Forum » Igre » The Witcher 3: Wild Hunt
Tezaab ::
"Where the cat and wolf play"? Naj uganem, the wolf je Geralt, the cat so pa witcherji iz mačje šole, ki so pošizili, ko jih vaščani niso hoteli plačati?
sisemen: "Inženirstvo je v nenehni tekmi z vesoljem. Trudi se izdelati
tehnologijo, ki je odporna na idiote, vesolje pa se trudi izdelati vedno
hujše idiote. In vesolje zmaguje."
Tr0n ::
http://forums.cdprojektred.com/threads/...
Dolgo so nucali.
A new, alternative (optional) movement response mode for Geralt.
A player stash for storing items, available in various locations throughout the game. Stash locations are marked on the player's map.
Crafting and alchemy components no longer add to the overall inventory weight.
Books are now placed in a dedicated tab in the Inventory and books that have already been read are properly grayed out.
Multiple sorting options are now available in the Inventory.
Alchemy formulas and crafting diagrams can be "pinned", meaning all components and ingredients required to make them will be conveniently marked in the Shop panel.
Dozens of fixes for quest related issues, both major and minor.
A few performance enhancements, including the optimization of FX, scenes and general gameplay.
Various improvements to horse behavior.
Dolgo so nucali.
- spremenilo: Tr0n ()
yayo ::
Nekje ta teden. (110 ur igre pa še nisem šel na Skellige. Drugače opažam, da če igro fiksiram na 30fps lahko imam vse na ultra + hairworks. Edino tako se znebim strutterja, je pa res da je bojevanje pri 30fps bolj bogo.
Bergyb ::
Kira grafična?
Men na r9 290 laufa na 45-60fps na Ultra s hairworks (v nastavitvah grafične nastavljen tessalation level na 16X).
Res pa mam nekaj nastavitev nižjih, ker nisem opazil razlike med medium in ultra.
Zoga ::
Ja lol. Rečeš, da laufaš na ultra, potem pa poveš, da pa nimaš vse na ultra, ker nisi opazil razlike :D
Bergyb ::
Detajle, teren, distanco, grass, hairworks, vodo imam na max,
sence se mi niso zdle nič boljše na max, kot na medium in pa št. ljudi ni razlike, če nastaviš nižje, ker jih ponavad tk ni na ekranu več kot 10-20 (NPCji brez funkcije).
Nekaj spremembb pa sem imel še v INI, da se npr. drevje ne upogiba toliko, sam vprašanje, če mi tega novi updati že niso pofural.
Ambient Occlusion pa uporabljam nek custom, ker mi HBAO+ ni všeč, pa še preveč grafične moči vzame...
GenZNPC ::
Witcher dela čist normalno na 2 let starem mid-range Keplerju in to samo 2GB Vrama (kombinacija high-ultra):
Pa še shadowplay se niti ne opazi, da je vklopljen.
skibidi
- spremenil: GenZNPC ()
overklocker ::
Vprašanje:
Ali bi delal Witcher 3 na tej konfiguraciji:
Proc FX6300
grafika je nova r7 360 2gb ram
rama 8 gb
Proc FX6300
rama 8 gb
Motherboard:Asus X570eStrix CPU:AMD 5950X ,GPU: RTX 5080,
128GB RamDDR4,Hladilnik NoctuaNU15s,Tipkovnica:Crosair K95 Miška:Logitech g903
2x Samsung m.2 980PRO 500 gb,2x Samsung 860evo 2tb,Monitor:Samsung Odyssey G9
GenZNPC ::
Bo bo, malo slabše ampak bo. ambient occlusion, hairworks, antialias, na off ostalo pa prilagodiš sence low ostalo probaš medium mogoče kak high.
skibidi
Zoga ::
lopov ::
Update sem sicer snel, a dokler XP & weight mod ne delata ne mislim nadgradit, sem čisto zadovoljen :)
Dami ::
Who the fuck cares about consoles.
Konzolaši si sploh že u štartu ne zaslužjo tega špila!
Že mogoče res, sam vseeno patchi bi moral igralnost izboljšat in ne poslabšat, ne glede al je za konzole al nas (PC master race).
GenZNPC ::
Baje so kr zjebali performance s tem patchom, sploh na konzolah.
kokr vem so samo znižal framerate na 30hz :D a ste se navadli na več ?
Die ohnehin nicht optimalen Bildwiederholraten verbessern sich also nicht. Microsofts Spielkonsole setzt nunmehr wie zuvor nur die PlayStation 4 die Bildwiederholrate in anspruchsvollen Szenen auf 20 herab („double buffering vsync“),
skibidi
Izi ::
Prišel je 15. zastonjski DLC
The double helix triple backspin stab to the face DLC
Geralt se je naučil nekaj novih "cool" potez s svojima mečema. Še več naokoli letečega črevesja, krvi in gorja
Forget Wolf School, here comes the Cool School, and Geralt just picked up a few new tricks at Kewl Morhen. Today's DLC introduces a pack of all-new combat finishers to truly take your sword skills to the next level of badass.
- spremenil: Izi ()
yayo ::
So pa mulci takoj opazili, kako se skin kateregakoli sovraga, v trenutku, ko ga prerežeš na pol v hipu spremeni v enega in istega s krvjo oblitega pleškota. In že kričijo: prevara! CDPR suks!
Izi ::
Novi DLC New Game Plus (NG+) ne bo prišel ta teden.
Verjetno se kdo sprašuje kaj hudiča sploh je ta NG+
Zadeva v igričarskem svetu ni nekaj novega. Pravzaprav ima precej iger to funkcijo. Detajlno še ni znano kako točno bo zadevo implementiral CDPR, amapk na splošno gre nekako takole:
Funkcija NG+ se vključi šele ko ti prvič igro končaš do konca. Potem pa lahko začneš novo igro Plus, ki gre sicer od začetka, ampak obdržiš vse levele in opremo iz prejšnjega igranja, poleg tega pa je na voljo nekaj novih funkcij, ki jih prej ni bilo.
Torej levelaš naprej od tistega levela do katerega si prilezel prej, kar tukaj ne bo problem, saj gredo leveli menda do 70, opremo obdržimo vso razen quest itemov, ki seveda izginejo. Ker je ves loot v Witcherju 3 dinamičen in se sproti prilagaja našemu levelu tudi z iskanjem nove opreme ne bo težav.
Ne ve pa se še kako bo s sovražniki. Ponavadi se sovražniki prilagodijo našemu levelu drugače je vse skupaj precej prelahko. V nekaterih igrah se odklenejo kakšne nove težavnostne stopnje. Včasih se pri NG+ pojavi tudi nekaj povsem novih in hudo močnih sovražnikov, ki so ekskluzivni za NG+. Pa kakšen nov hudo težaven quest deluje tudi samo v NG+.
Kako se bo zadeve lotil CDPR bomo verjetno zvedeli šele naslednji teden.
Izi ::
Glede par stvari okoli NG+ so se že zjasnili:
Minimum level za NG+ je 30. Kdor je končal igro z nižjim levelom bo v NG+ kar avtomatsko skočil na level 30. Tisti ki so dosegli višje levele pa bodo obdržali svoj level.
Prenesla se bo vsa naša oprema, denar, recepti in tudi vsi že naučeni napitki.
Ne bodo se prenesli vsi quest predmeti, knjige in pisma. Tudi vsi predmeti za uporabo se ne bodo prenesli, kot na primer ključi in podobno. Izgubili bomo seveda tudi vse trofeje. Pa vse Gwent karte tudi, kar je logično, ker je precej kart quest predmetov. Skratka Gwent bomo morali začeti iz nule.
Ko bomo začeli NG+ bomo lahko izbrali katerokoli težavnostno stopnjo.
Sovražniki pa bodo seveda občutno močnejši, kar pa ima verjetno veze samo za tiste ki bodo začeli kot level 30. Tisti ki so okoli level 40 ali celo že blizu level 50 bomo seveda že od začetka pravi Witcherji kot se za Geralta spodobi in ne neke patetične reve, ki so jih vrgli iz Witcherjeve šole še preden so prvič prijeli meč v roko
NG+ bo šele prava Witcher igra. Tista Geraltova šibkost na začetku igre nikakor ni sedla v 3. del zgodbe, ko smo že svetovno znani in praktično najboljši Witcher na svetu, premagal nas je pa vsak navaden vojaček z levo roko.
Tokrat bodo vojaki že na prvi mapi spoznali, da z Witcherjem ni dobro češen zobati
Sam kaj ti pomagajo leveli nad 30, ko pa razen malenkost boljše opreme nič več ne profitiraš? Meni bi bilo logično da se v NG+ razširi tudi skill drevo.
Izi ::
Prihaja že popravek 1.08, ki bo tu še preden pride zadnji DLC NG+, ker kot vidimo v zadnji vrstici popravkov ta popravek med drugim tudi pripravlja teren za vpeljavo NG+
Spisek popravkov v 1.08
Sam kaj ti pomagajo leveli nad 30, ko pa razen malenkost boljše opreme nič več ne profitiraš? Meni bi bilo logično da se v NG+ razširi tudi skill drevo.Skill drevo je tako široko, da ga tudi pri level 70 ne izpolniš v celoti
Mešaš količino skilov, ter skill drevo, ki gre zgolj do lvl30. Ko si enkrat lvl 30 lahko skile zgolj še menjaš, ne moreš več novih dodajat pod active. Zdaj recimo da z večjim levelom odkleneš še kak malenkost boljši skill, da ga zamenjaš z slabšim, ampak to je nekak to.
Izi ::
scipascapa ::
Skellige Most Wanted še vedno mi ne dela do konca...tam volk štekme.
Potem un WOLF PLAY DLC al kaj je že, sploh ni na tabli.
+ še nekaj malega ni ok
PS4.
PS4.
m0f0x ::
lopov ::
Heh, jaz sem šele na Skellige prispel, v Kaer Morhen še nimam vstopa ... Ostal sem tudi na 1.07, sem se odločil, da prvi krog naredim z XP in max weight modom ...
yayo ::
Nekaj se piše, da naj bi v naslednjem patchu omogočili obisk Kaer Morhena preden te glavna zgodba tja odpelje. Ker je Wolf Armor quest level 14, ko pa ti igra dovoli dostop do witcherske utrdbe si komot level 26. Baje naj ne bi imelo vpliva na zgodbo in balance igre. Drugače jaz ravno spoznavam Skellige, fak , muzika in vzdušje ko se potepaš po hribih v slabem vremenu sta enkratna. Pa tisti quest z nemim druidom je tak smeh.
In močno sumim, da sem za quest z brati Grossbart sam zaslužen, ker sem knjigo omenil na uradnem forumu v eni temi par let nazaj, ko avtorja v Evropi nihče ni poznal. Vsaj sanjam, da je tako...
- spremenil: yayo ()
| » | The Witcher 4 (nova trilogija) (strani: 1 2 3 4 5 6 7 )Oddelek: Igre | 72212 (261) | tikitoki |
| » | Dawnwalker: Origins (strani: 1 2 3 4 5 )Oddelek: Igre | 21725 (251) | Predsednik11 |
| ! | Brezplačne igre (giveaways) (strani: 1 2 3 4 … 23 24 25 26 )Oddelek: Igre | 375294 (6273) | acookook |
| » | The Witcher 2: Assassins Of Kings (strani: 1 2 3 4 5 6 7 8 9 )Oddelek: Igre | 113361 (82577) | yoco |
