Forum » Pomoč in nasveti » Antivirostni programi
leonček ::
Pozdravljeni!
Imam eno majhno težavico z nakupom antivirosnega programi. Prosil bi če bi mi lahko povedali kateri antivirostni programi so najboljši?
Hvala za odgovor
Hvala za odgovor
- zaklenil: Mavrik ()
ST-777 ::
Imam dobre izkušnje z Bitdefender, priporočam nakup.
"Bitdefender Antivirus Plus is the acknowledged "Best Antivirus of 2014". With a non-intrusive and extremely fast scanning technology, it offers essential silent security against e-threats." http://www.bitdefender.com/solutions/an...
Test Bitdefender Antivirus Plus 2014: http://anti-virus-software-review.topte...
Če kupiš Bitdefender Antivirus Plus za 5 PC-jev in si s prijatelji razdeliš stroške, te bo ena licenca prišla 9 € na leto, kar se mi zdi ne zdi veliko.
Bitdefender Antivirus Plus (5PC): http://www.mimovrste.com/artikel/262008...
ST-777 ::
Ti sam si najboljši antivirus in če nisi ravno The_Bill, ga sploh ne potrebuješ.
"Hypothetically, that's possible but the computing experience would be very dull. In order to avoid being infected, you must NEVER:
1. Install anything to your computer
2. Plug in storage devices (CD/DVD/USB/Floppy) on your computer
3. Connect the computer to the Internet
If you did that, then you will never get infected. Removing today's viruses is shockingly complicated, even if performed by experts. Some damages are so horibble that there is no choice but to reinstall the system." http://answers.yahoo.com/question/index...
Chev ::
Yahoo Answers, srsly?
Ne vem, kako določenim uspe okužiti računalnik do te mere, da je potreben format. Ravno zadnjič sem dokazoval z malwarebytes programom, da je moj (zdaj sicer bivši) računalnik, čist kot suza. Pa je bil delovna mula, prižgan in online 24/7.
But hey, that's just me
Napajalc ::
Mene pa zanima če je kakšna razlika med antivirusom: Microsoft Security Essentials zastojnski, in pa McAfee, sprašujem ker imam možnost preko neke kode dobiti zastojn tale McAfee. Uporaba: povprečen desktop user.
Hvala
Hvala
- spremenilo: Napajalc ()
RejZoR ::
Ja. Predvsem v tem da je MSE počasno govno. Ampak je pa free, huray. Sifilis je tud free pa ga noben noče. Raje glej za čem drugim, ki je isto free. Recimo AVIRA, AVG, avast! so preverjeno dobri in isto brezplačni.
Napajalc ::
Sem potiho računal da bo plačljiva različica pač taka kot more bit, nč pol ga naj pa kar majo. Ty
| ! | Anti-virus programi (strani: 1 2 3 4 … 48 49 50 51 )Oddelek: Informacijska varnost | 745176 (6865) | fikus_ |
| » | Bitdefender in Klik NLBOddelek: Loža | 4120 (3182) | predi |
| » | Zaradi antivirusnega programa stalno zaseden CPU 99% (strani: 1 2 )Oddelek: Pomoč in nasveti | 16501 (15229) | solatko |
| ⊘ | Je mogoč izbris določenih postov - moderatorji?Oddelek: Slo-Tech | 2079 (1564) | kitara8 |
| » | VarnostOddelek: Informacijska varnost | 24995 (6696) | techfreak :) |
