eGreat EG-S2 Sigma Designs 8643
2
vrossi46 ::
Novi predvajalnik z Sigma čipom.Brez ventilatorja in možnost vgradnjo 3,5" HDD-ja.
Slike:
  • spremenil: vrossi46 ()
Cena?
vrossi46 ::
Baje da okoli 200EUR oziroma pod to ceno.Bomo videli kmalu :))
floyd1 ::
Ali na teh novih "Sigminih" playerjih še vedno letijo vsi stari dodatki - programi, ki so bili narejeni za npr. Popcorn Hour A110?
NazgulRR ::
Kul, da je sigmin (se mi zdi da malenkost ostrejša slika), vendar je cena malo previsoka? Xtreamer Pro bo imel možnost vgradnje 2 diskov in bo 150EUR. Poleg tega bo 100% imel še lepši vmesnik..
Maxl ::
Samo moraš pa vedeti, da ima Xtreamer Pro Realtek čip, ki je slabši od tega Sigminega. Poleg tega, bo imel ta predvajalnik še Gbit mrežno kartico :). Mi je kar malo žal, da sem nabavil EG-R1 hehe :P.
NazgulRR ::
Aha, če je Sigmin čip dražji, potem razumljivo. Pa GBit mrežna..se pa potem splača! :)
vrossi46 ::
Specifikacije:
Features:
 Solid Aluminum alloy case, good heat sink; at same time, mobile rack design give user easily/friendly/quickly installation.
 Besides of internal SATA port, there is another external SATA port for external SATA HDD or Blu-ray DVD ROM without extra power.
 Support original BD disk (need extra SATA BD-ROM which isn’t standard accessory)
 Can be refurbish to other FW depend on your choice.
 External remote control.
Chipset:
Sigmadesign8643,667MHz CPU
Memory:
 512MB DDR2, 256MB NAND FLASH.
Output connectors:
Video Output connectors:
 HDMI 1.3
 Component (Y/Pb/Pr)
 Composite
Audio Output connectors:
 Stereo
 SPDIF Digital audio output
 Coaxial digital audio output
Other interface:
 2 x USB hosts at the side.
 2 x USB hosts at the back
 1 x USB slave at the back
 1 x SATA port at the back which can install DVD ROM or HDD without extra power.
Network
 Ethernet 10/100/1000M
Power on/off control by RC
 Add one MCU which can support power on/off by RC.
Spec:
Video container
* MPEG1/2/4 Elementary (M1V, M2V, M4V)
* MPEG1/2 PS (M2P, MPG)
* MPEG2 Transport Stream (TS, TP, TRP, M2T, M2TS, MTS)
* VOB
* AVI, ASF, WMV
* Matroska (MKV)
* MOV (H.264), MP4, RMP4
Video decoder
* XVID SD/HD
* MPEG-1
* MPEG-2 -MP@HL
* MPEG-4.2 - ASP@L5, 720p, 1-point GMC
* WMV9 -MP@HL
* H.264 -BP@L3 ,MP@L4.0 ,HP@L4.0 ,HP@L4.1
* VC-1 -MP@HL ,AP@L3
Audio container
* AAC, M4A
* MPEG audio (MP1, MP2, MP3, MPA)
* WAV
* WMA
* FLAC
* OGG
Audio decoder
* WMA, WMA Pro
* AAC
* MP1, MP2, MP3
* LPCM
* FLAC
* Vorbis
Picture format JPEG, BMP, PNG, GIF
Subtitle format SRT, SMI, SUB, SSA
HDD partition FAT32, NTFS,EXT3
Size 205.4x198x67mm
Package:
Remote control 1pcs
HDMI cable 1pcs
USB2.0 cable 1pcs
12V/3A power adapter 1pcs
AC cable 1pcs
CD-R 1pcs
Simple install guide 1pcs
Screw bag 1pcs
gregor ::
tale s2 pa res izgleda zelo zanimivo, morda bo pch a200 killer :)
je pa res, da ni na nmt platformi kar pomeni da aplikacije iz www.networkedmediatank.com ne bodo delovale
NazgulRR ::
vrossi46 je izjavil:
Specifikacije:
Zakaj tega ni na sliki in je eSATA?
vrossi46 ::
Egreat,a mi lahko poveš če je ta predvajalnik NMT ali je NMP?
Hvala
vrossi46 ::
Cena tega predvajalnika,če ne bojo naši preveč požrešni pri nabijanju raznih stroškov, bo relativno nizka glede na ostale z istim čipom.
Nabavna cena je zelo ugodna!
gregor ::
to ni nmt
na nmt imaš pch a200 in c200
Maxl ::
Vrossi46, upajmo da res! Sem kar precej zadovoljen s svojim R1, vendar pa bi rad imel še nekaj "bonbončkov", ki jih tale S2 prinaša, zato ga bom najbrž tudi kupil...
A nima S2 enak čip kot C200, ki je NMT? Kolikor je meni znano je S2 tudi NMT, ali pač?
In kaj so tisti bonbončki, ki jih dobiš? Sem šel enkrat gledat aplikacije, pa se mi je zdela bolj žalost - našel nisem niti ene, ki bi jo hotel imeti.
gregor ::
nmt = www.networkedmediatank.com
gre torej za platformo podjetja http://www.syabas.com/
na kateri so tudi hdx 1000, starjši egreati, ...vsi z starejšimi procesorji
z novim procesorjem je a200 in c200, meni ni znano da bi še katero drugo podjetje naredilo nmt predvajalnik z novim čipom
vrossi46 ::
Fajn je to, da lahko daš FW od recimo C-200.
Je open source ta EG-S2
Zurbum ::
iz www.predvajalniki.si:
Dnevno prejmemo kar nekaj emailov, v katerih nas sprašujete, kdaj bo predvajalnik EG-S2 možno kupiti in kakšna bo cena zanj. Žal smo izvedeli slabo novico in sicer, da se bo predvajalnik uradno začel prodajati šele junija! Prav tako pa tudi cena zaenkrat še ni znana!
Hvala za razumevanje!
vrossi46 ::
Na tem linku je primerjava med PopCornom in Egreat S-2
http://s645.photobucket.com/albums/uu17...
Urajmal ::
Nekateri so uspeli poganjati Android
vrossi46 ::
Juhuuhu,moj S-2 je že na poti k meni.
Komaj čakam da ga stestiram. Žena mi rekla,da sem ko otroci, saj veste ko dobi liziko ali čokoladico in je veselje nepopisno. Tak sem jaz.
Gatsu ::
Kakšna je bla cena in kje si naroču?
Zurbum ::
Super novica, saj tudi sam komaj čakam, da naročim to zadevico.
vrossi46 ::
Pri nas še ni dobavljiva,tako da sem jo naročil direkt iz HongKonga. Nabavna cena je pod 250$,pri nas pa se ve da se bo gibala okrog 250 - 300€
LuGi ::
Urajmal je izjavil:
To je samo njihov loading screen..daleč od tega da bi poganjal Andorid (Zakaj bi ga??) :D
  • spremenil: LuGi ()
Zurbum ::
Cena pa je kar precej višja od tega, kar se je govorilo.
Bom počakal, če je res tako super, se splača še kak novčič dati zraven, drugače bom nabavu EG-R1B.
Z1g1smund ::
Ima ta zadeva Syabas-ov firmware ali so naredili svojega?
vrossi46 ::
Glede FW, vem da je narejeno tako da lahko daš kerega hočeš,tudi od PopCorn c-200,eni dajajo gor od Allure M3. Sem ga že dobil v roke v službo in ga stestiram danes ko pridem domov.Vam sporočim!
vrossi46 ::
Prvi vtisi so super,vse dela enkratno,pa še brez nadležnega ventilatorja. Podpira preverjeno,ampak samo Dmix,
ker nimam pravega reciverja.
DTS Dmix TrueHD Dmix DTS-HD MA Dmix
DTS Pass TrueHD Pass DTS-HD MA Pass
in še vse tiste Dolby HD-je in kaj jaz vem kaj še vse.
hamurabi ::
A tale škatlica ima torrent odjemalca? Kakšna pa je cena?
Zurbum ::
@hamurabi:
Cena je napisana 6 postov višje (250$). Pri nas zaenkrat še ni dobavljiv.
@vrossi46:
se pravi, podpira vse kar ima EG-R1B + ostalo?
vrossi46 ::
@hamurabi:
ima torrent odjemalec,koliko bo cena pri nas pa ne vem :8)
@Zurbum:
ja načeloma istko kot R1B,samo dosti hitreje dela ,pa podpira tiste DD tru HD,pa DTS HD,ki jih R1B ne.Pa še lepši grafični vmesnik ima.
Če kdo kupi PlayON!HD naj me kontaktira.
Z1g1smund ::
Kakšen je pa vmesnik? Je to NMT ali ni?
vrossi46 ::
Ja je NMT,ker ima možnost IPTV,pa coverje ,pa še par bonbončkov
nitro2 ::
dvb-c pa dvb-t bi mogu met pa bi bila zadeva popolna
kmetek ::
wow zdaj te pa še carina upili pa bo :))
NazgulRR ::
daj kake screenshote od vmesnika:)
a se da premikat videosliko gor/dol/levo/desno?
vrossi46 ::
Kmetek,carina me ne bo prav nič upalila,ker imam zadevco že doma.
NazgulRR,bom dal ko bom imel malo več časa.
kmetek ::
no potem pa super zegnar pač.
LuGi ::
Če pride preko TNT,UPS pride carina za tabo.. Če ne pa lucky bastard ;)
gregor ::
morda se motim ampak ta naprava ni nmt naprava, torej ne spada v isto skupino kot sta pch a200 in c200...
torej tudi delovanje programov iz www.networkedmediatank.com je vprašljivo...
LuGi ::
Če nalozis FW od C200 dobis NMT napravo..
vrossi46 ::
Prišla je potom DHL in ne bom dobil dodatne carine. Glede NMT pa bom še kaj probal.
Z1g1smund ::
A za to da naložiš drug FW je treba kej hekat in po netu iskat al je to čist u izi inštalacija?
vrossi46 ::
Je čisto izi inštalacija,jaz imam FW od Allure M-3
vrossi46 ::
Evo par slikic.
OldSkul ::
ja, DHL včasih udari s carino, včasih pa ne. Sem enkrat 2x naročil isti sat sprejemnik. Enkrat so mi carinili, enkrat pa ne. DHL seveda :)
eGreat ::
Pozdravljeni!
Pričakujem, da bodo vsi (tudi EG-S2) dobavljivi čez dober mesec. Razlog je, da EG-S2 še ni uradno izdan, ker še nimajo svojega lastnega FW-ja in se zato vleče, dokler ga ne bodo naredili. Cena bo zaradi padca evra v primerjavi z dolarjem in zaradi vseh dodatnih stroškov (carina, davek, poštnina) okoli 250 EUR oziroma v najslabšem primeru nekaj pod 300 EUR. Se bom potrudil, da bom izsilil čim nižjo ceno...
Pa drugače to je NMT predvajalnik in lahko povem, da je res bomba! ;)
@vrossi46: čudno, da ti ni bilo treba plačati carine in davka... si imel res srečo... Jaz je do sedaj žal še nisem imel takšne sreče in so mi vedno vse zaračunali :/
  • spremenil: eGreat ()
vrossi46 ::
Še dve slikici:
Z1g1smund ::
Zgleda hudo, a to ma kakšen vgrajen Jukebox in pobera informacije iz neta al je to samo slika, ki jo imaš v folderju zraven filma?
2
h.264/DVD/DivX player (strani: 1 2 3 4 … 44 45 46 47 )
Oddelek: Zvok in slika
2330274553 (88645) dope1337
Wireless nizka hitrost
Oddelek: Omrežja in internet
101283 (1072) JanezH
Še en nov HD predvajalnik - EGreat EG-R1 (strani: 1 2 3 4 5 6 7 8 )
36051044 (29650) xandros
Prihaja nov NMT player - Popcorn Hour A200 (strani: 1 2 3 )
10957904 (50288) vrossi46
HDX lansiral novi - HDX BD-1
62323 (1816) tisot
