Forum » Loža » Všeč sta mi dve punci...
Mesar ::
V bistvu so mi tri samo sta mi dve ful všeč pa ne vem kaj naj naredim. Obe dve zgledata kul, sta zabavni in vse... tako super, da se nemorem odločit s katero naj se zapletem? Z obema? Verjetno bi lahko lep čas obe na enkrat... samo potem je problem ko zveta druga za drugo. Po drugi strani pa lahko naprej z eno pa potem z drugo ko/če se s prvo ne obnese... samo potem pa je spet problem s katero naj prvo, ker ne rad delam razlike.
Skratka po kakšnem ključu se odločate v takšnih situacijah in kaj narediti... sam ne vidim pametne rešitve.
Your turn to burn!
- zaklenil: kuglvinkl ()
ZaphodBB ::
Če sta ti dve všeč, očitno ne gre za resno zadevo. Torej odkrito nastaviš z obema in vidiš če je kateri do avanture. Na tak način imaš lahko obe, eno ali nobeno. Vse drugo po mojem vodi v to, da ne boš imel nobene oz. da boš prizadel vsaj eno dekle, ki pričakuje vezo.
Mehmed ::
There was a man who had 3 girlfriends, but he did not know which one to marry. So he decided to give each 1 $5000 and see how each of them spent it.
The first 1 went out and got a total makeover with the money. She got new clothes, a new hairdo, manicure, pedicure, the works, and tells the man, "I spent the money so I could look pretty for you because I love you so much."
The 2nd one went out and bought new golf clubs, a CD player, a television, and a stereo and gave them to the man. She said, "I bought these gifts for you with the money because I love you so much." The 3rd one takes the $5000 and invests it in the stock market, doubles her investment, returns the $5000 to the man and reinvests the rest. She says, "I am investing the rest of the money for our future because I love you so much."
The man thought hard about how each of the women spent the money.
Finally, being a man he decided to marry the one with the biggest tits.
St235 ::
Kaj ko bi probal s tisto, pri kjer imaš dejansko kaj šans?
Mesar ::
Šanse mam pri vseh treh... ena bi resno, ostali dve pa sta tak... neki med tem, da ne veta kaj bi. Če bi naprej neresni, ker se nebi kregali pa to potem pa se vrnem k resni, sam če se razve bom prasec pa me resna nebo hotla več... verjetno.
Your turn to burn!
oemdzi ::
torej ne bo naredil nic ?
- spremenil: oemdzi ()
Mesar ::
Ne sodi po sebi.
Meni bi pasalo, da bi ble vse 3 zadovoljne pa še ostanemo kolegi če bo kak interes kdaj pa to ne... nikoli ne veš kako se obrnejo stvari v življenju.
Your turn to burn!
- spremenil: Mesar ()
oemdzi ::
Jaz imam tudi lahko v pravljicah hareme in odpiram teme na slotechu ce bi vseh 100 zapecal ...
Sem pa 99%, da je to troll tema, 1% je pa da si res tok glup
gendale ::
a se poznajo med sabo?
http://pastebin.com/QiWny5dV
ZaphodBB ::
Kristus, kaj vi mislite, da če vam nobena ne da. Da potem nobenemu drugemu ne da? Imam dva zelo dobra kolega, ki sta imela stalno vsak svoj krog "prijateljic". Tudi sam bi jih lahko imel a se mi to nikoli ni zdelo okusno. Zame je že eno žensko servisirat dovolj dela.
Če si šarmanten in so ti ženske všeč (strastno), ter hkrati iskren in diskreten, ženske to zavohajo in tudi rade izkoristijo.
Poglejte ta primer: Catharine MacKinnon @ Wikipedia
Največja feministka in manhaterka na svetu, je bila v razmerju z enim največjih kurbirjev v 'meriki. Hinavščina? Sagurno. Ampak take ženske so. Vsaka je rada dobro pokavsana.
Mesar> V bistvu so mi tri samo sta mi dve ful všeč pa ne vem kaj naj naredim.
Kar vsem trem razloži situacijo. Če si jim všeč, jih ne bo nič motilo.
Mesar ::
jype, bo problem če kateri potem več nebom všeč...
Kar se pa tiče spornih pogledov na te zadeve pa mislim, da ne smem bit tak egoist, da bi katero kr odrinil pa ji odrekel mojo družbo... tako da imam kr opravičljiv razlog. Ampak to ni debate, samo razložim, ker vidim, da bi se eni že radi vpičli v to... gre se zato, da ne rad delam razlike med ljudmi.
Your turn to burn!
oemdzi ::
Da si izposodim temo, ker imam tudi sam podoben problem.
Vsec sta mi 2 punci ena je ze porocena, druga pa slabega slovesa (lahka). Zdaj nevem kateri bi dal priloznost ? Angelini Jolie ali Megan Fox ?
ZaphodBB ::
Saj prav, vsem hočeš ustrežt. Ampak na skrivaj boš to težko dosegel. Ker vkolikor se ne strinjajo z takim odprtim štirikotnikom, bodo ko se bo razvedelo vse to (upravičeno) dojele kot zaštih v hrbet.
Zapomni si: Hell has no fury like a woman scorned.
BigWhale ::
amigo_no1 ::
Če sta ti dve (tri?) ful všeč ti v resnici nobena ni všeč.
Ko spoznaš pravo vse ostale izginejo.
oemdzi ::
Phantomeye ::
Všeč so ti tri in vsaki posvečaš 1/3 pozornosti, namesto da bi eni 3/3 pozornosti.
Nobeni ni všeč samo 1/3 pozornosti, zato se bo takšna nehala zanimati zate in ker so v tem primeru tri, boš izgubil vse tri. :D
Mr Hilter ::
Phantomeye je izjavil:
Cepec, 1/24 je preveč.
kixs ::
Eni pa imajo domisljijo
Tri so ti vsec in te tri bi tudi bile s tabo. Mat'r dobra statistika. Pa je to s prve roke ali tako malo po ovinkih ali celo iz lufta vzeto!?
Ne recem, da ni mozno, vendar je zelo malo verjetno. Predvsem to, da so tudi one enako zainteresirane kot ti.
Navadno je pa tako, da na koncu pri vseh izvisis... kar verjetno si ze, ker neodlocnih tipov prave zenske nimajo rade.
kixs> Navadno je pa tako, da na koncu pri vseh izvisis... kar verjetno si ze, ker neodlocnih tipov prave zenske nimajo rade.
Tudi napačne ženske imajo dele telesa, ki Mesarja zanimajo.
amigo_no1 ::
Glede na to, da propade okoli 50% vseh vez (in se ljudje temeljito odločajo ali gredo v vezo ali ne) lahko mečeš kovanec, šanse da vama uspe bodo podobne
BigWhale ::
Mr Hilter ::
Naslov teme še razumem (Všeč sta mi dve punci...), potem pa govori že o treh. A ima človek 3 roke? 2 roke + avtofelacija, 2 roke + svojo rit.... sem čisto zmeden???
ZaphodBB ::
Dosta sam dugo sarao svijetom
samocu lijecio kvantitetom
na putu sreo ljude, ranjene i lude
i vise put' opecene, i u strahu nedorecene
Zato ne jebem vise jeftini klise
da se samo o onoj pravoj pise
pa zar nijedna pjesma, nijedan stih
za onih milijun pogresnih
koje su bile tu kad nisam imao nju
Kad sam vikendom staj'o na rubu
i kad je nedjelja zjapila ko crna rupa
meni su neprave pruzile ruku
i poljupcima odvukle do jutra
Njsu bile glupe, vjeruj mi
svaka je znala
kad nema velike ljubavi
dovoljna je i mala
masterpsi ::
aaahahahhahhahhahhahhaha umrl od smeha :))))))))))))))))))))))))))))
tolk razmišljanja, ampak joški imajo nadzor nad možgani
JesusChrist ::
kaj še niste opazili da mesar samo trolla vi pa dodajate drva na ogenj?
mesar itak ma punco, ampak ona še tega ne ve
remember, the clock is ticking. run like no tomorrow.
gendale ::
Dve sta sestri... tretje pa ne poznata.
ena od sester + tretja
oemdzi ::
JesusChrist je izjavil:
Jah sj ves kako je to.. nekako v stilu: Kaj naj kupim ? Ferari ali porsche ?
gendale ::
bmw, žanu na čast
Haahahahaahahah CAR!
oemdzi ::
Phantomeye ::
3/3 časa, ki si ga ženska zasluži in ne 3/3 vsega časa, ki ga imaš.
Cepec :P
Mr Hilter ::
Po tvoje si vsaka zasluži 50 ur na dan, to je 3/3, kar je še zmeraj slabše kot 3/3 prostega časa.
Friendone much? Pa zakaj omenjaš samo ženske, zapostavljaš geye homofob jedni!
- predlagal izbris: VelikiTun ()
Half-Saint ::
Men je všeč cel kup žensk sam kaj ko sm že skor poročen :)
Moj blog: http://onlyageek.blogspot.com
Phantomeye ::
balocom ::
Vrži kovanec, določi si s katero boš glede na kaj pade in če ne drugače boš vedel s katero bi hotel biti ko boš začel upat da pade taprava stran.
V svetu brez googla bi bil najbolj uporabljen ukaz v bash-u ukaz man
Mesar ::
Tudi če zberem tisto, ki nima sestre + eno izmed sester ne vem če bo druga sestra vesela, da jo zanemarjam. V bistvu se že zdaj sprašujem kaj si mislita sestrici, ker nekega opaznega pumpanja ena proti drugi še ni...
Sicer pa se nebom ženo ... še, pa če dve na enkrat mam več kot 50% možnosti za srečno življenje te? Sicer ne vem od kje izračuni...
kr1ženska, za razliko od nekaterih se mi porivanje in lizanje auspuha nikoli ni zdelo zanimivo.
Your turn to burn!
Mesar> V bistvu se že zdaj sprašujem kaj si mislita sestrici
Čemu se pa to sprašuješ?
A ne bi bilo pametneje njiju vprašat? Po moje sta bolj primerni podajati kvalificirane odgovore na taka vprašanja.
| » | Citati, ki vam kaj pomenijo (strani: 1 2 3 4 5 )Oddelek: Sedem umetnosti | 59820 (10390) | yansek |
| » | Dr. Phil: My African-American Daughter Believes She is Caucasian (strani: 1 2 )Oddelek: Loža | 24993 (23253) | KAVINSKY |
| » | nigerijci še vedno harajo po bolhiOddelek: Loža | 10104 (9029) | sarma832 |
| ⊘ | Kaj obleči za zmenek (strani: 1 2 3 4 5 6 )Oddelek: Loža | 63448 (56364) | jype |
| » | Zenske, rasizem in izbira partnerja (strani: 1 2 3 4 … 13 14 15 16 )Oddelek: Loža | 121029 (107945) | kr1ženska |
