Desktop procesor z najvišjo "tovarniško" frekvenco vseh časov
Kron ::
Naslov pove vse.
Turbo in OC se ne upošteva. Prav tako "inženirske" verzije ne.
Do sedaj našel:
- Pentium 4 HT z 3,8GHz
Je mogoče še kakšen (bil) čez 4GHz?
=**=C64=**=
jest10 ::
Zakaj pa ne turbo? Saj to je tovarniško.
misek ::
http://www.ehow.com/facts_6730551_frequ...
What Is the Frequency of the Fastest CPU for a Desktop Computer?
By David Perez, eHow Contributor
updated: July 14, 2010
According to independent reviewer ZDNet, Intel’s Core i7-980X, at a maximum clock speed of 3.6 GHz, is the “fastest desktop processor ever” as of summer 2010.
Je oni P4 sploh ugledal masovno proizvodnjo?
Pyr0Beast ::
To bo karkoli iz Netburst ali Prescott linije.
P4 EE.
pershi ::
Glede na Wiki (link) ima Kron prav:
The fastest, the 570J and 571, is clocked at 3.8 GHz. Plans to mass-produce a 4 GHz Pentium 4 were cancelled by Intel in favor of dual core processors, although some European retailers claimed to be selling a Pentium 4 580, clocked at 4 GHz.
  • spremenil: pershi ()
Kron ::
@jest10
S tem sem hotel poudarit, da naj deluje "po možnosti stalno" na določeni frekvenci.
@misek
Mislim, da.
Prescott
=**=C64=**=
jest10 ::
Kron je izjavil:
@jest10
Glede na to, da vsi sedanji procesorji v neobremenjenem stanju nižajo frekvenco, boš malo težko definiral, kaj je stalno:P
Kron ::
Se da izklopit nižanje.
Nevem pa če lahko prisiliš cpu v turbo tudi v idle?
=**=C64=**=
mr1two ::
se da, če ga overclockaš ;((
Kron ::
Brez OC.
Intel turbo boost:
Intel Turbo Boost is a technology implemented by Intel in certain versions of their Nehalem-based CPUs, including Core i5 and Core i7. Turbo Boost allows dynamically increasing CPU clock-speed on demand. Turbo Boost activates when the operating system requests the highest performance state of the processor. Processor performance states are handled via ACPI which is supported by all major operating systems so no additional software or drivers are required to support this new technology. Most refer to this concept as "dynamic overclocking".
=**=C64=**=
  • spremenil: Kron ()
axee ::
Če se ne motm Turbo Boost overclocka samo ko niso v rabi vsa jedra, ampak ko se gre za eno-nitne aplikacije.
Kaj če bi to definirali kot procesor, ki deluje na največji tovarniški frekvenci pri full loadu vseh jeder oz niti.
jRk0 ::
in kaj zdaj? ugotovili ste daj e to p4, konec debate?
Kron ::
UPDATE:
Nov na "prestolu":
Iz serie Xeon 5600 z 4.4 GHz
Model: X5698
OEM: AT80614007314AA
QDF: Q5C1
Frekvenca: 4.4 GHz
L3: 12MB
=**=C64=**=
socket 1366:)):D
Xeon E3 vs i7-K (strani: 1 2 3 4 5 6 7 8 )
36771569 (38505) mahone
Intelovi mobilni procesorji 9. generacije Core so tu
Oddelek: Novice / Procesorji
3616549 (14130) MrStein
INTEL - Turbo Boost
5893 (772) Bizkit45
I7 920 + X58 UD5
Oddelek: Navijanje
222393 (1646) ModriN96
Pomoč pri navijanju i7 procesorja (strani: 1 2 )
Oddelek: Navijanje
577174 (5741) mysly
