijski sistemi
1061249537 (118376) poweroff
[ARM] Problem pri prevajanju kode
Oddelek: Programiranje
81248 (1153) Hayabusa
Debian Gnu/Linux kot workstation (strani: 1 2 3 4 … 37 38 39 40 )
1960128028 (43702) RedDrake
[ubuntu] nepreverjeni paketi na si.archive.ubuntu.com ?
Oddelek: Programska oprema
71330 (1215) MrStein
