Forum » Zvok in slika » DVDFab-DVD Ripper
DVDFab-DVD Ripper
krebs11 ::
Za ropanje iz DVD v mkv uporabljam DVDFab, pa mi včasih ne zripa celega posnetka v mkv, npr.: posnetek na dvd-ju je dolg 53:07min, men pa zripa samo 52:59min, tako da ni cel posnetek, fali nekaj sekund, včasih mi pa lepo naredi vse, če sem dal pa isti posnetek v avi, je pa naredilo vseh 53:07 min, v obeh primerih je izbran kodek avc in audio copy
Še info od tega posnetka, ki ni celoten:
General
Complete name : Rivers of the World 03 Niger.mkv
Format : Matroska
Format version : Version 2
File size : 515 MiB
Duration : 53mn 7s
Overall bit rate : 1 355 Kbps
Movie name : Rivers of the World 03 Niger
Encoded date : UTC 2012-01-07 14:29:25
Writing application : DVDFab
Writing library : libebml v0.7.8 + libmatroska v0.8.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 53mn 7s
Bit rate : 1 072 Kbps
Width : 720 pixels
Height : 466 pixels
Display aspect ratio : 3:2
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.128
Stream size : 407 MiB (79%)
Writing library : x264 core
Default : Yes
Forced : No
Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 53mn 7s
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 97.3 MiB (19%)
Default : Yes
Forced : No
General
Format : Matroska
File size : 515 MiB
Duration : 53mn 7s
Video
Format : AVC
Duration : 53mn 7s
Width : 720 pixels
Height : 466 pixels
Color space : YUV
Bit depth : 8 bits
Default : Yes
Forced : No
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 53mn 7s
Bit rate : 256 Kbps
Bit depth : 16 bits
Default : Yes
Forced : No
| » | Plazma LG 50 pk350 (strani: 1 2 3 4 5 6 7 )Oddelek: Zvok in slika | 74425 (9939) | stratosD |
| » | YouTube nativni video formatOddelek: Pomoč in nasveti | 2374 (2003) | Ijus |
| » | Občasno štekanje pri predvajanju preko HDMIOddelek: Zvok in slika | 4219 (3175) | sejmon |
| » | HD ali FULL HD KAMERAOddelek: Zvok in slika | 6392 (5416) | JOKER |
| » | Kupil bi Satelitsko. (strani: 1 2 )Oddelek: Zvok in slika | 18972 (17432) | mumbo |
