Call of Duty server
Call of Duty server
SeeN000 ::
Zdravo!
Zanima me par stvari ker sem se spravil narediti server za COD UO. Zanima me kako sploh narediš server, daš notri mode, server zaznajo programi kot XFire, ASE,...Zanima me tudi kako je z rconom kako uspostavit, komande za konzolo in rcon. Skratka tisti ki imate izkušnje s serverji da se lahko vsaj 10 ali 6 igralcev poveže na tvoj server in da dela lepo brez problemov. Prosil bi tudi da ne pišete en čez drugega, ampak lepo step by step. Lahko mi pa tudi tisti z izkušnami pustite msn naslov za pomoč uspostavitve serverja. Prosim čimveč odgovorov
P.S.: Če uspe uspostavit server vam povem ip da lahko pridete gor =)
SeeN000 ::
Na internetu sem našel tudi tole:
This might be a sticky so other people know what to do. I could not get the maps to load 1 at a time.
The problem was I run the Awe mod on my CoD server and the Zoxo Mod on my CoD:UO. I had all of the files on redirect for fast downloading but I had them all in folders called awe_cod and awe_uo. I simply, I say simply cause I know now it is an easy fix but spent hours researching this, made a new folder call "main" for the cod server and put all the maps here. I left all the Awe files in the awe_cod folder. I did the same for the UO server but I named this file "uo".
Then on both servers I add another folder called "mp" and put it along the same path as the main in both servers. I then opened all the maps with winzip. I doubled clicked on the "MP" folder and COPIED not cut each arena file from each map. I then put the arena file into the "MP" folder for each server running that map.
This works like a charm and loads the mod first and then the current map being played on the server.
This makes it much faster for the people to download the mods and map and get on the server.
Fozzie from Mork Depot was the one who turned me in the direction for adding the MP folder.
Vendar pa nevem točno kaj misli s tem. Če gdo od vas razume bi ga prosil naj razloži. Hvala
skyp`R ::
Poglej na cb.Mislim da vse pise
SeeN000 ::
na cb nič ne najdem. Vseeno bi pa prosil če lahko gdo tukaj step by step napiše, mogoče bi tudi drugim prišlo prav poleg tega da je zgoraj razloženo kako clan ustvariti bi lahko prav prišlo isto za server
skyp`R ::
Pa kaki server mislis Parba.cz al prav server ki ga placujes?
SeeN000 ::
Server navaden. Na domačem računalniku bi svoj server postavil da bi lahko s prijatli igrali na njem. Plačevau pa nebi rad in tui zanima me kako se to naredi in da malo modov gor naložim
skyp`R ::
Mas org?
SeeN000 ::
nimam org. zakaj pa org? Js mislm met samo server d bomo lahko s frendi igrali na svojm serverju in d bi not mal mode dodajali
SeeN000 ::
PLIIIIIIIIIIISSSS dejte npisat za serverje ku j zihr kak tak ku to zna. Res bi prosu
Pyr0Beast ::
Lavfneš dedicated in to je to. Dol si lahko se snemeš Rcon4cod in s tem preko neta nastavljaš server.
SeeN000 ::
kako pa zaženem dedicated server, če sem za server dal bljižnico na namizje in pod lastnosti bližnjice napisal tole: "C:\Games\Call of Duty\CoDUOMP.exe" +set dedicated 2 +set sv_punkbuster 1 +exec dedicated.cfg +map_rotate
Zanima me še ko imaš server kako daš mode gor na server (več modov)
Pyr0Beast ::
Zaženeš bližnico ?
SeeN000 ::
Ja zaženem bližnjico, vendar se noben ne more name povezat. Tudi če prijatelj vpiše IP se ne more povezati name.
Pyr0Beast ::
Ampak lavfa pa ?
Poglej malo za COD server management tools ali kaj podobnega.
Kako si povezan v svet ?
SeeN000 ::
Povezan sem preko routerja ampak sem že gledal če je odprt port 28960 in je. Server a tudi laufa, vendar grem samo jaz lhko gor, prijatelju sem dal moj IP in ni mogel se povezati. Any ideas? =)
Pyr0Beast ::
FW maš vklopljen ..
Če router to omogoča, vklopi DMZ.
Call of duty 4 (strani: 1 2 3 4 … 13 14 15 16 )
Oddelek: Igre
78877817 (19722) oo7
Apache - localhost JA, IP naslov NE
Oddelek: Omrežja in internet
187286 (7145) ManDriver
Valve & STEAM & On-Line gaming (strani: 1 2 )
Oddelek: Igre
7110035 (8457) Tilen
Kako v Win2k premakniti mapo Documents and Settings?
Oddelek: Operacijski sistemi
62545 (2511) Mercier
Program za web server?
92873 (2732) Hojne
