kako odpreti XPS dokument
Ikspe ::
Po meilu sem dobil dokument z nekakšnim XPS formatom. Če ga direkt v mejlu odprem ga vidim in natisnem.
Če pa ga shranim na disk, ga ne morem odpreti. Je kaj narobe s fajlom ali bi rabil kak poseben program za odpiranje?
bluefish ::
Windows ima dodan XPS Viewer. Če ga nimaš, pojdi: Win + R > optionalfeatures > kljukica pri XPS Viewer.
Cold1 ::
Če poguglaš "how to open XPS document" dobiš tele rezultate:
What is the XPS Viewer? - Microsoft Windows Help
http://windows.microsoft.com/en-us/wind...
XPS file, XPS document open, view, convert - XPS Viewer
http://www.xpsviewer.com/xps-file.aspx
How to Open, View or Create XPS Documents in Windows XP and Windows 2003
http://www.mydigitallife.info/how-to-op...
Ikspe ::
navodila kako videt če imaš v windowsih XP nastavljen pregledovalnik xps nisem našel.
Mogoče bi šlo s tem spodaj ampak v angleških XP v nadzorni plošči ne ni najti PROGRAMI oz. PROGRAMS.
Kliknite gumb StartSlika gumba >>Start<<, kliknite Nadzorna plošča, kliknite PROGRAMI in nato kliknite Vklop ali izklop funkcij programa Windows. Zahtevana skrbniška dovoljenja Če računalnik od vas zahteva skrbniško geslo ali potrditev, vnesite geslo ali izvedite potrditev.
  • spremenil: Ikspe ()
Cold1 ::
Ahem, nisi pregledal povezav, ali ne znaš angleško?
In Windows XP and Windows 2003, to add in the capability to open to view and create XPS documents, you can either download Microsoft .NET Framework 3.0 or Microsoft XPS Essentials Pack. XPS document viewing and generation capabilities are included in Microsoft .NET Framework 3.0. With .NET Framework 3.0, the XPS files will open within Internet Explorer 6.0 or higher.
Meanwhile Microsoft XPS Essentials Pack contains the XML Paper Specification (XPS) Viewer to read and index XPS Documents, and the Microsoft XPS Document Writer to output files to the XPS Document format, plus providers to enable the iPreview and iFilter capabilities found in many Windows applications. Windows shell handlers are also included to enable thumbnail views and file properties for XPS Documents. When you select this Essentials Pack option, XPS documents will open in standalone viewer.
http://www.microsoft.com/en-us/download...
Zaklenjeni piskoti v Win10
Oddelek: Operacijski sistemi
191660 (1026) nsa_ag3nt
Laptop se instantno zbudi iz sleep/hibernate
172132 (1745) fujtajksel
Symatec in Adobe proti Microsoftu
Oddelek: Novice / Tožbe
424686 (3985) para!
Adobe in Microsoft ter PDF (strani: 1 2 3 )
10516411 (13284) Jst
Microsoft .NET Framework 2.0 je tu, XPS ob bok PDF v Office 12 (strani: 1 2 )
Oddelek: Novice / Pisarniški paketi
8213392 (11396) 64202
