Moj score na 3Dmark2001 SE
iiyamaa ::
Imam plato ABIT NF7-S , corsiar ram , AMD 2100xp @ 2400 Mhz... Graficno imam od HIS-a novi model... dal se jo je nafrizirat na 378 CORE in 344 MEMORY tole je pa rezultat trenutni ..
Najnovejsi score do sedaj je 17777 3DMark's in ga imam na tej strani objavljenega:
http://service.futuremark.com/compare?2...
  • zaklenil: Predator ()
Matek ::
A ti ni kuglvinkl že v včerajšnji temi napisal, da je skupna tema o 3Dmark dosežkih že odprta?
rap3r ::
Al pa da tvoj score ni nč posebnga niti configuracija...
Za primerjavo to dam moj link kjer lahko vidš da te j zmojim 9500 non pro ki je nenavit zanekrat dokler nebo vedno hlajen premagam celo v car chase high details in tud moj CPU ma 50Mhz mn k tvoj kar ti pove da nimaš glih dobr zoptimizirano use...
tko ti dajem ker mi piše: This project can not be published
due to detected CPU speed variation.
Nevem pa kaj bi blo narobe test gre lepo skoz...
System Configuration
Operating System Microsoft Windows XP
DirectX Version 9.0
Mobo Manufacturer
Mobo Model nVidia-nForce
AGP Rates (Current/Available) 8x / 4x 8x
CPU Unknown 2368 MHz
FSB 225 MHz
Memory 256 MB
Graphics Chipset ATI RADEON 9700/9500 Series
Driver Name RADEON 9500
Driver Version 6.14.01.6307
Video Memory 128 MB
Program Version 3DMark2001 SE
Resolution 1024x768 32bit
Texture Format Compressed
FSAA Disabled
Z-Buffer Depth 24bit
Frame Buffer Double
Rendering Pipeline D3D Pure Hardware T&L
Test Results
3DMark Score 14238 3D marks
Game 1 Car Chase - Low Detail 196.4 FPS
Game 1 Car Chase - High Detail 86.2 FPS
Game 2 Dragothic - Low Detail 232.1 FPS
Game 2 Dragothic - High Detail 133.2 FPS
Game 3 Lobby - Low Detail 206.5 FPS
Game 3 Lobby - High Detail 98.8 FPS
Game 4 Nature 76.3 FPS
Fill Rate (Single-Texturing) N/A
Fill Rate (Multi-Texturing) N/A
High Polygon Count (1 light) N/A
High Polygon Count (8 lights) N/A
Environment Bump Mapping N/A
DOT3 Bump Mapping N/A
Vertex Shader N/A
Pixel Shader N/A
Advanced Pixel Shader N/A
Point Sprite N/A
Ne droga, ne trava me ne mika, le kakšna promilja alkohola se učasih po krvi mi potika:)
Predator ::
zaklepam tole podvojeno temo
3DMARK 2001SE build330 (strani: 1 2 3 4 … 22 23 24 25 )
Oddelek: Navijanje
122465579 (34311) LittleDevil
Lastniki Gericom Blockbusterja pomoč (strani: 1 2 )
615860 (4953) snow
GF FX 5700 Ultra in 3DMark 2001SE build 330
101282 (1210) ERGY
Uspelo mi je! Navijalske sanje (strani: 1 2 3 )
Oddelek: Navijanje
1368449 (5890) koyot
Uporabnikov test Detonatorjev
63118 (3118) tejo
