Forum » Mobilne tehnologije » Nokia 5800 XpressMusic
C_AGUILERA ::
* Kinetic scrolling
* Home style widget with Nokia 5530
* if you rotate the phone horizontally, it automatically activates the QWERTY keyboard
* Refresh Icons "Sharing Online", "Configuring Accessories", "Configure Phone"
* Improved application "Updating Applications", which also renames Upgrade SW
* The application "Data transfer" was also implemented in "Settings"
* Real Player Updated
* Touch more responsive
* Slide to Unlock during call
* Improved stability
* New contact & music widget
* Kinetic Scrolling is not available in main menu, application menu, browser.
* Home Screen similar to that of Nokia 5530
* Removed the alphanumeric keypad in landscape version, now when we turned the phone alphanumeric portrait changes to full qwerty
* New screen alarm, but only when the screen is locked
* New screen incoming call, also only when the screen is locked
* Ovi Contacts installed
* In the settings menu there is a new icon for 'Phone Switch'.
by D way.....tole mam že od začetka januarja, saj sem zamenjala product code..
- spremenila: C_AGUILERA ()
sulaco ::
Hm, hm zakaj pri tejle nokii ne deluje opomnik za rojstne dni. Na SE te vdeno opozori na RD, če je zapisan pri osebi v imeniku, 5800 pa ne ?? A je potrebno kje kaj obkljukat??
Bor H ::
Renatox: ko se sprijazniš s tem, da 80+% uporabnikov tega foruma ne bere debate in samo piše neumnosti ugotoviš da bit pameten kle sploh ni težko
Bor H ::
ne ne, to cilja na uporabnike ki pridejo z "X končno na voljo za Y!!" ampak ne vidijo da je njihov vir star cirka mesec in da se o tem že vsi pogovarjajo..
denabiker ::
NOKIA 5800
Uradno je prišla teško pričakovana različ. V40.0.005!
a rad dražiš ljudi? hehe. KO bo za SLO ta na voljo, bo za ostale države že verjetno v45, v50 itd.
navodila preberi!
C_AGUILERA je izjavil:
a kdo ve še za kakšno super aplikacijo?
kaj bi rad imel? symbian aplikacij je milijone. Obišči kakšen ipmart itd.
- spremenil: denabiker ()
sulaco ::
denabiker: pa se ti zavedaš, da forume ne berejo samo rač. geeki ampak tudi ljudje z pomanjkljivim znanjem računalništva in angleščine, ki forumaše včasih vprašajo zelo enostavno vprašanje, na katerega pričakujejo enostaven vzpodbuden odgovor....
Kot je meni znano, nokia5800 NIMA OPOMNIKA za rojstne dni, ki jih shraniš k profilu osebe iz imenika....
Mogoče kdo uporablja kakšen dodaten program, da RD datume prebere iz profila in jih označi v koledarju ter po možnosti zapiska alarm/opozorila, ko nastopi ustrezni datum ??? Ali pa pričakujem preveč od telefona za 200EUR?? :(
Madona, pa to ima vsak SE-mobi za par cekinov..
C_AGUILERA ::
saj vem, da je ogromno aplikacij....mene zanima, če kdo uporablja kakšno nad katero je zelo navdušen??
ne me zdaj zarad tega grdo gledat.
Bor H ::
Jst redno uporabljam Opero Mobile, najdejo se še Google Maps, en wisget za po Wikipediji brskat, se še odločam a je kul al ne, imdb widget, Skype če ti je do takih zadev, Nokia messeging (za maile), od offscreen pa mam še converter, timer, bright light in calculator
ivanuscha ::
Jst sem zelo navdušen nad igro SPB Brain Evolution, pa MicroPinball je tud fajn.
Glede roj. dnevov - kokr jst vem je edina varjanta da greš v koledar in nataviš dogodek ki se ponavlja ter dodaš opis.
js osebno ::
Aplikacije ki jih redno uporabljam: Free-iSMS (SMS program ki je mnogo hitrejši od vgrajenega), FolderPlay (Za uživanje ob .FLAC glasbi, ki je vgrajen predvajalnik ne podpira, Opera Mobile (hitrost), Skyfire (Včasih si zaželim videti flash na internetu), Quickoffice, VideoHub (hitrejši od Youtube predvajalnika z Ovi stora), zraven pa imam še okoli 20 aplikacij, ki jih včasih pogledam.
Glede koledarja se mi zdi pa zanimivo, moral bi nekje imeti gumb za sinhronizacijo z imenikom.
- spremenil: js osebno ()
martincek1 ::
Ena zanimivejših in novejših aplikacij je tudi Opera Widgets 10.00
Trenutno podpira Google translate, twitter, wikipedio in facebook. Glede na to, da je bila izdana šele včeraj, upam da bodo počasi kapljali tudi drugi widgetsi ;)
Bi se pa vsekakor priporočal za kakšen widgets za slo-zeleznice, alpetour, lpp, če je kakšen programer tukaj
Dri3r ::
Ne draži ljudi.Pred 2 urama sem preko posodobitev naložil v40 firmware na Nokio 5800XM, kupljeno pri Simobilu.
dri3r
WaterBoy ::
denabiker ::
E to. Je res čudno da nima rojstnih dnevom. Se je treba malo znajti![]()
Pa daj nehaj no...Preko pc suite ali novejšega OVI-ja si nastaviš kaj hočeš. Če pa greš preko telefona je pa menda ime obletnica. Samo najbolj simpl, da uporabljate suite ali pa ovi, pa ne samo za koledar ampak tudi za sporočila, imenik itd.
nastaviš lahko:
Sestanek
Klic
Sestanek
Rojstni dan
Obletnica/letni dogodek
Beležka
Dogodek/planer
Opravilo
Opravilo
Opomnik
Dogodek
Opombe
Opombe/Beležnica
denabiker ::
evo ta je popularen program za RD (Uses information from native Contacts and Calendar databases )
BEST BIRTHDAY
opis:
http://nokia-5800-software.smartphonewa...
BEST BIRTHDAY
opis:
C_AGUILERA ::
BEST BIRTHDAY
opis:
a ni tale demo?
denabiker ::
BEST BIRTHDAY
opis:
a ni tale demo?
če ga kupiš je normalno delujoče. Lahko ga pa potegneš s "pašnika" s keygenom
Jaz ga nisem še uporabljal, ke rmi je to brezveze, saj uporabljam obstoječ kolendar v nokiji, če dodaš rojstni dan še imaš ikono kot torta in svečke - nekaj takšnega. Sam uporabljam pc suite in sihroniziram z outlookom razna opravila, sestanke itd., tako da sem na tekočem tudi na PC-ju. Imam še google sync, kateri mi sinhronizira z gmail kolendarjem in tega imam v skupni rabi s punco. To mi je čisto dovolj.
imaš pa še podobne programe: Fandango60 Birthdays, Friends Birthdays, Aims Migital Tech Birthday Mate ,...
Mare3 ::
Telefon kupljen pri simobilu in s pomočjo Nokia Software Updater mi je uspešno nadgradilo na v40. telefon mam pa kupljen 2 meseca nazaj
denabiker ::
drugače pa toliko (ko se gremo poštene Slovence):
Piratstvo programske opreme je nezakonito kopiranje in distribuiranje programskih aplikacij za poslovno ali osebno rabo!
Po drugi strani je pa treba spoštovat pravice intelektualne lastnine itd.
Drugače je pa polno freeware na netu.
Zakaj vam pa ne paše obstoječa varianta v kolendarju obletnica/rojstni dan?
e-marko ::
Verjetno zato, ker bi bilo lažje, da ne bi bilo potrebno še enkrat vpisovati vse roj. dneve v koledar, če so že vpisani v vizitki. Predvidevam.
...somebody, somewhere...
denabiker ::
hej najdel na oviju Best Birthday for S60 5th ed, cena 2EUR
http://store.ovi.com/content/5830?click...
DuleKrtola ::
Js iščem en ftp client. Za silo je opera v redu, ampak omogoča samo dl in še to le nekaj tipov datotek, recimo .pdf. Probal sem SIC! ftp, pa se noče povezat na server. Dobite ga tukaj:
http://www.symbian-guru.com/welcome/200...
A komu dela? Uporabljate mogoče kako drugo app?
AapocalypseE ::
Se je že komu zgodilo, da se mu je lcd kar sam od sebe vgasnil? Prej sem vnašal kodo za wireless... stisnem OK, da se poveže in se je lcd počasi samo vgasnil. Potem se je sam prižgal nazaj in je pisalo gor samo nokia pač tisto pozdravno sporočilo in ni blo več nič iz tega. Sem moral dat ven baterijo in nazaj noter.
js osebno ::
@StreetRacer
Zadevo povzroči rahlo razrahljan konektor LCD zaslona, problemi pa se pojavljajo pozimi (ob nižjih temperaturah). Meni se naredi recimo enkrat na mesec. Največkrat se pojavi, ko je telefon dalj časa hladen in se ga nato da na toplo, včasih pa je vse skupaj zelo spontano. Menda pa napako povzročata tudi Wi-Fi in EDGE anteni.
Samson ::
Mnjah. Sem upal da bo nokia s tem zadnjim FW popravila totalno blikado telefona, po kateri je treba baterijo ven in na novo uzgat telefon. In kaj se je zgodilo? :O)
Sedaj blokira se veliko vec kot prej. Mislim da je razlog tisti drsni odgovor na klic. Zadevo resujem na ta nacin, da frknem v levo da se telefon odklene, potem pa klik na "ikono" za sprejem klica. Je kdo najdel kaksno resitev glede zamrznjenega telefona ko zelis klic prekinit?
condom.com not found - load pregnant.bat - done :O)
js osebno ::
@Samson
Fw update ne more rešiti hardwersko pogojenih težav. Kot se že prej omenil sta za to kriva razrahljan konetktor LCD zaslona in pa zimske temperature (poleti se vsaj meni te težave niso dogajale).
Za klicanje imaš pa spodaj na telefonu 2 namenski tipki (zeleno in rdečo).
Samson ::
Kar se tice konektorja bo verjetno treba na servis. Moram povedat da se to meni dogaja tudi poleti. Do namenskih tipk pa moram vseeno telefon odklenit verjetno, hehe. Edino ce dela tudi brez odklepa telefona...
Sam ceprav malce pomislim. Zakaj potem zadeva ne zmrzuje kadar pisem sms, ali kaj brskam po telefonu. Ali je res tolk slampasto vse skupaj da je zrahljan konektor kriv le za sprejem klica in zadeva freezne??
- spremenil: Samson ()
C_AGUILERA ::
meni pa samo zdjle pozimi kdaj zmrzne, poleti mi ni nikoli, vsaj ne spomnem se..pa ga imam od aprila. Me pa to sploh ne moti, tudi komp kdaj "zmrzne" (zablokira).
Samson ::
Hja meni se ne zalost vse veckrat dogaja. Pa mi niti enkrat samkrat telefon ni padel. Samo po sebi...
js osebno ::
@Samson
Možno je, da GSM (EDGE)antena povzroči nekaj, kar prekine delovanje LCD zaslona. Meni se je zadeva od začetka (recimo februarja prejšnje leto) pojavljala, ko sem bil res ogromno na internetu. In se je telefon ugasnil kar nekajkrat.
Samson ::
Ne uporabljam veliko interneta. Omrezje nastavljeno na GSM, brez kaksnih 3G in podobno. Pac kadar se oglasim zadeva deluje. Pogovarjam se in vse ok, ceprav je telefon freeznu in potem ne reagira na nobeno tipko. Je treba bakterijo ven in na novo prizgat. Seveda baterija pade za crtico ali dve, hehe. Mozno da je kaj kriv kontakt ekrancka kot je prej omenil. Predvidevam da to naredijo na licu masta pregled kontakta. Upam, hehe.
DuleKrtola ::
Men pa frizne, če sprejmem klic medtem ko imam zaklenjeno tipkovnco, in sicer za tem ko se klik konča. Se še komu to dogaja?
Samson ::
Pri meni je tako. Zato pri tazadnjem FW odklenem telefon in sprejmem klic. Se se ni zgodilo da bi zablokiral...
biokill ::
jaz še vedno nemorem posodobiti, 5800nav. edit, kupljen pri mobitelu...
Posodobitev za telefon mi sicer najde, naredi backup potem pa pri inštalaciji napiše, da ni povezave s strežnikom oz. da naj spremenim nastavitve v požarnemzidu........internet dela normalno, firewall je sklopljen pa useeno noče....imam pa 31.0.008.c04.01 različico gor..
anybody?
anybody?
amacar ::
imaš mogoče nod32 (seset smart security), ali kakšen antivirusni program, ki ima požarni zid?
biokill ::
nimam antivirusa. na *#0000# sem ze veckrat probal. vendar mi na sredi instalacije javi napako. da pro.oprema ni zdruzljiva z telefonom
C_AGUILERA ::
anybody?
stari, nared backup, pa ga pol *#7370# ....HARD RESET (pazi, vse zbriše). Pol pa daš obnovo podatkov. Ne vem, lahko, da bo potem boljše. Ima kdo boljši predlog???
AapocalypseE ::
thejan2009, hvala za obrazložitev.
*#7370# je soft reset. Zbriše cel pomnilnik telefona. Ostane samo OS in privzete nastavitve telefona. Pomnilniške kartice ne zbriše.
- spremenil: AapocalypseE ()
C_AGUILERA ::
okej..pol je pa hard reset, ugasnes mobi in drzis: zelena tipka+rdeca tipka+kamera tipka+vklop. SAJ JE LOGICNO, da se spominska kartica ne zbrise!
js osebno ::
@volbabe
ne. rdeča+zelena+kamera+power button je povsem isti reset kot *#7370#
Verzija z tipkami je za tiste primere, ko se NE moremo dokopati do tipkovnice na telefonu.
Je pa to t.i. HARD reset. Soft reset (ali cold reset) naj bi bil reebot (ponovni zagon telefona). Obstaja še Deep Reset, ki zbriše samo uporabniške podatke, nastavitev in drugih sistemskih stvari pa ne ponastavi.
C_AGUILERA ::
@thejan2009
aha. no tko. tnx ej, se mi je zdelo, da je to v bistvu isti reset...pa ti res use ves
<333333 http://www.youtube.com/watch?v=wwCykGDEp7M&sns=fb
| » | Nokia E52 (strani: 1 2 3 4 5 6 7 8 )Oddelek: Mobilne tehnologije | 94558 (52573) | mailer |
| » | Nokia X6 firmware updateOddelek: Mobilne tehnologije | 3024 (2446) | krneki0001 |
| » | HTC Tattoo - Simobil (strani: 1 2 3 4 5 )Oddelek: Mobilne tehnologije | 39818 (20973) | errhec |
| » | Nokia E66/E71 (strani: 1 2 )Oddelek: Mobilne tehnologije | 12979 (7162) | MrAs |
| » | [fork] GPS v telefonu ali Garmin - kaj je bolje (strani: 1 2 )Oddelek: Loža | 15667 (14908) | bond007 |
