[Vse o DSLR]
[Vse o DSLR]
KTr1sk ::
Pa sem zamenjal pred dnevi 40D z 5D (dobil dokaj poceni) :) in je zdaj je večji užitek fotkat z 50mm 1.4, je le večji širši kot, pa tudi čez kukalo je lažje gledat, ko je večje okno :)..samo LCD na fotkiču je zanič :P..no zdaj pa prodajam Sigma 18-50mm F2.8 EX DC, ker je črn rob in nima prave uporabe na FF, rabim pa nekaj širokokotnega, sem pa gledal in našel poceni tukaj
Sigma 28-105 mm CANON EF F2.8-4 100EUR in 14,79EUR ptt (je rekel da velja paypal plačilo)
https://www.ebay-kleinanzeigen.de/s-anz...
ampak sem bral da je zaslonka 2.8 samo na 28mm in kao neuporabna in da je "mehka" slika..zato nisem "upal" v nakup..in ker nimam trenutno veliko EUR sem gledal in našel tole pocen alternativo
Canon EF II 3,5-4,5 / 28-70 (star cca 23 let heh) in kupil za 63EUR in 12EUR pttja
http://www.ebay.de/itm/201565041328?_tr...
in kljub temu da ima slabšo zaslonko baje da je "dober" oz ima dobro ostrino
Here's another general zoom alternative: the Canon 28-70 II. This lens is a beast. Don't let its humble design and average build quality fool you - this lens performs extremely well.
No, it doesn't have fast USM autofocus like the 28-80, and the 28-70's design looks a bit old. The focus ring is narrow, and the build quality is simply average. But this lens is still a massive value, simply because of its glass. The images it produces are very sharp. Some say the image quality is on par with L lenses. You can find this lens on eBay for $100 or less - a bargain.
https://contrastly.com/old-inexpensive-...
https://macdyphotos.com/2011/01/28/cano...
http://www.dpreview.com/forums/post/505...
http://www.dpreview.com/forums/post/416...
http://www.lenstip.com/451-Canon_EF_28-...
še fotke s tem objektivom
https://www.flickr.com/groups/canon2870...
če ne bo za 70EUR ok, še vedno lahko prodam za ta denar :)
  • spremenil: KTr1sk ()
dottor ::
Jaz sem preko bigbanga uzel neki malega opreme (in kasko zanjo) na 1 leto... 145€/mesec se da preživet :)
freesty ::
KTr1sk je izjavil:
Zelo dober objektiv, ki ga lahko najdes zelo poceni, ce imas malo srece, je 28-135mm IS USM.
http://www.youtube.com/watch?v=5hfYJsQAhl0
KTr1sk ::
a si imel oz uporabljaš 28-135mm IS USM? Ker imam ponudbo s poštnino skupaj za 117€, verjetno je vredu ponudba
freesty ::
Sem imel hkrati sigma 24-70 2.8, prvo verzijo. In 28-135 IS USM macro. Ta drugi je bil svetlobna leta pred sigmo, ostrina, kontrast, barve. Edino sigma je imela vecjo zaslonko. Za 117€ se ga splaca uzet. Ponavadi se prodaja za 160€+.
KTr1sk ::
Nisem se odločil za 28-135 IS,..še dobro da se nisem, ker je imel napako, da včasih ne deluje AF, torej samodejno ostrenje ne deluje vedno,..sem pa tačas dobil iz ebaya
28-70 3.5-4.5 letnik 1988 in je objektiv kot nov (če ne bi vedel, bi rekel da je star kakšno leto heh) in ne bom drugega kupoval, deluje lepo, tule so dve sliki
pri 28mm
in
pri 70mm
KTr1sk ::
Tako da zdaj imam
Canon EF 50mm 1.4 USM
Vivitar 100mm/3.5 AF Macro
Če bo kdo kupoval Vivitar 100mm/3.5 AF Macro, zadeva sploh ni slaba, za 105€ sem kupil na ebayu
test
100mm f3.5 1/25 slikano brez stojala, pri dokaj slabi svetlobi
in
100mm f3.5 1/500 ISO 50
freesty ::
KTr1sk je izjavil:
pri 28mm
in
pri 70mm
Jaz sem predlagal delujocega, nisem vedel, da ne deluje.
Drugace pa zgleda, da sva soseda hehe. Jaz sem 100m naprej doma :)
SumTingWong ::
Pozdravljeni.
Kupujem prvi DSLR, pa me zanima najbolj glede objektivov. Body sem skoraj 100%, da bom kupil Nikon D5300.
Malo sem povprašal v Bigbangu, ampak tam bolj tako tako verjamem prodajalcem. Zanima me glede 18-55mm objektiva. Je res tako slab? Veliko profitiram če vzamem 18-105/135mm objektiv?
Namen je spoznavanje z manual nastavitvami in pa "podokumentiranje" dogodkov/potovanj.
Cena za oboje skupaj je tam max 700€. Razmišljal sem o D5300 body iz nemčije in pa rabljen objektiv iz bolhe.
dj_uro ::
raje rabljen body pa boljši objektiv
vw-klub.si
SumTingWong ::
Kaj/kateri pa je boljši objektiv? Na kaj vse se gleda pri nakupu objektiva? Pri bodyju ni nekega experimentiranja kot vidim.
gddr85 ::
18-105 je imo vseeno boljši, še boljši pa 18-70
body bi jst tud rabljen vzel npr. eno d7xxx serijo, mal večji pa več fizičnih gumbov, pa večino okvir iz aluja
  • spremenil: gddr85 ()
Janac ::
Vsak objektiv, ki nima vsaj f/2.8 je bolj pogojno uporaben.
dj_uro ::
Ni res...
vw-klub.si
Janac je izjavil:
Tole si zdaj sicer malo v temo brcnil.
Hasselblad je za svoj brezzrcalni aparat predstavil dva nova vrhunska objektiva - en je f3,2, drugi 3,5 (širokokotnik in normalen).
Z Olympusom 300 mm sem super zadovoljen, pa je "samo" f4.
Samyangov ribji uč je f3,5, kar je v veliki večini primerov več kot dovolj.
Tudi zaradi same ostrine, če hočeš optimalno, je koristno zaslonko malo zapreti, na f4 do f8 (odvisno od formata in objektiva).
V resnici je slikanje z f2,8 ali še manj bolj stvar izjemnih okoliščin, ko nimaš dovolj svetlobe. Včasih je bilo to precej bolj kritično, ko si imel v aparatu Kodachrome z ISO 25 (in ne, 25 ni napaka, najboljši diafilm je imel takšno občutljivost).
dottor ::
Poglej za kakšen D90 s 30-40tisoč kliki za neko normalno ceno, pa za začetek bo 18-105 čisto dovolj za učenje ;)
korenje3 ::
Okapi je izjavil:
Janac je izjavil:
F3,2 na medium frame je drugo kot F3,2 na full frame. ekvivalent bi bili T-stops, ki se uporablja v profesionalni industriji video kamer.
no comment ::
Najboljši filmi so še danes ISO 50. Če maš samo f4 si že kar omejen. Podnevi pa gre...
Drugače pa je f3,2 na FF... eh, kaj bi se matral...
Korenje se že spet pametnega dela, čeprav nima dosti pojma.
F3,2 je načeloma povsod enak, kar se osvetlitve tiče. Format oziroma velikost filma ali tipala nima pri tem nič. Vrednosti t so res bolj natančne, ampak razlika ne nastane zaradi formata tipala, temveč zaradi izgub svetlobe v samem objektivu. V praksi pa so razlike zaradi teh izgub tako majhne, da se jih mirno zanemari.
BigWhale ::
Okapi je izjavil:
T-stop je garancija za kolicino svetlobe na tipalu/filmu. F-stop je pa samo razmerje med goriscnico in premerom odprtine skozi katero pade svetloba. Razlike so resnicno minimalne vendar so pri filmu precej pomembne, drugace lahko hitro ostanes z dvema posnetkoma, ki ju ne mores zmontirat skupaj (je pa to danes lazje, kot je bilo vcasih, ko so delali s filmom)
Bistveno za to debato je, da razlika ne nastane zaradi velikosti tipala/filma. Dva Canonova objektiva za full-frame imata lahko pri istem F različen T. Ampak pri fotografiji je to zanemarljivo že od vsega začetka, tudi za profesionalce, zato se tudi uporablja F.
no comment ::
Tudi deklarirane goriščnice in f-števila pri objektivih so precej "kreativno" zakrožena.
Razlike med f in t-številom je pa daleč od zanemarljivega (razen, če rečemo, da pol stopa ni nič in en stop minimalna razlika). Sploh na digitalnih senzorjih, film je požrl praktično vso svetlobo, ki je padla nanj, današnji senzorji imajo še vedno precej probleme kadar je kot vpadbe svetlobe velik. Enkrat je nekdo objavil test z t-stopi za veliko Nikkorjev, pripnem, če najdem...
Je pa to na digitalcih trivialno za popravit. Človek tega ne bo nikoli opazil.
Profesionalni fotografi uporabljajo izključno f že od vekomaj. Če bi razlike ne bile zanemarljive, bi verjetno uporabljali t ali kaj tretjega. Odkar se svetlobo meri skozi objektiv, pa je tako ali tako bolj ali manj vseeno, kaj piše na objektivu. T je bil pomemben pri filmskih kamerah tudi zato, ker so svetlobo vedno merili z zunanjimi svetlomeri.
Kvečjemu je vse to koristno vedeti, da se ne nategneš s kakšnim objektivom, ki se hvali z f0,95, a v resnici ni nič svetlejši kot f1,2 ali 1,4 - pa še to velja samo za tiste, ki mislijo, da je f0,95 hudo boljše od f1,2.
gddr85 ::
potem imaš lahko objektiv z max 1.2 zaslonko, ampak glede na t vrednost je možno, da pride svetlobe skozi samo za f1.4 vrednost, potem to ni čist 1.2 objektiv, kolker razumem..
Ja, glede osvetlitve res ni. Koliko se bo to poznalo, je odvisno predvsem od načina merjenja svetlobe. Če fotoaparat meri dejansko svetlobo, ki pade na tipalo, potem bo osvetlitev še vedno čisto pravilna.
Kar se globinske ostrine tiče, pa velja vrednost f, se pravi razmerje med goriščno razdaljo in premerom luknje, skozi katero gre svetloba (če je seveda oboje pravilno izmerjeno, kar ni nujno).
Saintek ::
Hm tip je vprašal za nasvet okol fotkiča, vi pa o zaslonkah nekih objektivov nabijate, o katerih dotični osebek nima blage vezalke....
no comment ::
Okapi je izjavil:
Ker na telefonu ne bom cesal internetsov... Iz glave, Nikkor 85/1.4D je imel razliko skoraj 2/3 stopa. Ni pa bil niti najvecji "laznjivec".
Zanemarljivo? Odvisno za koga oz. od okoliscin...
no comment ::
Okapi je izjavil:
Poenostavljeno. Drugace lahko imata dva razlicna objektiva iste goriscnice in iste odprtune zaslonke precej razlicno globinsko ostrino.
Ampak to samo toliko, da malo dodatno iritiram Sainteka...
korenje3 ::
BigWhale je izjavil:
Okapi je izjavil:
ja sem narobe napisal. mislil sem DOF.
očitno ne morem konkurirat okapiju ki googla za ta forum 17 ur na dan (sodeče po objavah na forumu). eni imamo službe pa smo tukaj gor 1 uro na dan.
BigWhale ::
no comment je izjavil:
Okapi je izjavil:
Ja, pri fotografiji je to zanemarljivo. Pritisnes sprozilec do polovice, aparat zmeri kaj in kako, nastavis ostale stvari in fotkas. Bistveno je to, da f-stop NE pove koliko svetlobe pade skozi objektiv, pove samo kaksno je razmerje med odprtino in goriscno razdaljo.
BigWhale ::
gddr85 je izjavil:
Se vedno je to f1.2 objektiv.
Pri cemer f goriscna razdalja, D je pa premer vstopne odprtine oziroma zaslonke.
dottor ::
S to debato ste človeka, ki sprašuje po nakupu DSLRja, tolko zmedli da bo dalje fotografiral s telefonom ;((
no comment ::
dottor je izjavil:
Če ga je to zmedlo, potem naj pusti DSLR zaenkrat še pri miru in slika s telefonom.
Če zanemarim, da vsaj polovica mojih aparatov ne naredi absolutno NIČ, če pritisneš sprožilec do polovice, je vseeno razlika ali z enim objektivom aparat potrebuje 1/50, z drugim pa 1/25, da je slika enako osvetljena.
dottor ::
Pač šli ste v precej tehnično debato, katera je za začetnike nepotrebna ;)
SumTingWong ::
Razumem približno. Razen pač tega računanja in formul.
Kaj pa menite o Canon 600D + Canon EFS 18-55mm in Canon EFS 55-250mm?
Sem "privrženec" Canona, za Nikonom se oziram ker naj bi bil boljši p/p pri nakupu novega.
Oziroma če mi lahko površno razložite čemu je namenjen 18-55 objektiv in čemu 18-105 ali pa 55-250?
dottor ::
Mimovrste ima 700D + 18-55 za 500€ v akciji trenutno:
https://www.mimovrste.com/zrcalnoreflek...
Jerry000 ::
Kako se lahko naučim več o barvah oziroma o editiranju slik? Na primer, slikam sliko in bi jo rad v Lightroom barvno uredil da bo...waw slika (po domače). Kje lahko začnem kako in kaj?
BigWhale ::
A ves, da to ni debata o tebi in o tem kako imas ti nastavljen svoj fotoaparat?
En cel stop razlike med dvema objektivoma, enakih dimenzih in enake f oznake je ze kar extrem.
Ampak spet, f oznaka ne pove PRAV NIC o dejanski kolicini svetlobe, ki pade na senzor. Vse kar ves je to, da lahko pri f1.4 uporabis za polovico krajsi cas osvetlitve kot pri f1.8.
dottor je izjavil:
Sej je tema o 'Vse o DSLR'. ;)
  • spremenil: BigWhale ()
nofaith ::
Jerry000 je izjavil:
Najdes na kaksni piratski strani kakšne presete, lahko jih tut kupiš (VSCO film preseti so ful znani) in pol mal gledaš kakšne stvari so ti učeš in si mal kreativen, drugače pa lahko pol tudi uporabljaš actions v fotoshopu, mal probavaš pa vidiš kaj ti je všeč.
V prostem in neprostem času tehnološki entuziast.
dottor ::
Odpri fotografijo v lightroomu, pejdi v develop in se malo igraj s slajderji in vidi kaj dela kateri.
Jerry000 ::
Torej ni nekih smeri? Ker igram se že lahko, ampak ali je tisto potem "pravilno osvetljeno", to je tisto kar me zanima. ALi je to bolj subjektivno? Rad imam namreč bolj dramatične fotke kar se tiče barv, močni kontrasti
dottor ::
Sam sem si za bolj natančen editing pobral še Google NIK zbirko (ne vem če je še vedno zastonj), ampak kot pogruntaš kaj kej dela je z njim užitek delat :)
nofaith ::
Da je pravilno osvetljeno je tako da tale histogram pod sekcijo develop zgleda kot zvon. http://prntscr.com/bl08qb Čim mannj stvari naj bi bilo čisto levo pa desno naprimer takole http://prntscr.com/bl09cy potem pa popravis da je takole http://prntscr.com/bl09q2. Z whitebalancom pa je tako, da probaš ljudi narest čim bolj normalne taki kot so res. V raznih gozdovih je to velik problem zelene svetlobe (ker se povsod odbija) se da probat u fotoshopu popravljat z actions. Če u gozdu slikas je dobro met take kartice https://goo.gl/GxHzqu da potem zlahko popraviš whitebalanca (to sta prvedva sliderja Temp in Tint).
No za začetek je, če te pa še kaj zanima pa vprašaj.
Jerry000 ::
nofaith je izjavil:
Bom kar vprašal :). Na primer, če bi jaz tisto sliko editiral (les) mi je veliko bolj všeč prvi, nepravilni primer kot pravilni. Torej ta slika http://prntscr.com/bl09cy mi je veliko bolj všeč kot ta http://prntscr.com/bl09q2. Zdaj ali je to vseeno in se gleda na osebne preference ali se drži nekih takšnih pravil kot si rekel v histogramu? Je to vedno tako da naj bi izgledal kot zvon?
Glede teh kartic pa jih niti ne znam uporabljat :P.
dottor je izjavil:
Ha, za to pa še nism slišal, bom testiral :). Ti je boljše to kot Lightroom? Zakaj?
  • spremenil: Jerry000 ()
dottor ::
Google NIK je dodatek za Lightroom in Photoshop in ne samostojen program. Zadnjič sva s kolegico ob sprehodu stisnila par fotografij, kjer je imela rdeč dežnik. Zaradi sonca ki je prodiralo skozi dežnik je bil obraz hudo rdeč vse ostalo pa normalno osvetljeno. Pol pa sem z lahkoto popravil samo osvetljenost in barvo kože na obrazu z Viveza 2, kjer dodajaš točke in obseg delovanja in imaš slajderje pol za vsako od teh točk.
nofaith ::
To se gleda na osebne preferenca seveda, saj fotografija je tudi umetnost ;). Ta histogram je samo neka smernica po kateri se lahko orientiraš kako svetla je sama fotka.
Za kartice pa pač ko slikaš nekje v enem okolju gozd jih postaviš nekam na tla, al jih pa pridržiš pred objektivom če maš dovolj dolge roke. Potem pa v lightroomu klikneš na tale tool pri whitebalancu (http://prntscr.com/bl0ng6) in klikneš na sivo kartico in bo white balance pravilen in pol prepišeš številke od whitebalanca na ostale slike (oziroma se zihr da tut applyat isti whitebalance na ostale slike)
  • spremenilo: nofaith ()
nofaith ::
Malo preveč sem zakompliceral z WB zadevo samo v naravi je res veliko zelene, ki se od povsod odbija in ma mnogo fotoaparatov težave z WhiteBalancom. Drugače pa sam ven slikat pa kr pridno objavljat fotke na facebooke pa instagrame.
gddr85 ::
gddr85 je izjavil:
ok, ampak teoretično dobiš svetlobno slabše zmogljiv objektiv ane?
kuglvinkl ::
glej monografije.
no comment ::
kuglvinkl je izjavil:
glej monografije.
^ Ja, definitivno najboljši in najhitrejši način, da dobiš filing kaj je dobra barvna fotografija. Potem dopolniš še s kakšnim gradivom o barvni teoriji. Oglej si kak dober film/serijo in bodi pozoren na coloring, kajpavem, The Master, True Detective (s1)...
Sreča, da ti v teh časih vseeno ni treba v štartu zapraviti na stotine (ok, bodmo pošteni, na tisoče) evrov za knjige. V google vtipkaj "masters of color photography". Če so ti npr. te fotografije čisto mimo, potem pač naključno premikaj sliderje v vseh pluginih, ki jih uspeš nabavit... Škode ne bo nobene. Koristi tudi ne.
Sicer boš pa ugotovil, da je editiranje fotografije glede na histogram norost. Izgovor za tiste, ki ne vedo kaj bi radi naredili s sliko...
40 / 93
Nov D-SLR (strani: 1 2 )
8832373 (20638) BigWhale
Fotoaparat dober nakup? (strani: 1 2 )
Oddelek: Zvok in slika
6628601 (22653) schurda
Sigma je najavila (svetlobno) hiter zoom objektiv 18-35mm f/1.8
3815561 (13013) CaqKa
zrcalno-refleksni fotoaparat (strani: 1 2 3 )
14029583 (24434) schurda
kateri 4\3 fotaparat do 500evrov (strani: 1 2 3 4 5 )
20445883 (42725) bluefish
