Virtualdub
Virtualdub
raso ::
Rad bi skrajso eno avi datoteko z virtualdubom in ne gre ko je skusam odpret mi ispise
no audio decomprresor could be found to compresor the source audio format
source format 0055
hvala za pomoc
StratOS ::
poguglaj in našel boš ...
Go
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
amigo_no1 ::
V programu gspot odpri to avi datoteko in videl boš kaj ti manjka.
mavec ::
Tu je nekaj o rešitvi problema.
Klik
Pa poskusi z VirtualDub Modom. :)
VirtualDub za začetnike (strani: 1 2 )
Oddelek: Zvok in slika
5816494 (9900) Revenant
Pretvorba DIVX v KVCD (strani: 1 2 3 )
11930268 (9704) LexLuthor
Snemanje avi filmov
373723 (3119) gruntfürmich
*.ogm Format
344677 (4242) trpo
Kako convertirat DivX v VCD??
415146 (3782) jabe
