DVDFab-DVD Ripper
DVDFab-DVD Ripper
krebs11 ::
Za ropanje iz DVD v mkv uporabljam DVDFab, pa mi včasih ne zripa celega posnetka v mkv, npr.: posnetek na dvd-ju je dolg 53:07min, men pa zripa samo 52:59min, tako da ni cel posnetek, fali nekaj sekund, včasih mi pa lepo naredi vse, če sem dal pa isti posnetek v avi, je pa naredilo vseh 53:07 min, v obeh primerih je izbran kodek avc in audio copy
Še info od tega posnetka, ki ni celoten:
General
Complete name : Rivers of the World 03 Niger.mkv
Format : Matroska
Format version : Version 2
File size : 515 MiB
Duration : 53mn 7s
Overall bit rate : 1 355 Kbps
Movie name : Rivers of the World 03 Niger
Encoded date : UTC 2012-01-07 14:29:25
Writing application : DVDFab
Writing library : libebml v0.7.8 + libmatroska v0.8.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 53mn 7s
Bit rate : 1 072 Kbps
Width : 720 pixels
Height : 466 pixels
Display aspect ratio : 3:2
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.128
Stream size : 407 MiB (79%)
Writing library : x264 core
Default : Yes
Forced : No
Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 53mn 7s
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 97.3 MiB (19%)
Default : Yes
Forced : No
Plazma LG 50 pk350 (strani: 1 2 3 4 5 6 7 )
Oddelek: Zvok in slika
30074425 (9939) stratosD
YouTube nativni video format
152374 (2003) Ijus
Občasno štekanje pri predvajanju preko HDMI
474220 (3176) sejmon
HD ali FULL HD KAMERA
286392 (5416) JOKER
Kupil bi Satelitsko. (strani: 1 2 )
5018972 (17432) mumbo
