Palladium!?!
Palladium!?!
smash ::
Q: What's with this Palladium stuff I keep hearing about?
A: One of the most exciting aspects of Longhorn is its integration with Palladium, Microsoft's technology for realizing the Trustworthy Computing vision. Palladium is basically a secure run-time environment for Windows and other operating systems that allows a coming generation of software applications and services to protect the end user from privacy invasion, outside hacking, spam, and other electronic attacks. Palladium requires special hardware security chips and microprocessors (which will be made by Intel and AMD) and doesn't interfere with the normal operation of the PC. That is, Palladium-based PCs will still operate normally, working with legacy operating systems and applications. But specially-made Palladium applications and services will offer a range of features of functionality not found in the non-Palladium world, and if the initiative is successful, we'll one day be running only Palladium-based software.
If you're familiar with the .NET model, you might be aware of the notion of "managed" and "non-managed" (or legacy) code. Palladium will institute a similar model for PC software, where a trusted execution mode is used for Palladium applications and services and the old, "untrusted" mode is used for legacy code.
Microsoft designed Palladium around the following ideals:
Palladium will tell you who you're dealing with online, and what they're doing. It will uniquely identify you to your PC and can limit what arrives (and runs on) that computer. Information that comes in from the Internet will be verified before you can access it.
Palladium protects information using encryption to seal data so that "snoops and thieves are thwarted." The system can maintain document integrity so that documents can't be altered without your knowledge.
Palladium stops viruses and worms. The system won't run unauthorized programs, preventing viruses from trashing your system.
Palladium stops spam. Spam will be stopped before it even hits your email inbox. Unsolicited mail that you might actually want to receive will be allowed through if it has credentials that meet your user-defined standards.
Palladium safeguards privacy. In addition to the system's ability to seal data on your PC, Palladium can also seal data sent across the Internet using software agents that ensure the data reaches only the proper people. Newsweek reports that the agent has been nicknamed "My Man," a goof on ".NET My Services," "My Documents," and other similar names at Microsoft.
Palladium controls information after it's sent from your PC. Using Digital Rights Management (DRM) technology, Palladium can be used to securely distribute music, movies, and other intellectual property securely over the Internet. Movie studios and the recording industry could use this technology to let their customers exercise their fair use rights to copy audio CDs and movies, for example. "It's a funny thing," says Bill Gates. "We came at this thinking about music, but then we realized that e-mail and documents were far more interesting domains." Gates says that Palladium could ensure that email designated as private could not be forwarded or copied to other people, for example. Or, the Newsweek reports reads, "you could create Word documents that could be read only in the next week. In all cases, it would be the user, not Microsoft, who sets these policies."
You can find out more about Palladium in my WinInfo article, Microsoft's Secret Plan to Secure the PC, which was written when this initiative was first revealed. But I will add this now: There is a ton of misinformation about Palladium out there on the Net ("It will require proprietary Microsoft changes to TCP/IP," "It won't run on Linux," and other similar claptrap), but most of that is completely untrue. People fear what they don't understand, but Palladium is about securing the PC, plain and simple.
mene ta zadeva malce skrbi...pa vas?
andrej ::
pocakajmo da vidimo kaj bo v resnici prislo ven, potem pa vzganjajmo paranojo:D
Loki ::
A ma NSA kej prste vmes; kot npr. pri SSL 128bit?
andrej ::
kaksne prste pa ima pri SSL?
Loki ::
ce gre verjeti enemu slovenskemu racunalnicarju (studio city; tema palladium, kaka 2-3 tedne nazaj), naj bi bilo 40 bitov v SSL 128 spremenljivih, ostali ( alidel ostalih) pa naj bi bili kao ena enkriptana koda NSA.
omenjal je, da ce ne verjames, si poglej RFC; kaj vec na to temo se pa ne spomnim vec na zalost;
s tem, da je velika moznost, da bi se lahko nasel kdo, ki bi to tehnologijo izkoriscal - saj vemo...podatki so denar in ce te podatke naokrog posilja sistem, katerega pomanjkljivosti/ skrite "feature" poznamo, kdo nam lahko se brani, da ne prisluskujemo - v interesu kake drzavne varnosti.
  • spremenil: Loki ()
smash ::
mene bolj zanima kdo bo potem se kuppoval racunalnike, saj komaj zberemo za racunalnik, ki stane 250 jurjov....potem bi pa moral odsteti samo se 100 jurjov za windowse pa office da bi se lahko igral z wordom ter excelom....sam zgleda da tko bo
Matek ::
Jah po moje bo treba lepo preuredit cene, npr tiste cene, ki so postavljene v USA, so za nhij čisto ok, tak kot da bi bli pri nas windowsi 10-20k, ker majo pač tolko višje standarde in plače, pri nas pa je cena ogromna. Fajn bi blo, da bi zračunali ceno glede na bruto domačega proizvoga ali glede na povprečno plačo, ali glede na kaj drugega, kar vsaj približno ponazarja standarde v džavi, da bi potem lahko bili windowsi(in tudi ves drug software) ponujeni po sprejemljivi ceni. Seveda bi pa to povzročilo nove probleme, npr. švercanje na velko iz držav z nižjimi cenami.
Jah, nič ni popolno.
Edin software, ki ga kupujemo po primerljivi ceni glede na ameriko, je linux:D
Sicer pa, glede Palladiuma, tako kot je reko master andrej, počakajte da pride kaj direktno iz microsofta, ker tak fancy page z fake informacijami lahko naredi vsak.
  • spremenil: Matek ()
Ziga Dolhar ::
Ali pa švercanje paketov IZ Slovenije, saj bi bili tukaj cenejši :)
perci ::
al pa če bi blo kej tazga nezakonito, Ziggga - ti to najbrž že veš (dumpinške cene in to) :D
andrej ::
ok, nebi rad obsojal, ampak vecina, ki gostov v sc se mi zdi da se delajo full pametne in oh in sploh.
kot drugi ne vem kateri RFC je mislo, ker SSL ni definiran v nobenem RFC-ju. pa tudi RFC-ja ni omenjal
Heh, oni je bil razvpiti Miso Alkalaj ;) 34:30
oni tudi ne loci med registracijo in aktivacijo ;) ccc
reko je"
"ni racunalniskih virusov. so samo microsoftovi".... kaka dobra :) "Ms bi lahko to odpravo pa ne." se lepsa ;) zakaj jih ne? "ah, tukaj so taksne ideje, da jih namensko ne, jaz pa mislim, da gre za en operacijski sistem in programsko opremo, ki je tko kot zobna pasta. Mora met zelo barvito skatlico in vse ostalo in pravzaprav v vsebino se ne smes prevec vtaknit. In ce pomislimo da oni vsako leto pridejo ven z novo verzijo, kar ima vedno vec okraskov tezko poskrbit, da je zadeva povsem konsistenta."
zanimivo kaj je reko o NSA. Samo ce to govoris na Tv moras tudi nekaj met s cimer lahko podkrepis te izjave...
en je poklicat in povedal za dve zadeve.
"A se zavedate kaksne neumnosti govorite". Opa ;)
MadManMato: well said. Cene enostavno niso primerne za nas trg.
Ziga Dolhar ::
Perci: mi dr kregamo, da imata Telekom in SiOL visoke cene, podjetja pa pravijo, da so dumpinške :] A ni to hecno? :]]]*
BaRtMaN ::
Ja, cene pr nas so res visoke.
Država se vse bolj trud met evropsko primerljive davke, cene... Ne trud se pa, da bi mel folk evropsko primerljive plače! Razmerje je kar 3:1 in ni mi treba govort v čigavo prid.
andrej ::
bart: DRZI kot pribito. Vsi bi radi bli evropski, pa evropske cene pa evropso to pa ono. ;((
Najbolj bomo zadovoljni ce bomo enkrat meli evropske place. Druga nam ne manjka
vodik??
Oddelek: Šola
262854 (2344) tomi66
Billyjeve zvezde: Železje bo brezplačno, ne pa programje!
233075 (3075) CaqKa
Kako bi lahko izgledal Longhorn
203887 (3887) andrej
Razvoj novih Windows primerljiv z odpravo na Mesec
223161 (3161) andrej
Microsoft kupuje antivirusno podjetje
Oddelek: Novice / Varnost
202747 (2747) Neandertalec
